[求助] 在給php添加sockets.so模塊的時(shí)候報(bào)錯(cuò)
[root@sky ~]# service nginxd restart
Stopping nginx:                                            [  OK  ]
Shutting down php_fpm . done
Starting nginx:                                            [  OK  ]
Starting php_fpm PHP Warning:  PHP Startup: Unable to load dynamic library '/www/wdlinux/wdphp/lib/php/extensions/no-debug-non-zts-20060613/sockets.so' - /www/wdlinux/wdphp/lib/php/extensions/no-debug-non-zts-20060613/sockets.so: cannot open shared object file: No such file or directory in Unknown on line 0
done
我是這樣添加的:
1、進(jìn)入php源文件下ext/sockets目錄
cd /usr/src/lanmp/lanmp/php-5.2.17/ext/sockets/
2、執(zhí)行命令
[root@sky sockets]# /www/wdlinux/php/bin/phpize
Configuring for:
PHP Api Version:         20041225
Zend Module Api No:      20060613
Zend Extension Api No:   220060519
3、編譯安裝
[root@sky sockets]# ./configure --enable-sockets --with-php-config=/www/wdlinux/php/bin/php-config
checking for cc... cc
checking for icc... no
checking for suncc... no
checking for PHP prefix... /www/wdlinux/php
checking for PHP includes... -I/www/wdlinux/php/include/php -I/www/wdlinux/php/include/php/main -I/www/wdlinux/php/include/php/TSRM -I/www/wdlinux/php/include/php/Zend -I/www/wdlinux/php/include/php/ext -I/www/wdlinux/php/include/php/ext/date/lib
checking for PHP extension directory... /www/wdlinux/php/lib/php/extensions/no-debug-non-zts-20060613
checking for PHP installed headers prefix... /www/wdlinux/php/include/php
checking if debug is enabled... no
checking if zts is enabled... no
checking for re2c... no
configure: WARNING: You will need re2c 0.13.4 or later if you want to regenerate PHP parsers.
checking for gawk... gawk
checking whether to enable sockets support... yes, shared
checking for struct cmsghdr... yes
checking for hstrerror... yes
checking for socketpair... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking netinet/tcp.h usability... yes
checking netinet/tcp.h presence... yes
checking for netinet/tcp.h... yes
checking sys/un.h usability... yes
checking sys/un.h presence... yes
checking for sys/un.h... yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking for ld used by cc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking how to recognize dependent libraries... pass_all
./configure: line 5967: /usr/bin/file: No such file or directory
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking the maximum length of command line arguments... 1966080
checking command to parse /usr/bin/nm -B output from cc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if cc supports -fno-rtti -fno-exceptions... no
checking for cc option to produce PIC... -fPIC
checking if cc PIC flag -fPIC works... yes
checking if cc static flag -static works... no
checking if cc supports -c -o file.o... yes
checking whether the cc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking how to hardcode library paths into programs... immediate
checking whether to build shared libraries... yes
checking whether to build static libraries... no
creating libtool
config.status: creating config.h
config.status: config.h is unchanged
[root@sky sockets]# make
/bin/sh /usr/src/lanmp/lanmp/php-5.2.17/ext/sockets/libtool --mode=install cp ./sockets.la /usr/src/lanmp/lanmp/php-5.2.17/ext/sockets/modules
cp ./.libs/sockets.so /usr/src/lanmp/lanmp/php-5.2.17/ext/sockets/modules/sockets.so
cp ./.libs/sockets.lai /usr/src/lanmp/lanmp/php-5.2.17/ext/sockets/modules/sockets.la
PATH="$PATH:/sbin" ldconfig -n /usr/src/lanmp/lanmp/php-5.2.17/ext/sockets/modules
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
   - add LIBDIR to the `LD_LIBRARY_PATH' environment variable
     during execution
   - add LIBDIR to the `LD_RUN_PATH' environment variable
     during linking
   - use the `-Wl,--rpath -Wl,LIBDIR' linker flag
   - have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
Build complete.
[root@sky sockets]# make test
Build complete.
PHP Warning:  PHP Startup: Invalid library (maybe not a PHP library) 'sockets.so'  in Unknown on line 0
PHP         : /www/wdlinux/php/bin/php
PHP_SAPI    : cli
PHP_VERSION : 5.2.17p1
ZEND_VERSION: 2.2.0
PHP_OS      : Linux - Linux sky 2.6.32-220.23.1.el6.x86_64 #1 SMP Mon Jun 18 18:58:52 BST 2012 x86_64
INI actual  : /usr/src/lanmp/lanmp/php-5.2.17/ext/sockets/tmp-php.ini
More .INIs  :
CWD         : /usr/src/lanmp/lanmp/php-5.2.17/ext/sockets
Extra dirs  :
VALGRIND    : Not used
TIME START 2012-07-05 12:07:17
FAIL Bug 46360 - TCP_NODELAY constant (sock_get_option, sock_set_option) [tests/bug46360.phpt]
FAIL IPv4 Loopback test [tests/ipv4loop.phpt]
SKIP IPv6 Loopback test [tests/ipv6loop.phpt] reason: no IPv6 support
FAIL Test parameter handling in socket_accept() [tests/socket_accept-wrongparams.phpt]
FAIL ext/sockets - socket_bind - basic test [tests/socket_bind.phpt]
FAIL ext/sockets - socket_bind - test with empty parameters [tests/socket_bind_params.phpt]
FAIL ext/sockets - socket_close - test with empty parameters [tests/socket_close_params.phpt]
FAIL Test error cases when creating a socket [tests/socket_connect_error.phpt]
FAIL ext/sockets - socket_connect - test with empty parameters [tests/socket_connect_params.phpt]
SKIP Test if socket_create_listen() returns false, when it cannot bind to the port. [tests/socket_create_listen-nobind.phpt] reason: Test cannot be run as root.
FAIL Test if socket_create_listen throws E_WARNING with wrong parameters. [tests/socket_create_listen-wrongparams.phpt]
FAIL Test if socket binds on 31338 [tests/socket_create_listen.phpt]
FAIL ext/sockets - socket_create_listen - test for empty parameters [tests/socket_create_listen_params.phpt]
FAIL ext/sockets - socket_create_listen - test for used socket [tests/socket_create_listen_used.phpt]
FAIL Test parameter handling in socket_create_pair() [tests/socket_create_pair-wrongparams.phpt]
FAIL Test for socket_create_pair() [tests/socket_create_pair.phpt]
FAIL ext/sockets - socket_create - test with empty parameters [tests/socket_create_params.phpt]
FAIL ext/sockets - socket_getsockname - basic test [tests/socket_getpeername.phpt]
FAIL ext/sockets - socket_getpeername_ipv4loop - basic test [tests/socket_getpeername_ipv4loop.phpt]
SKIP ext/sockets - socket_getpeername_ipv6loop - basic test [tests/socket_getpeername_ipv6loop.phpt] reason: no IPv6 support
FAIL ext/sockets - socket_getsockname - basic test [tests/socket_getsockname.phpt]
FAIL Test parameter handling in socket_listen(). [tests/socket_listen-wrongparams.phpt]
FAIL ext/sockets - socket_listen - test with empty parameters [tests/socket_listen_params.phpt]
FAIL ext/sockets - socket_read- test with empty parameters [tests/socket_read_params.phpt]
FAIL Test parameter handling in socket_select(). [tests/socket_select-wrongparams-1.phpt]
FAIL Test parameter handling in socket_select(). [tests/socket_select-wrongparams-2.phpt]
FAIL Test parameter handling in socket_select(). [tests/socket_select-wrongparams-3.phpt]
FAIL Test parameter handling in socket_select(). [tests/socket_select-wrongparams-4.phpt]
FAIL Test parameter handling in socket_select(). [tests/socket_select.phpt]
FAIL Test if socket_recvfrom() receives data sent by socket_sendto() via IPv4 UDP [tests/socket_sentto_recvfrom_ipv4_udp.phpt]
SKIP Test if socket_recvfrom() receives data sent by socket_sendto() via IPv6 UDP [tests/socket_sentto_recvfrom_ipv6_udp.phpt] reason: no IPv6 support
FAIL Test if socket_recvfrom() receives data sent by socket_sendto() through a Unix domain socket [tests/socket_sentto_recvfrom_unix.phpt]
FAIL Test socket_set_block return values [tests/socket_set_block-retval.phpt]
FAIL Test if socket_set_block throws E_WARNING with wrong parameters. [tests/socket_set_block-wrongparams.phpt]
FAIL Test socket_set_nonblock return values [tests/socket_set_nonblock-retval.phpt]
FAIL Test if socket_set_nonblock throws E_WARNING with wrong parameters. [tests/socket_set_nonblock-wrongparams.phpt]
FAIL ext/sockets - socket_set_block - basic test [tests/socket_set_nonblock.phpt]
SKIP Test if socket_set_option() returns 'unable to set socket option' failure for invalid options [tests/socket_set_option_error_socket_option.phpt] reason: Test cannot be run as root.
FAIL Test if socket_set_option() works, option:SO_RCVTIMEO [tests/socket_set_option_rcvtimeo.phpt]
FAIL Test if socket_set_option() works, option:SO_SEOLINGER [tests/socket_set_option_seolinger.phpt]
FAIL Test if socket_set_option() works, option:SO_SNDTIMEO [tests/socket_set_option_sndtimeo.phpt]
FAIL ext/sockets - socket_strerror - basic test [tests/socket_strerror.phpt]
FAIL ext/sockets - socket_write - test with empty parameters [tests/socket_write_params.phpt]
FAIL Unix domain socket Loopback test [tests/unixloop.phpt]
TIME END 2012-07-05 12:07:21
TEST RESULT SUMMARY
Exts skipped    :    0
Exts tested     :   38
Number of tests :   44                39
Tests skipped   :    5 ( 11.4%) --------
Tests warned    :    0 (  0.0%) (  0.0%)
Tests failed    :   39 ( 88.6%) (100.0%)
Expected fail   :    0 (  0.0%) (  0.0%)
Tests passed    :    0 (  0.0%) (  0.0%)
Time taken      :    4 seconds
FAILED TEST SUMMARY
You may have found a problem in PHP.
We would like to send this report automatically to the
PHP QA team, to give us a better understanding of how
the test cases are doing. If you don't want to send it
immediately, you can choose "s" to save the report to
a file that you can send us later.
Do you want to send this report now? [Yns]:
Please enter your email address.
(Your address will be mangled so that it will not go out on any
mailinglist in plain text):
Posting to qa.php.net /buildtest-process.php
Thank you for helping to make PHP better.
[root@sky sockets]# make install
Installing shared extensions:     /www/wdlinux/php/lib/php/extensions/no-debug-non-zts-20060613/
[root@sky sockets]# ll /www/wdlinux/php/lib/php/extensions/no-debug-non-zts-20060613
lrwxrwxrwx 1 root root 57 Jun 20 17:24 /www/wdlinux/php/lib/php/extensions/no-debug-non-zts-20060613 -> /www/wdlinux/php/lib/php/extensions/no-debug-zts-20060613
[root@sky sockets]# vim /www/wdlinux/wdcp/php
phpdb/      phpmyadmin/
phpdb/      phpmyadmin/
[root@sky sockets]# vim /www/wdlinux/wdcp/l
left.php     license.txt  login.php
[root@sky sockets]# find / -name php.ini
/www/wdlinux/etc/php.ini
/www/wdlinux/Zend/etc/php.ini
/www/wdlinux/wdphp/lib/php.ini
/www/wdlinux/wdcp_bk/conf/php.ini
[root@sky sockets]# /usr/local/php5/bin/php -v
-bash: /usr/local/php5/bin/php: No such file or directory
[root@sky sockets]# /www/wdlinux/php/bin/php -v
PHP 5.2.17p1 (cli) (built: Jul  5 2012 16:44:35)
Copyright (c) 1997-2010 The PHP Group
Zend Engine v2.2.0, Copyright (c) 1998-2010 Zend Technologies
[root@sky sockets]# /www/wdlinux/php/bin/php -m
[PHP Modules]
bcmath
bz2
ctype
curl
date
dom
filter
ftp
gd
gettext
hash
iconv
json
libxml
mbstring
mcrypt
mhash
mysql
mysqli
openssl
pcre
PDO
pdo_sqlite
posix
Reflection
session
SimpleXML
soap
sockets
SPL
SQLite
standard
tokenizer
xml
xmlreader
xmlwriter
zip
zlib
[Zend Modules]
[root@sky sockets]# service nginxd restart
done
[root@sky sockets]#
顯示是支持了,但就是不行,還報(bào)錯(cuò)Starting php_fpm PHP Warning:  PHP Startup: Unable to load dynamic library '/www/wdlinux/wdphp/lib/php/extensions/no-debug-non-zts-20060613/sockets.so' - /www/wdlinux/wdphp/lib/php/extensions/no-debug-non-zts-20060613/sockets.so: cannot open shared object file: No such file or directory in Unknown on line 0
就修改php.ini,其他地方?jīng)]有做修改,有沒有人幫忙
目錄是這個(gè)
而不是
在這里找到解決方法了,但不夠詳細(xì)。。   現(xiàn)在 DX后臺可以使用 SOCKET 連接SMTP發(fā)信,,并成功了。
過下寫個(gè)步驟來。
你可以整理一個(gè)出來
