[求助] D-link dfe-530TX 網(wǎng)卡要安裝驅(qū)動(dòng)嗎?
添加了一塊網(wǎng)卡,好像沒(méi)有驅(qū)動(dòng)。
那在官網(wǎng)找下驅(qū)動(dòng)安裝下
本帖最后由 lfghx 于 2012-2-3 09:40 編輯
看了,真的的需要安裝驅(qū)動(dòng)
**  VIA Rhine Family Fast Ethernet Adapter
**  Linux Driver
**  v5.08  Nov. 2006
Introduction:
    The instructions listed below are for linux driver installation. You must
    compile the source code to generate rhinefet.o(rhinefet.ko in 2.6.x kernel,
    please remember to replace rhinefet.o with rhinefet.ko in the following
    sentences if you are using 2.6.x kernel) and use insmod command to insert
    rhinefet.o as module.
Contents of the Subdirectory:
    linux.txt               This file.
    Makefile                Makefile for generating driver object file
    rhine_maic.c            The linux core driver source code file
    rhine_proc.c            The source to create proc entries
    rhine_wol.c             The WOL supporting source file
    rhine.h                 The extended driver header file
    rhine_proc.h            The header file for proc entries
    rhine_wol.h             The WOL supporting header file
    rhine_cfg.h             The general and basic info header file
    kcompat.h               The header file for Linux kernel version
                            compatibility.
    osdep.h                 OS depended function and macro defined
    rhine_hw.h              Rhine series MAC register supporting header file
    rhine_hw.c              shared function for accessing and configurating Rhine series MAC
Kernel Supported
    This driver supports linux kernel version 2.2.x, 2.4.x and 2.6.x now.
    For 2.6 kernel, it supported up to 2.6.18 in this version.
CPU Supported
    This driver supports x86 and AMD64 based linux system.
Installation
    Please enter the following commands at the UNIX prompt. Remember, UNIX is
    case sensitive.
    1) Create a temporary directory:
        mkdir /temp
    2) Change to the temporary directory:
        cd /temp
    3) Copy driver (rhinefet.tgz) from DOS disk, (mcopy below is one tool in
       mtools, if you didn't install mtools, you can type
       'mount -t msdos /dev/fd0 /mnt' and use 'cp /mnt/rhinefet.tgz /temp'
       command to copy the driver to the temporary directory):
        mcopy a:rhinefet.tgz .
    4) untar the archive file:
        tar xzvf rhinefet.tgz
        cd src
    5) Compile the driver source files and it will generate rhinefet.o, and
       copy it to correct driver installation path (The installation directory
       is different in different kernel versions. In 2.4.x/2.6.x kernel, the path
       is /lib/modules/KERNEL_VERSION/kernel/drivers/net/, and in 2.2.x kernel,
       the path is /lib/modules/KERNEL_VERSION/net/, the KERNEL_VERSION (see
       above) means the kernel version of your Linux distribution. If you don't
       know your kernel version , please run 'uname -r' command in command
       line. The kernel version will look like '2.2.16', '2.4.2-2smp' etc.) :
    6) Check configuration file (/etc/modules.conf or /etc/conf.modules or
       /etc/modprobe.conf, it depends on your Linux distribution) for loading
       kernel modules. Make sure the first line below is appeared in the
       configuration file, where # is the interface number (eg: alias eth0
       rhinefet). If you need to set the driver options, below second line is
       an example to set the NIC to 100Mbps fullduplex mode (remember to unmark
       the line if it is put in the configuration file).
        alias eth# rhinefet
        #options eth# speed_duplex=2
    7) Reboot now:
        shutdown -r now
    8) Install your driver module (If the driver module is in the wrong place,
       an error message will appear, and say that can't find the driver
       module):
        insmod rhinefet.o
    9) Use ifconfig command to assign the IP address, where # is network
       interface number:
        ifconfig eth# <IP>
    10) Check the interface works:
         ping <remote_host_IP>
不懂呀。。。。。
已經(jīng)寫(xiě)的很清楚了啊 大哥
