剛剛試了下,卸載云鎖以后,重啟一下服務(wù)器,后臺界面上就出現(xiàn)重新安裝的提示了。
我操作流程是這樣的:
現(xiàn)在后臺首頁點擊卸載云鎖,等了很久,刷新以后仍然顯示卸載云鎖這個鏈接。
然后遠(yuǎn)程命令卸載云鎖,刷新后臺首頁,仍然顯示卸載云鎖這個鏈接。
重啟服務(wù)器,進(jìn)入后臺首頁,顯示安裝云鎖鏈接,
遠(yuǎn)程再輸入卸載云鎖的命令,顯示沒有此程序。
所以卸載完之后重啟一下試試,本人剛接觸這個軟件,還不太熟悉,方法也許比較笨。
我的云鎖也沒辦法卸載
命令卸載后還是顯示保護(hù)中,重新安裝的時候提示已經(jīng)安裝了
為什么無法卸載云鎖呢?
本帖最后由 johdan 于 2017-9-7 14:46 編輯
[root@hostname ~]# /usr/local/yunsuo_agent/uninstall
Are you sure to uninstall?(y/n)
Are you sure to uninstall?(y/n)y
ERROR: stop software failed
rm: cannot remove `/usr/local/lib/jlibs': Permission denied
rm: cannot remove `/usr/local/yunsuo_agent/sec_policy/ip_blacklist.pol': Permission denied
rm: cannot remove `/usr/local/yunsuo_agent/sec_policy/asve.pol': Permission denied
rm: cannot remove `/usr/local/yunsuo_agent/dump': Permission denied
rm: cannot remove `/usr/local/yunsuo_agent/template': Permission denied
rm: cannot remove `/usr/local/yunsuo_agent/libs/libnetiostream_asynch_ar_linux.so': Permission denied
rm: cannot remove `/usr/local/yunsuo_agent/libs/libdefault_rules_linux.so': Permission denied
rm: cannot remove `/usr/local/yunsuo_agent/libs/libasynch_rpc_linux.so': Permission denied
rm: cannot remove `/usr/local/yunsuo_agent/libs/libicuuc.so.48': Permission denied
rm: cannot remove `/usr/local/yunsuo_agent/libs/libfile_transfer_linux.so': Permission denied
rm: cannot remove `/usr/local/yunsuo_agent/libs/libipfilter_linux.so': Permission denied
rm: cannot remove `/usr/local/yunsuo_agent/libs/libcloud_center_linux.so': Permission denied
rm: cannot remove `/usr/local/yunsuo_agent/tool/tar': Permission denied
rm: cannot remove `/usr/local/yunsuo_agent/tool/patch_md5': Permission denied
rm: cannot remove `/usr/local/yunsuo_agent/tool/file': Permission denied
rm: cannot remove `/usr/local/yunsuo_agent/jspAgent/JSPAgent.jar': Permission denied
rm: cannot remove `/usr/local/yunsuo_agent/jspAgent/liblitexml_linux.so': Permission denied
Uninstall Success.
ewrwerwer
我的就是上面的情況,卸載不了,安裝不了,導(dǎo)致我程序出現(xiàn)一些異常問題。
ewrwerwer
最主要遠(yuǎn)程連接云鎖也是失敗的。。。。
ewrwerwer
這個問題到現(xiàn)在也沒有解決啊,這云鎖是真坑人啊,
987影音
我的也解決不了啊,暈了,不小心點了一下安裝,現(xiàn)在服務(wù)器全都出錯。
怎么卸載都卸載不了,既然這樣能不能不要放在后臺啊,一不小心碰到了就安裝上了。
