[求助] mysql升級到5.5報錯了
本帖最后由 qq682907 于 2013-2-28 23:37 編輯
wget http://down.wdlinux.cn/in/mysql_up55.sh
sh mysql_up55.sh我是按著這個升級的 是面板安裝好后
升級的
詳細(xì)的錯誤日志
130228 23:33:43 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
130228 23:33:43 [Note]   - '0.0.0.0' resolves to '0.0.0.0';
130228 23:33:43 [Note] Server socket created on IP: '0.0.0.0'.
130228 23:33:43 [ERROR] Fatal error: Can't open and lock privilege tables: Table 'mysql.host' doesn't exist
130228 23:33:43 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.5.27/data/MyVPS1970.pid ended
你這個是新下載安裝的嗎?
怎么還是/www/wdlinux/mysql-5.5.27/data目錄,應(yīng)該是
/www/wdlinux/mysql-5.5.27/var
這個才對的
   我自己用論壇里腳本升級的
sh mysql_up55.sh
是這個腳本
我把里面的參數(shù) 復(fù)制出來給你看
#!/bin/bash
IN_DIR="/www/wdlinux"
MYS_VER="5.5.27"
if [ ! -f mysql-${MYS_VER}.tar.gz ];then
wget -c http://dl.wdlinux.cn:5180/soft/mysql-${MYS_VER}.tar.gz
fi
yum install -y cmake
tar zxvf mysql-${MYS_VER}.tar.gz
cd mysql-${MYS_VER}
cmake -DCMAKE_INSTALL_PREFIX=$IN_DIR/mysql-$MYS_VER -DSYSCONFDIR=$IN_DIR/etc -DWITH_INNOBASE_STORAGE_ENGINE=1 -DWITH_SSL=no -DWITH_DEBUG=OFF -DWITH_EXTRA_CHARSETS=complex -DENABLED_PROFILING=ON -DWITH_MYISAM_STORAGE_ENGINE=1 -DWITH_MEMORY_STORAGE_ENGINE=1
[ $? != 0 ] && echo "configure err" && exit
[ $? != 0 ] && echo "make err" && exit
[ $? != 0 ] && echo "make install err" && exit
service mysqld stop
if [ ! -d /www/wdlinux/mysql_bk ];then
mkdir -p /www/wdlinux/mysql_bk
cp -pR /www/wdlinux/mysql/var/* /www/wdlinux/mysql_bk
fi
rm -f /www/wdlinux/mysql
ln -sf $IN_DIR/mysql-$MYS_VER /www/wdlinux/mysql
sh scripts/mysql_install_db.sh --user=mysql --basedir=/www/wdlinux/mysql --datadir=/www/wdlinux/mysql/var
chown -R mysql.mysql /www/wdlinux/mysql/var
mv /www/wdlinux/mysql/var/mysql /www/wdlinux/mysql/var/mysqlo
cp -pR /www/wdlinux/mysql_bk/* /www/wdlinux/mysql/var/
cp support-files/mysql.server /www/wdlinux/init.d/mysqld
chmod 755 /www/wdlinux/init.d/mysqld
service mysqld restart
echo
if [ -d /www/wdlinux/mysql-5.1.63 ];then
ln -sf /www/wdlinux/mysql-5.1.63/lib/mysql/libmysqlclient.so.16* /usr/lib/
fi
sleep 2
sh /www/wdlinux/tools/mysql_wdcp_chg.sh
echo
echo "mysql update is OK"
之前是安裝的哪個,升級的?
回復(fù) 5# admin
   mysql-5.1.63 一鍵安裝包 安裝下來的mysql 然后就直接升級了
回復(fù) 6# qq682907
   管理 報錯了
PM IP,密碼來看看
回復(fù) 8# admin
   已經(jīng)發(fā)了 外出了3小時 剛剛回來
這個怎么解決 我也一樣的
求解決辦法?
難得糊涂
檢查mysql是否啟動,或不能啟動的原因,看下日志
錯誤日志如下,請教如何解決?
130402 20:03:37 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.5.27/data
/www/wdlinux/mysql-5.5.27/bin/mysqld: Table 'mysql.plugin' doesn't exist
130402 20:03:37 [ERROR] Can't open the mysql.plugin table. Please run mysql_upgrade to create it.
130402 20:03:38 InnoDB: The InnoDB memory heap is disabled
130402 20:03:38 InnoDB: Mutexes and rw_locks use GCC atomic builtins
130402 20:03:38 InnoDB: Compressed tables use zlib 1.2.3
130402 20:03:38 InnoDB: Initializing buffer pool, size = 128.0M
130402 20:03:38 InnoDB: Completed initialization of buffer pool
130402 20:03:38  InnoDB: Operating system error number 13 in a file operation.
InnoDB: The error means mysqld does not have the access rights to
InnoDB: the directory.
InnoDB: File name ./ibdata1
InnoDB: File operation call: 'create'.
InnoDB: Cannot continue operation.
130402 20:03:38 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.5.27/data/li260-147.pid ended
難得糊涂
回復(fù) 13# zd305
   沒升級成功
本帖最后由 qq514408389 于 2013-4-3 11:59 編輯
回復(fù) 14# qq682907
    可以修改下/www/wdlinux/init.d/mysqld這個文件
    里面這兩行basedir=
                  datadir=
    修改如下
    然后再重新試試
