[求助] 2.4快速安裝有問題,在php中,抓取https的網(wǎng)站,會(huì)出現(xiàn)錯(cuò)誤:
Warning: file_get_contents(https://localhost/myphp/a.asp) [function.file-get-contents]: failed to open stream: Invalid argument in I:\Web\myphp\a.php on line 16
求解決辦法
不帥你找我
執(zhí)行下這個(gè)試試
http://www.szkyjg.com/bbs/thread-3657-1-1.html
還是不行老大?
不帥你找我
lnmpa 測(cè)試64位不過。
執(zhí)行了lnmp_php_ssl_5217.sh腳本,沒有完成。
在進(jìn)行PHP編譯的過程中,出現(xiàn)了這個(gè)問題:
Configuring extensions
checking size of long... (cached) 8
checking for int32_t... yes
checking for uint32_t... yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking for strtoll... yes
checking for atoll... yes
checking for strftime... (cached) yes
checking whether to enable LIBXML support... yes
checking libxml2 install dir... /usr
checking for xml2-config path... /usr/bin/xml2-config
checking whether libxml build works... yes
checking for OpenSSL support... yes
checking for Kerberos support... no
checking for DSA_get_default_method in -lssl... yes
checking for pkg-config... /usr/bin/pkg-config
checking for OpenSSL version... >= 0.9.6
checking for CRYPTO_free in -lcrypto... yes
checking for SSL_CTX_set_ssl_version in -lssl... yes
checking for PCRE support... yes
checking for ZLIB support... yes
checking if the location of ZLIB install directory is defined... no
checking for gzgets in -lz... yes
checking whether to enable bc style precision math functions... no
checking for BZip2 support... no
checking whether to enable calendar conversion support... no
checking whether to enable ctype functions... yes
checking for cURL support... yes
checking if we should use cURL for url streams... no
checking for cURL in default path... found in /usr
checking for cURL 7.10.5 or greater... libcurl 7.19.7
checking for SSL support in libcurl... yes
checking how to run the C preprocessor... gcc -E
checking for openssl support in libcurl... no
checking for gnutls support in libcurl... no
checking for curl_easy_perform in -lcurl... yes
checking for curl_version_info in -lcurl... yes
checking for curl_easy_strerror in -lcurl... yes
checking for curl_multi_strerror in -lcurl... yes
checking for QDBM support... no
checking for GDBM support... no
checking for NDBM support... no
checking for Berkeley DB4 support... no
checking for Berkeley DB3 support... no
checking for Berkeley DB2 support... no
checking for DB1 support... no
checking for DBM support... no
checking for CDB support... no
checking for INI File support... no
checking for FlatFile support... no
checking whether to enable DBA interface... no
checking whether to enable dbase support... no
checking whether to enable DOM support... yes
checking for xml2-config path... (cached) /usr/bin/xml2-config
checking whether libxml build works... (cached) yes
checking whether to enable EXIF (metadata from images) support... no
checking for FrontBase SQL92 (fbsql) support... no
checking for FDF support... no
checking whether to enable input filter support... yes
checking pcre install prefix... no
checking whether to enable FTP support... yes
checking OpenSSL dir for FTP... no
checking for CRYPTO_free in -lcrypto... (cached) yes
checking for SSL_CTX_set_ssl_version in -lssl... (cached) yes
checking for GD support... yes
checking for the location of libjpeg... yes
checking for the location of libpng... yes
checking for the location of libXpm... no
checking for FreeType 1.x support... no
checking for FreeType 2... yes
checking for T1lib support... no
checking whether to enable truetype string function in GD... yes
checking whether to enable JIS-mapped Japanese font support in GD... no
checking for fabsf... yes
checking for floorf... yes
configure: error: libjpeg.(a|so) not found.
手工yum安裝libjpeg
Setting up Install Process
Package libjpeg-turbo-1.2.1-3.el6_5.x86_64 already installed and latest version
Nothing to do
環(huán)境:
lnamp 當(dāng)前版本: wdcp_v2.5.9(20131108)
Linux CentOS 6.4 64bit
看看哪位老大支持一下,不勝感激!
1. cp  -frp /usr/lib64/libjpeg.* /usr/lib/   #configure:error:libjpeg.(a|so) not found 報(bào)錯(cuò)搞定
2. 注意過程中還會(huì)提示" Configure: error: libpng.(also) not found."錯(cuò)誤,解決辦法和上面的一樣.
    cp -frp /usr/lib64/libpng* /usr/lib/
編譯通過,PHP reinstall ok,不過curl 還是沒有成功支持 https,不知道為什么。
Build complete.
Installing PHP SAPI module:       cgi
Installing PHP CGI binary: /www/wdlinux/nginx_php-5.2.17/bin/
Installing FPM config:            /www/wdlinux/etc/php-fpm.conf
                                  (installing as php-fpm.conf.default)
Installing init.d script:         /www/wdlinux/nginx_php-5.2.17/sbin/php-fpm
Installing PHP CLI binary:        /www/wdlinux/nginx_php-5.2.17/bin/
Installing PHP CLI man page:      /www/wdlinux/nginx_php-5.2.17/man/man1/
Installing build environment:     /www/wdlinux/nginx_php-5.2.17/lib/php/build/
Installing header files:          /www/wdlinux/nginx_php-5.2.17/include/php/
Installing helper programs:       /www/wdlinux/nginx_php-5.2.17/bin/
  program: phpize
  program: php-config
Installing man pages:             /www/wdlinux/nginx_php-5.2.17/man/man1/
  page: phpize.1
  page: php-config.1
Installing PEAR environment:      /www/wdlinux/nginx_php-5.2.17/lib/php/
[PEAR] Archive_Tar    - already installed: 1.3.7
[PEAR] Console_Getopt - already installed: 1.2.3
[PEAR] Structures_Graph- already installed: 1.0.3
[PEAR] XML_Util       - already installed: 1.2.1
[PEAR] PEAR           - already installed: 1.9.1
Wrote PEAR system config file at: /www/wdlinux/nginx_php-5.2.17/etc/pear.conf
You may want to add: /www/wdlinux/nginx_php-5.2.17/lib/php to your php.ini include_path
Installing PDO headers:          /www/wdlinux/nginx_php-5.2.17/include/php/ext/pdo/
php-fpm: unrecognized service
php reinstall is OK
