[求助] SSL開啟強制使用,但并不跳轉(zhuǎn),是否原因如下:
wdCP版本為 v3.2.12。站點已經(jīng)成功上傳cert和key文件,并且設置強制開啟SSL,并且http和https均可以正常打開訪問站點,但是用http訪問的時候,并不會強制跳轉(zhuǎn)到https,請問是什么情況!目前是A+N引擎!強制開啟SSL后,發(fā)現(xiàn)nginx的conf文件并沒有什么變化,還是如下:
  1. server {
  2.         listen       80;
  3.         root /www/web/xxx_com/public_html;
  4.         server_name xxx.com www.xxx.com;
  5.         index  index.html index.php index.htm;
  6.         error_page  400 /errpage/400.html;
  7.         error_page  403 /errpage/403.html;
  8.         error_page  404 /errpage/404.html;
  9.         error_page  503 /errpage/503.html;
  10.         location ~ \.php$ {
  11.                 proxy_pass http://127.0.0.1:88;
  12.                 include naproxy.conf;
  13.         }
  14.         location ~ /\.ht {
  15.                 deny  all;
  16.         }
  17.         location / {
  18.                 try_files $uri @apache;
  19.         }
  20.         location @apache {
  21.                  internal;
  22.                  proxy_pass http://127.0.0.1:88;
  23.                  include naproxy.conf;
  24.         }
  25. }
另外,參照其他教程分別嘗試添加了如下代碼,添加后http和https均無法正常訪問:
代碼1:
  1. if ($server_port = 80) {
  2. return 301 https://$host$request_uri;
  3. }
代碼2:
  1.   listen 443 ssl;
  2.   ssl on;
  3.   ssl_certificate /www/wdlinux/nginx/conf/cert/xxx.com.cert;
  4.   ssl_certificate_key /www/wdlinux/nginx/conf/cert/xxx.com.key;
補充一句:我用了cloudflare的CND加速,是否和這個有關?
重裝了vps系統(tǒng)和wdcp,問題得以解決。conf文件有變化!可是新問題出現(xiàn),打開訪問 會存在重定向死循環(huán):
  1. server {
  2.         listen       80;
  5.         rewrite ^(.*)$  https://$host$1 permanent;
  6.         index  index.html index.php index.htm;
  7.         error_page  400 /errpage/400.html;
  8.         error_page  403 /errpage/403.html;
  9.         error_page  404 /errpage/404.html;
  10.         error_page  503 /errpage/503.html;
  11.         location ~ \.php$ {
  12.                 proxy_pass http://127.0.0.1:88;
  13.                 include naproxy.conf;
  14.         }
  15.         location ~ /\.ht {
  16.                 deny  all;
  17.         }
  18.         location / {
  19.                 try_files $uri @apache;
  20.         }
  21.         location @apache {
  22.                  internal;
  23.                  proxy_pass http://127.0.0.1:88;
  24.                  include naproxy.conf;
  25.         }
  26. }
  27. server {
  28.         listen       443;
  29.         root /www/web/xxx_com/public_html;
  30.         ssl                  on;
  31.         ssl_certificate      cert/xxx.crt;
  32.         ssl_certificate_key  cert/sxxx.key;
  33.         ssl_prefer_server_ciphers on;
  34.         ssl_session_timeout 10m;
  35.         ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
  36.         ssl_ciphers EECDH+CHACHA20:EECDH+AES128:RSA+AES128:EECDH+AES256:RSA+AES256:EECDH+3DES:RSA+3DES:!MD5;
  37.         server_name xxx.com www.xxx.com;
  38.         index  index.html index.php index.htm;
  39.         error_page  400 /errpage/400.html;
  40.         error_page  403 /errpage/403.html;
  41.         error_page  404 /errpage/404.html;
  42.         error_page  503 /errpage/503.html;
  43.         location ~ \.php$ {
  44.                 proxy_pass http://127.0.0.1:88;
  45.                 include naproxy.conf;
  46.         }
  47.         location ~ /\.ht {
  48.                     deny  all;
  49.             }
  50.         location / {
  51.                 try_files $uri @apache;
  52.         }
  53.         location @apache {
  54.                  internal;
  55.                  proxy_pass http://127.0.0.1:88;
  56.                  include naproxy.conf;
  57.         }
  58. }
  59.
另外,選擇https啟用(非強制啟用)一切正常,最奇怪的是,選擇不啟用,https依然可以正常訪問!
