[求助] 升級(jí)php5.3,腳本成功,但是還是5.2
升級(jí)php5.3顯示成功
  1. Wrote PEAR system config file at: /www/wdlinux/apache_php-5.3.17/etc/pear.conf
  2. You may want to add: /www/wdlinux/apache_php-5.3.17/lib/php to your php.ini include_path
  3. /root/php-5.3.17/build/shtool install -c ext/phar/phar.phar /www/wdlinux/apache_php-5.3.17/bin
  4. ln -s -f /www/wdlinux/apache_php-5.3.17/bin/phar.phar /www/wdlinux/apache_php-5.3.17/bin/phar
  5. Installing PDO headers:          /www/wdlinux/apache_php-5.3.17/include/php/ext/pdo/
  6. Stopping httpd:                                            [  OK  ]
  7. Starting httpd:                                            [  OK  ]
  8. php update is OK
但是info顯示還是5.2.17
info中:
  1. Configuration File (php.ini) Path        /www/wdlinux/apache_php-5.2.17/etc
  2. Loaded Configuration File        /www/wdlinux/apache_php-5.2.17/etc/php.ini
但是wd后臺(tái)
  1. php優(yōu)化參數(shù)設(shè)置
  2. php優(yōu)化參數(shù)設(shè)置
  3. 變量設(shè)置
  4. 當(dāng)前
  5. 配置文件
  6. /www/wdlinux/etc/php.ini
這里的/www/wdlinux/etc/php.ini   是指向5.3的php.ini文件的
所以請(qǐng)教一下,怎么切換到5.3上
