[求助] 安裝完成后空白頁面和無響應(yīng)
本帖最后由 zd繁華落幕 于 2017-8-3 22:50 編輯
采用RPM包安裝。
對于Linux是一臉懵逼,當(dāng)然英文也是。(╯°Д°)╯︵┻━┻
所以來請教各位神
安裝完成了
然后輸入ip試試
之前是這種情況這樣的包括安裝AMH也是這樣響應(yīng)超時
防火墻狀態(tài)
列出的端口
個人覺得應(yīng)該是端口的問題但是壓根不知道怎么解決所以請各位給點辦法吧
[root@zdrcro ~]# service wdapache restart
Redirecting to /bin/systemctl restart  wdapache.service
Failed to restart wdapache.service: Unit not found.
無法重啟wdcp
[root@zdrcro ~]# netstat -ntlp
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      7337/mysqld
tcp        0      0 127.0.0.1:11211         0.0.0.0:*               LISTEN      7420/memcached
tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      30591/redis-server
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      7387/httpd
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      720/sshd
tcp6       0      0 :::8080                 :::*                    LISTEN      7455/wdcp
tcp6       0      0 :::21                   :::*                    LISTEN      725/vsftpd
這樣好像端口沒問題
[root@zdrcro ~]# ps 7455
  PID TTY      STAT   TIME COMMAND
7455 ?        Sl     0:00 /www/wdlinux/wdcp/wdcp
但是運行時間0,壓根沒有運行,然而重啟和啟動都沒有用。。。菜鳥的我到底誰來幫
[root@zdrcro ~]# systemctl stop firewalld.service
[root@zdrcro ~]# systemctl disable firewalld.service
[root@zdrcro ~]# firewall-cmd --state
not running
防火墻是關(guān)閉
COMMAND  PID USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
wdcp    7455 root    5u  IPv6 143460      0t0  TCP *:webcache (LISTEN)
網(wǎng)絡(luò)統(tǒng)計信息
Ip:
    162975 total packets received
    0 forwarded
    0 incoming packets discarded
    162975 incoming packets delivered
    88894 requests sent out
    85 dropped because of missing route
Icmp:
    0 ICMP messages received
    0 input ICMP message failed.
    ICMP input histogram:
    46 ICMP messages sent
    0 ICMP messages failed
    ICMP output histogram:
        destination unreachable: 44
        echo request: 2
IcmpMsg:
        OutType3: 44
        OutType8: 2
Tcp:
    72 active connections openings
    10 passive connection openings
    11 failed connection attempts
    6 connection resets received
    2 connections established
    161746 segments received
    88750 segments send out
    506 segments retransmited
    0 bad segments received.
    13 resets sent
Udp:
    1177 packets received
    45 packets to unknown port received.
    0 packet receive errors
    1407 packets sent
    0 receive buffer errors
    0 send buffer errors
UdpLite:
TcpExt:
    4 invalid SYN cookies received
    11 resets received for embryonic SYN_RECV sockets
    6 packets pruned from receive queue because of socket buffer overrun
    47 TCP sockets finished time wait in fast timer
    138 delayed acks sent
    Quick ack mode was activated 69 times
    3 packets directly queued to recvmsg prequeue.
    18288 bytes directly in process context from backlog
    2 bytes directly received in process context from prequeue
    142354 packet headers predicted
    13 packets header predicted and directly queued to user
    11535 acknowledgments not containing data payload received
    2428 predicted acknowledgments
    30 times recovered from packet loss by selective acknowledgements
    3 congestion windows recovered without slow start by DSACK
    1 congestion windows recovered without slow start after partial ack
    TCPLostRetransmit: 151
    465 fast retransmits
    4 forward retransmits
    9 retransmits in slow start
    9 other TCP timeouts
    TCPLossProbes: 21
    TCPLossProbeRecovery: 7
    1 SACK retransmits failed
    48 packets collapsed in receive queue due to low socket buffer
    70 DSACKs sent for old packets
    19 DSACKs received
    5 connections reset due to unexpected data
    TCPDSACKIgnoredNoUndo: 9
    TCPSackShifted: 56
    TCPSackMerged: 277
    TCPSackShiftFallback: 302
    TCPDeferAcceptDrop: 5
    TCPRcvCoalesce: 78812
    TCPOFOQueue: 195
    TCPWantZeroWindowAdv: 2
    TCPSynRetrans: 6
    TCPOrigDataSent: 25172
IpExt:
    InOctets: 220114146
    OutOctets: 12005864
    InNoECTPkts: 162973
    InECT0Pkts: 2
機房防火墻
回復(fù) 7# admin
    能麻煩在提醒一點嗎。。。太高深
回復(fù) 7# admin
    問題碰巧解決了,很感謝你的幫助
回復(fù) 7# admin
    能不能麻煩把我的帖子刪了
