[求助] 請(qǐng)問(wèn)為什么安裝不了PHP
如題,由于之前數(shù)據(jù)用了簡(jiǎn)單的密碼被黑之后。今天重新安裝WDCP,是最新 v3.3.9
根據(jù):
v3升級(jí)到v3.2后,多PHP版本共存的安裝方法
http://www.szkyjg.com/bbs/viewthread.php?tid=56024&highlight=PHP
的方法,提示:
Nothing to do
5.2.17 is Installed
5.3.29 is Installed
5.4.45 is Installed
5.5.38 is Installed
5.6.30 is Installed
7.0.18 is Installed
7.1.4 is Installed
      configurations, phps install is complete
      visit http://ip:8080
      more infomation please visit http://www.szkyjg.com/bbs/
看上去是成功的,但是只有 5.2.17 成功了,因?yàn)?/font>
/www/wdlinux/phps
目錄下只有 52/etc/php.ini
沒(méi)有其他。點(diǎn)擊WDCP面板的PHP版本管理也只有5.2
其他全部未安裝,嘗試多次:
wget http://down.wdlinux.cn/in/phps.sh
sh phps.sh
sh phps.sh 7.1.4(如5.2.17/5.3.29/5.4.45/5.5.38/5.6.30/7.0/7.2/7.3)
統(tǒng)統(tǒng)提示成功,就是只有5.2
聽,
rm -f inf/53.txt
執(zhí)行這個(gè)再安裝試試
相應(yīng)版本相應(yīng)執(zhí)行
   多謝了,用“Putty.exe”測(cè)試過(guò),算是無(wú)效。為什么說(shuō)算是?用FTP工具《Filezilla》鏈接服務(wù)器,看到 /root/inf/53.txt、54.txt、56.txt、71.txt、72.txt、73.txt 是被刪除了,
執(zhí)行以下:
sh phps.sh 5.4.45
sh phps.sh 5.6.30
sh phps.sh 7.0.33
sh phps.sh 7.1.25
sh phps.sh 7.2.15
sh phps.sh 7.3.2
顯示檢查:
Loaded plugins: fastestmirror, security
Setting up Install Process
最后:Nothing to do
本人只是喳喳前端,不太懂后端的語(yǔ)言,看到 /root/src 目錄下已經(jīng)有:
php-5.2.17.tar.gz、php-5.3.29.tar.gz、php-5.4.45.tar.gz、php-5.5.38.tar.gz、php-5.6.30.tar.gz、php-7.0.18.tar.gz各個(gè)包了
不知道是否和訪問(wèn)端口有關(guān),例如本人的WDCP訪問(wèn)IP地址是:***.***.***.***:8010/index。
后面,把8010,改回8080,再重新測(cè)試
sh phps.sh 7.1.4
這次不再是檢查、加載什么什么模塊。而是:
php-7.1.4/Zend/tests/unset_cv05.phpt
php-7.1.4/Zend/tests/bug42818.phpt
checking whether to enable zend signal handling... yes
Configuring TSRM
Configuring libtool
creating libtool
Generating files
| License:                                                           |
| This software is subject to the PHP License, available in this     |
| distribution in the file LICENSE.  By continuing this installation |
| process, you are bound by the terms of this license agreement.     |
| If you do not agree with the terms of this license, you must abort |
| the installation process at this point.                            |
Thank you for using PHP.
config.status: creating php7.spec
configure: WARNING: unrecognized options: --with-mysql
/bin/sh /root/src/php-7.1.4/libtool --silent --preserve-dup-deps --mode=compile cc -DZEND_ENABLE_STATIC_TSRMLS_CACHE=1 -Iext/opcache/ -I/root/src/php-7.1.4/ext/opcache/ -DPHP_ATOM_INC -I/root/src/php-7.1.4/include -I/root/src/php-7.1.4/main -I/root/src/php-7.1.4 -I/root/src/php-7.1.4/ext/date/lib -I/usr/include/libxml2 -I/usr/include/freetype2 -I/root/src/php-7.1.4/ext/mbstring/oniguruma -I/root/src/php-7.1.4/ext/mbstring/libmbfl -I/root/src/php-7.1.4/ext/mbstring/libmbfl/mbfl -I/root/src/php-7.1.4/ext/sqlite3/libsqlite -I/root/src/php-7.1.4/ext/zip/lib -I/root/src/php-7.1.4/TSRM -I/root/src/php-7.1.4/Zend    -I/usr/include -g -O2 -fvisibility=hidden -DZEND_SIGNALS    -c /root/src/php-7.1.4/ext/opcache/ZendAccelerator.c -o ext/opcache/ZendAccelerator.lo
Build complete.
7.1.4 install complete
這次提示成功 是真的成功
/www/wdlinux/phps/71/ 有文件了,
WDCP面板的PHP版本管理也看到了
我的系統(tǒng)CentOS 6.8 64位,安裝WDCP時(shí) 默認(rèn)的PHP是5.5,為了驗(yàn)證想法,接下來(lái)再安裝 5.6.30其他的都可以了。。。
果然是端口問(wèn)題。。。。
聽,
