rar壓縮文件是在windows用得最多的一個壓縮文件或格式
有時,也會用在Linux下,但Linux下默認(rèn)是不支持這個格式的
對zip的格式,倒還是可以支持的
所以,一般都可以在win用壓縮成zip,然后在linux下就可以用了
對于一定要用到rar的,還是可以的
只要安裝個rar軟件就可以
rar的linux官網(wǎng),可以看這里
http://www.rarlab.com/download.htm
可以下載最新版的,不過據(jù)我測試的,最新版要球gblic是2.7以上的
但在CentOS 5.X系統(tǒng)里,是2.5的,所以不用下最新版的
以wdOS 1.0為例,wdOS 1.0是基于CentOS 5.8的
只能用較低的版本,如下
wget http://www.rarlab.com/rar/rarlinux-3.6.0.tar.gz
tar zxvf rarlinux-3.6.0.tar.gz
cd rar
這樣就完成了
然后就可以解壓了
運(yùn)行
rar x file.rar
這樣就完了
x是參數(shù)
file.rar是相應(yīng)的文件
更多的功能和參數(shù),可看
RAR 3.60 Copyright (c) 1993-2006 Alexander Roshal 5 Aug 2006
Shareware version Type RAR -? for help
Usage: rar <command> -<switch 1> -<switch N> <archive> <files...>
<@listfiles...> <path_to_extract\>
<Commands>
a Add files to archive
c Add archive comment
cf Add files comment
ch Change archive parameters
cw Write archive comment to file
d Delete files from archive
e Extract files to current directory
f Freshen files in archive
i[par]=<str> Find string in archives
k Lock archive
l[t,b] List archive [technical, bare]
m[f] Move to archive [files only]
p Print file to stdout
r Repair archive
rc Reconstruct missing volumes
rn Rename archived files
rr[N] Add data recovery record
rv[N] Create recovery volumes
s[name|-] Convert archive to or from SFX
t Test archive files
u Update files in archive
v[t,b] Verbosely list archive [technical,bare]
x Extract files with full path
<Switches>
- Stop switches scanning
ad Append archive name to destination path
ag[format] Generate archive name using the current date
ap<path> Set path inside archive
as Synchronize archive contents
av Put authenticity verification (registered versions only)
av- Disable authenticity verification check
c- Disable comments show
cfg- Disable read configuration
cl Convert names to lower case
cu Convert names to upper case
df Delete files after archiving
dh Open shared files
ds Disable name sort for solid archive
e[+]<attr> Set file exclude and include attributes
ed Do not add empty directories
en Do not put 'end of archive' block
ep Exclude paths from names
ep1 Exclude base directory from names
ep3 Expand paths to full including the drive letter
f Freshen files
fcu[file] Read archive comment from Unicode file
hp[password] Encrypt both file data and headers
id[c,d,p,q] Disable messages
ierr Send all messages to stderr
ilog[name] Log errors to file (registered versions only)
inul Disable all messages
isnd Enable sound
k Lock archive
kb Keep broken extracted files
m<0..5> Set compression level (0-store...3-default...5-maximal)
mc<par> Set advanced compression parameters
md<size> Dictionary size in KB (64,128,256,512,1024,2048,4096 or A-G)
ms[ext;ext] Specify file types to store
n<file> Include only specified file
n@ Read file names to include from stdin
n@<list> Include files in specified list file
o+ Overwrite existing files
o- Do not overwrite existing files
ol Save symbolic links as the link instead of the file
or Rename files automatically
ow Save or restore file owner and group
p[password] Set password
p- Do not query password
r Recurse subdirectories
r0 Recurse subdirectories for wildcard names only
s[<N>,v[-],e] Create solid archive
s- Disable solid archiving
sfx[name] Create SFX archive
si[name] Read data from standard input (stdin)
sl<size> Process files with size less than specified
sm<size> Process files with size more than specified
t Test files after archiving
ta<date> Process files modified after <date> in YYYYMMDDHHMMSS format
tb<date> Process files modified before <date> in YYYYMMDDHHMMSS format
tk Keep original archive time
tl Set archive time to latest file
tn<time> Process files newer than <time>
to<time> Process files older than <time>
ts<m,c,a>[N] Save or restore file time (modification, creation, access)
u Update files
v Create volumes with size autodetection or list all volumes
v<size>[k,b] Create volumes with size=<size>*1000 [*1024, *1]
ver[n] File version control
vn Use the old style volume naming scheme
vp Pause before each volume
w<path> Assign work directory
x<file> Exclude specified file
x@ Read file names to exclude from stdin
x@<list> Exclude files in specified list file
y Assume Yes on all queries
z[file] Read archive comment from file
轉(zhuǎn)載請注明:wdlinux知識庫 原文連接:http://www.szkyjg.com/bbs/thread-3805-1-1.html
