[求助] 安裝出現(xiàn) Install Error:mysql configure err 修復(fù)無(wú)果
參照此貼 http://www.szkyjg.com/bbs/viewthread.php?tid=2460&highlight=Install%2BError%3A%2Bmysql%2Bconfigure%2Berr
出現(xiàn)以下提示
求助 。
  1. ubuntu@ip-172-31-17-12:~$ yum install -y gcc gcc-c++ make autoconf libtool-ltdl-devel gd-devel freetype-devel libxml2-devel libjpeg-devel libpng-devel openssl-devel curl-devel patch libmcrypt-devel libmhash-devel ncurses-devel sudo bzip2
  2. The program 'yum' is currently not installed. You can install it by typing:
  3. sudo apt-get install yum
  4. ubuntu@ip-172-31-17-12:~$ sudo apt-get install yum
  5. Reading package lists... Done
  6. Building dependency tree
  7. Reading state information... Done
  8. The following extra packages will be installed:
  9.   libcap2 liblua5.1-0 libnspr4 libnss3 librpm3 librpmbuild3 librpmio3
  10.   librpmsign1 libsqlite0 libxml2 python-libxml2 python-rpm python-sqlite
  11.   python-sqlitecachec python-support python-urlgrabber rpm rpm-common rpm2cpio
  12.   sgml-base xml-core
  13. Suggested packages:
  14.   python-sqlite-dbg alien elfutils rpm-i18n sgml-base-doc debhelper
  15. The following NEW packages will be installed:
  16.   libcap2 liblua5.1-0 libnspr4 libnss3 librpm3 librpmbuild3 librpmio3
  17.   librpmsign1 libsqlite0 libxml2 python-libxml2 python-rpm python-sqlite
  18.   python-sqlitecachec python-support python-urlgrabber rpm rpm-common rpm2cpio
  19.   sgml-base xml-core yum
  20. 0 upgraded, 22 newly installed, 0 to remove and 0 not upgraded.
  21. Need to get 852 kB/3,754 kB of archives.
  22. After this operation, 11.7 MB of additional disk space will be used.
  23. Do you want to continue [Y/n]? y
  24. Err http://ap-northeast-1.ec2.archive.ubuntu.com/ubuntu/ quantal-updates/main libxml2 i386 2.8.0+dfsg1-5ubuntu2.1
  25.   403  Forbidden
  26. Err http://security.ubuntu.com/ubuntu/ quantal-security/main libxml2 i386 2.8.0+dfsg1-5ubuntu2.1
  27.   404  Not Found [IP: 91.189.92.201 80]
  28. Err http://security.ubuntu.com/ubuntu/ quantal-security/main python-libxml2 i386 2.8.0+dfsg1-5ubuntu2.1
  29.   404  Not Found [IP: 91.189.92.201 80]
  30. Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/libx/libxml2/libxml2_2.8.0+dfsg1-5ubuntu2.1_i386.deb  404  Not Found [IP: 91.189.92.201 80]
  31. Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/libx/libxml2/python-libxml2_2.8.0+dfsg1-5ubuntu2.1_i386.deb  404  Not Found [IP: 91.189.92.201 80]
  32. E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
  33. ubuntu@ip-172-31-17-12:~$
ubuntu 是不是一些包沒裝。。像yum  gcc  這樣的?
ubuntu就不要用yum來(lái)更新了,直接用 apt-get 就可以
