[求助] 無法安裝mysqli
正在解析主機(jī) down.wdlinux.cn... 119.146.223.143
正在連接 down.wdlinux.cn|119.146.223.143|:80... 已連接。
已發(fā)出 HTTP 請求,正在等待回應(yīng)... 416 Requested Range Not Satisfiable
    文件已下載完成;不會進(jìn)行任何操作。
[root@123 ~]# chmod 755 mysqli_ins.sh
[root@123 ~]# ./mysqli_ins.sh
Configuring for:
PHP Api Version:         20041225
Zend Module Api No:      20060613
Zend Extension Api No:   220060519
checking for cc... cc
checking for icc... no
checking for suncc... no
checking for PHP prefix... /www/wdlinux/apache_php-5.2.17
checking for PHP includes... -I/www/wdlinux/apache_php-5.2.17/include/php -I/www        /wdlinux/apache_php-5.2.17/include/php/main -I/www/wdlinux/apache_php-5.2.17/inc        lude/php/TSRM -I/www/wdlinux/apache_php-5.2.17/include/php/Zend -I/www/wdlinux/a        pache_php-5.2.17/include/php/ext -I/www/wdlinux/apache_php-5.2.17/include/php/ex        t/date/lib
checking for PHP extension directory... /www/wdlinux/apache_php-5.2.17/lib/php/e        xtensions/no-debug-non-zts-20060613
checking for PHP installed headers prefix... /www/wdlinux/apache_php-5.2.17/incl        ude/php
checking if debug is enabled... no
checking if zts is enabled... no
checking for re2c... no
configure: WARNING: You will need re2c 0.13.4 or later if you want to regenerate        PHP parsers.
checking for gawk... gawk
checking for MySQLi support... yes, shared
checking whether to enable embedded MySQLi support... no
checking for mysql_set_server_option in -lmysqlclient... yes
checking for mysql_stmt_field_count in -lmysqlclient... yes
checking for ld used by cc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking how to recognize dependent libraries... pass_all
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking the maximum length of command line arguments... 1966080
checking command to parse /usr/bin/nm -B output from cc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if cc supports -fno-rtti -fno-exceptions... no
checking for cc option to produce PIC... -fPIC
checking if cc PIC flag -fPIC works... yes
checking if cc static flag -static works... no
checking if cc supports -c -o file.o... yes
checking whether the cc linker (/usr/bin/ld -m elf_x86_64) supports shared libra        ries... yes
checking whether -lc should be explicitly linked in... no
checking how to hardcode library paths into programs... immediate
checking whether to build shared libraries... yes
checking whether to build static libraries... no
creating libtool
config.status: creating config.h
/bin/sh /root/lanmp/php-5.2.17/ext/mysqli/libtool --mode=compile cc  -I. -I/root        /lanmp/php-5.2.17/ext/mysqli -DPHP_ATOM_INC -I/root/lanmp/php-5.2.17/ext/mysqli/        include -I/root/lanmp/php-5.2.17/ext/mysqli/main -I/root/lanmp/php-5.2.17/ext/my        sqli -I/www/wdlinux/apache_php-5.2.17/include/php -I/www/wdlinux/apache_php-5.2.        17/include/php/main -I/www/wdlinux/apache_php-5.2.17/include/php/TSRM -I/www/wdl        inux/apache_php-5.2.17/include/php/Zend -I/www/wdlinux/apache_php-5.2.17/include        /php/ext -I/www/wdlinux/apache_php-5.2.17/include/php/ext/date/lib -I/usr/includ        e/mysql  -DHAVE_CONFIG_H  -g -O2   -c /root/lanmp/php-5.2.17/ext/mysqli/mysqli.c        -o mysqli.lo
mkdir .libs
cc -I. -I/root/lanmp/php-5.2.17/ext/mysqli -DPHP_ATOM_INC -I/root/lanmp/php-5.2        .17/ext/mysqli/include -I/root/lanmp/php-5.2.17/ext/mysqli/main -I/root/lanmp/ph        p-5.2.17/ext/mysqli -I/www/wdlinux/apache_php-5.2.17/include/php -I/www/wdlinux/        apache_php-5.2.17/include/php/main -I/www/wdlinux/apache_php-5.2.17/include/php/        TSRM -I/www/wdlinux/apache_php-5.2.17/include/php/Zend -I/www/wdlinux/apache_php        -5.2.17/include/php/ext -I/www/wdlinux/apache_php-5.2.17/include/php/ext/date/li        b -I/usr/include/mysql -DHAVE_CONFIG_H -g -O2 -c /root/lanmp/php-5.2.17/ext/mysq        li/mysqli.c  -fPIC -DPIC -o .libs/mysqli.o
在包含自 /root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:31 的文件中:
/root/lanmp/php-5.2.17/ext/mysqli/php_mysqli.h:28:19: 錯誤:mysql.h:沒有那個文        件或目錄
/root/lanmp/php-5.2.17/ext/mysqli/php_mysqli.h:40:20: 錯誤:errmsg.h:沒有那個文        件或目錄
In file included from /root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:31:
/root/lanmp/php-5.2.17/ext/mysqli/php_mysqli.h:69: 錯誤:expected specifier-qual        ifier-list before ‘MYSQL_STMT’
/root/lanmp/php-5.2.17/ext/mysqli/php_mysqli.h:76: 錯誤:expected specifier-qual        ifier-list before ‘MYSQL’
/root/lanmp/php-5.2.17/ext/mysqli/php_mysqli.h:114: 錯誤:‘LOCAL_INFILE_ERROR_LE        N’未聲明(不在函數(shù)內(nèi))
/root/lanmp/php-5.2.17/ext/mysqli/php_mysqli.h:154: 錯誤:expected ‘)’ before ‘*        ’ token
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c: 在函數(shù)‘php_clear_stmt_bind’中:
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:110: 錯誤:‘MY_STMT’沒有名為‘stmt’的
成員
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:111: 錯誤:‘MY_STMT’沒有名為‘stmt’的        成員
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:114: 錯誤:‘MY_STMT’沒有名為‘param’的        成員
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:115: 錯誤:‘MY_STMT’沒有名為‘result’        的成員
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:117: 錯誤:‘MY_STMT’沒有名為‘query’的        成員
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:118: 錯誤:‘MY_STMT’沒有名為‘query’的        成員
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c: 在函數(shù)‘php_clear_mysql’中:
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:127: 錯誤:‘MY_MYSQL’沒有名為‘li_read        ’的成員
root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:128: 錯誤:‘MY_MYSQL’沒有名為‘li_read        ’的成員
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:129: 錯誤:‘MY_MYSQL’沒有名為‘li_read        ’的成員
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c: 在函數(shù)‘mysqli_link_free_storage’中:
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:158: 錯誤:‘MY_MYSQL’沒有名為‘mysql’        的成員
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:159: 錯誤:‘MY_MYSQL’沒有名為‘mysql’        的成員
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c: 在函數(shù)‘zm_startup_mysqli’中:
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:548: 錯誤:‘MYSQL_READ_DEFAULT_GROUP’        未聲明(在此函數(shù)內(nèi)第一次使用)
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:548: 錯誤:(即使在一個函數(shù)內(nèi)多次出現(xiàn)        ,每個未聲明的標(biāo)識符在其
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:548: 錯誤:所在的函數(shù)內(nèi)也只報告一次。        )
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:549: 錯誤:‘MYSQL_READ_DEFAULT_FILE’        未聲明(在此函數(shù)內(nèi)第一次使用)
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:550: 錯誤:‘MYSQL_OPT_CONNECT_TIMEOUT        ’未聲明(在此函數(shù)內(nèi)第一次使用)
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:551: 錯誤:‘MYSQL_OPT_LOCAL_INFILE’未        聲明(在此函數(shù)內(nèi)第一次使用)
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:552: 錯誤:‘MYSQL_INIT_COMMAND’未聲明        (在此函數(shù)內(nèi)第一次使用)
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:555: 錯誤:‘CLIENT_SSL’未聲明(在此函        數(shù)內(nèi)第一次使用)
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:556: 錯誤:‘CLIENT_COMPRESS’未聲明(在        此函數(shù)內(nèi)第一次使用)
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:557: 錯誤:‘CLIENT_INTERACTIVE’未聲明        (在此函數(shù)內(nèi)第一次使用)
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:558: 錯誤:‘CLIENT_IGNORE_SPACE’未聲        明(在此函數(shù)內(nèi)第一次使用)
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:559: 錯誤:‘CLIENT_NO_SCHEMA’未聲明(        在此函數(shù)內(nèi)第一次使用)
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:560: 錯誤:‘CLIENT_FOUND_ROWS’未聲明(        在此函數(shù)內(nèi)第一次使用)
/root/lanmp/php-5.2.17/ext/mysqli/mysqli.c:572: 錯誤:‘STMT_ATTR_UPDATE_MAX_LENG        TH’未聲明(在此函數(shù)內(nèi)第一次使用)
還有很長的錯誤代碼。請問怎么解決安裝?
頂上
頂上,管理員麻煩來給一下解決辦法吧。
這個目前不確定原因,可能和你的系統(tǒng)有關(guān)
回復(fù) 9# admin
     或者你能幫我看看嗎
