如果是lnmp版的環(huán)境,則使用下面這個試試(針對默認的php-5.2.17版本)
wget http://down.wdlinux.cn/in/lnmp_php_ssl_5217.sh
sh lnmp_php_ssl_5217.sh
我用的lnmp環(huán)境,安裝后,QQ登錄還是502
ye1028
安裝過程
Build complete.
Installing PHP SAPI module:       cgi
Installing PHP CGI binary: /www/wdlinux/nginx_php-5.2.17/bin/
Installing FPM config:            /www/wdlinux/etc/php-fpm.conf
                                  (installing as php-fpm.conf.default)
Installing init.d script:         /www/wdlinux/nginx_php-5.2.17/sbin/php-fpm
Installing PHP CLI binary:        /www/wdlinux/nginx_php-5.2.17/bin/
Installing PHP CLI man page:      /www/wdlinux/nginx_php-5.2.17/man/man1/
Installing build environment:     /www/wdlinux/nginx_php-5.2.17/lib/php/build/
Installing header files:          /www/wdlinux/nginx_php-5.2.17/include/php/
Installing helper programs:       /www/wdlinux/nginx_php-5.2.17/bin/
  program: phpize
  program: php-config
Installing man pages:             /www/wdlinux/nginx_php-5.2.17/man/man1/
  page: phpize.1
  page: php-config.1
Installing PEAR environment:      /www/wdlinux/nginx_php-5.2.17/lib/php/
[PEAR] Archive_Tar    - already installed: 1.3.7
[PEAR] Console_Getopt - already installed: 1.2.3
[PEAR] Structures_Graph- already installed: 1.0.3
[PEAR] XML_Util       - already installed: 1.2.1
[PEAR] PEAR           - already installed: 1.9.1
Wrote PEAR system config file at: /www/wdlinux/nginx_php-5.2.17/etc/pear.conf
You may want to add: /www/wdlinux/nginx_php-5.2.17/lib/php to your php.ini include_path
Installing PDO headers:          /www/wdlinux/nginx_php-5.2.17/include/php/ext/pdo/
Shutting down php_fpm . done
Starting php_fpm  done
php reinstall is OK
ye1028
老大啊    終于找到這個問題了  我找了好幾天了啊
先占位置
make[2]: Leaving directory `/tmp/httpd-2.2.22/modules/mappers'
make[2]: Entering directory `/tmp/httpd-2.2.22/modules'
make[2]: Leaving directory `/tmp/httpd-2.2.22/modules'
make[1]: Leaving directory `/tmp/httpd-2.2.22/modules'
Making install in support
make[1]: Entering directory `/tmp/httpd-2.2.22/support'
make[2]: Entering directory `/tmp/httpd-2.2.22/support'
make[2]: Leaving directory `/tmp/httpd-2.2.22/support'
make[1]: Leaving directory `/tmp/httpd-2.2.22/support'
make[1]: Entering directory `/tmp/httpd-2.2.22'
Installing configuration files
[PRESERVING EXISTING HTDOCS SUBDIR: /www/wdlinux/httpd-2.2.22/htdocs]
[PRESERVING EXISTING ERROR SUBDIR: /www/wdlinux/httpd-2.2.22/error]
[PRESERVING EXISTING ICONS SUBDIR: /www/wdlinux/httpd-2.2.22/icons]
[PRESERVING EXISTING CGI SUBDIR: /www/wdlinux/httpd-2.2.22/cgi-bin]
Installing build system files
Installing man pages and online manual
make[1]: Leaving directory `/tmp/httpd-2.2.22'
Starting httpd:                                            [  OK  ]
httpd ssl install is OK
已經安裝  但是不知道可以不?
回復 1# admin
老大 我安裝好了
但是怎么無法聯機數據庫啊
我哭了 ······················
數據庫沒啟動?
回復 77# ye1028
   我也遇到這問題,一摸一樣,你解決了么?
ndsq.cn
回復 73# admin
你好,腳本里修改成2.2.24 具體是怎么操作,我們這種小白確實頭痛。安裝的2.2.22 沒有解決問題。安裝后登錄QQ互聯提示網絡連接失敗。
QQ截圖20140227154058.png 回復 1# admin
APACHE 已經支持SSL了為什么還是QQ登陸502啊
現在也遇到這樣的問題了,不知道怎么解決啊
求助:
安裝httpd,改成2.2.24版本,make install 過程中提示報錯
錯誤信息如下
  1. libtool: install: error: cannot install `libaprutil-1.la' to a directory not ending in /www/wdlinux/wdapache/lib
  2. make[2]: *** [install] 錯誤 1
  3. make[2]: Leaving directory `/root/download/lanmp/httpd-2.2.24/srclib/apr-util'
  4. make[1]: *** [install-recursive] 錯誤 1
  5. make[1]: Leaving directory `/root/download/lanmp/httpd-2.2.24/srclib'
  6. make: *** [install-recursive] 錯誤 1
老大,我這里是這種錯誤啊 折騰了幾天了。還是出現這個錯誤。
httpd-2.2.22/httpd.spec
httpd-2.2.22/configure
httpd-2.2.22/libhttpd.dep
httpd-2.2.22/configure.in
httpd-2.2.22/VERSIONING
httpd-2.2.22/README
httpd-2.2.22/LAYOUT
httpd-2.2.22/buildconf
httpd-2.2.22/.gdbinit
http2222_ssl.sh: line 24: ./configure: Permission denied
24行:./configure --prefix=$IN_DIR/httpd-2.2.22 --enable-rewrite --enable-deflate --disable-userdir --enable-so --enable-expires --enable-headers --with-included-apr --with-apr=/usr --with-apr-util=/usr --enable-ssl --with-ssl=/usr
應該如何操作啊 。。。。
小弟在此謝過了
w
我是root用戶登錄的。
應該對那些文件/或者文件夾操作 ???
w
我解決了問題,重新編譯curl和php就好了
回復 89# zyf8985957
   怎么重新編譯呢
