[求助] 請(qǐng)問這個(gè)問題怎么解決?
/root/src/mysql-5.5.49/sql-common/client_plugin.c: 在函數(shù)‘mysql_client_plugin_init’中:
/root/src/mysql-5.5.49/sql-common/client_plugin.c:252:5: 錯(cuò)誤:‘a(chǎn)dd_plugin’的第 5 個(gè)實(shí)參類型不兼容
     add_plugin(&mysql, *builtin, 0, 0, 0);
/root/src/mysql-5.5.49/sql-common/client_plugin.c:120:1: 附注:需要類型‘va_list’,但實(shí)參的類型為‘int’
add_plugin(MYSQL *mysql, struct st_mysql_client_plugin *plugin, void *dlhandle,
/root/src/mysql-5.5.49/sql-common/client_plugin.c: 在函數(shù)‘mysql_client_register_plugin’中:
/root/src/mysql-5.5.49/sql-common/client_plugin.c:310:5: 錯(cuò)誤:‘a(chǎn)dd_plugin’的第 5 個(gè)實(shí)參類型不兼容
     plugin= add_plugin(mysql, plugin, 0, 0, 0);
make[2]: *** [libmysqld/CMakeFiles/sql_embedded.dir/__/sql-common/client_plugin.c.o] 錯(cuò)誤 1
make[2]: *** 正在等待未完成的任務(wù)....
Linking CXX static library libpartition_embedded.a
[ 69%] Built target partition_embedded
make[1]: *** [libmysqld/CMakeFiles/sql_embedded.dir/all] 錯(cuò)誤 2
make: *** [all] 錯(cuò)誤 2
armv7l
Derived from Red Hat Enterprise Linux 7.2 (Source)
----Install Error: mysql make err -----------
我的環(huán)境是樹莓派+CentOS7 架設(shè)的環(huán)境.請(qǐng)高手解答!
換個(gè)版本試試看
您指的是系統(tǒng)版本還是一鍵版本?
