[求助] 云主機硬盤劃分問題
[root@CentOS ~]# fdisk -l
Disk /dev/xvda: 10.7 GB, 10737418240 bytes
255 heads, 63 sectors/track, 1305 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x0000aba6
    Device Boot      Start         End      Blocks   Id  System
/dev/xvda1   *           1          64      512000   83  Linux
Partition 1 does not end on cylinder boundary.
/dev/xvda2              64        1306     9972736   8e  Linux LVM
Disk /dev/xvdb: 150.3 GB, 150323855360 bytes
255 heads, 63 sectors/track, 18275 cylinders
Disk identifier: 0x000d68a3
/dev/xvdb1               1       18275   146793906   83  Linux
Disk /dev/mapper/vg_501153278-lv_root: 9135 MB, 9135194112 bytes
255 heads, 63 sectors/track, 1110 cylinders
Disk identifier: 0x00000000
Disk /dev/mapper/vg_501153278-lv_root doesn't contain a valid partition table
Disk /dev/mapper/vg_501153278-lv_swap: 1073 MB, 1073741824 bytes
255 heads, 63 sectors/track, 130 cylinders
求各位賜教如何把未分配的空間,分配到主分區(qū)!
萬謝!
把 /dev/xvdb1 加載成 /www就可以
具體可以參考相關(guān)文章
謝謝管理員!我是新手,能不能麻煩你幫我把命令寫一下!
非常感謝!
我也遇到同樣的問題,求解,請看圖片
