[求助] 置頂升級(jí)的PHP5.3.17 memcache失效
本帖最后由 cfooxl 于 2013-12-4 16:52 編輯
驗(yàn)證如下...探針http://23.227.177.140/tz.php?act=phpinfo
# /www/wdlinux/php/bin/php -m |grep memcache
PHP Warning:  PHP Startup: Unable to load dynamic library '/www/wdlinux/php/lib/php/extensions/no-debug-non-zts-20090626/php_curl.dll' - /www/wdlinux/php/lib/php/extensions/no-debug-non-zts-20090626/php_curl.dll: cannot open shared object file: No such file or directory in Unknown on line 0
PHP Warning:  PHP Startup: memcache: Unable to initialize module
Module compiled with module API=20060613
PHP    compiled with module API=20090626
These options need to match
照著論壇里搜索的方法,編輯了原來memcache的sh文件
#!/bin/bash
# Memcache install scripts
# Author:wdlinux
# Url http://www.szkyjg.com
cd /tmp
wget -c https://github.com/downloads/libevent/libevent/libevent-2.0.21-stable.tar.gz
wget -c http://memcached.googlecode.com/files/memcached-1.4.15.tar.gz
wget -c http://pecl.php.net/get/memcache-2.2.7.tgz
tar xf libevent-2.0.21-stable.tar.gz
cd libevent-2.0.21-stable
./configure --prefix=/usr
[ $? != 0 ] && exit
cd ..
tar xf memcached-1.4.15.tar.gz
cd memcached-1.4.15
./configure --prefix=/www/wdlinux/memcached --with-libevent=/usr
[ $? != 0 ] && exit
cd ..
if grep -qi 'debian\|ubuntu' /etc/issue; then
    wget http://www.szkyjg.com/conf/init.d/init.memcached-ubuntu -O /www/wdlinux/init.d/memcached
    chmod 755 /www/wdlinux/init.d/memcached
    ln -s /www/wdlinux/init.d/memcached /etc/init.d/memcached
    update-rc.d -f memcached defaults
    update-rc.d -f memcached enable 235
else
    wget http://www.szkyjg.com/conf/init.d/init.memcached -O /www/wdlinux/init.d/memcached
    chkconfig --level 35 memcached on
fi
touch /www/wdlinux/etc/memcached.conf
service memcached start
tar zxvf memcache-2.2.7.tgz
cd memcache-2.2.7
/www/wdlinux/php/bin/phpize
./configure --enable-memcache --with-php-config=/www/wdlinux/php/bin/php-config --with-zlib-dir
[ $? != 0 ] && exit
grep -q 'memcache.so' /www/wdlinux/etc/php.ini
if [ $? != 0 ]; then
    echo "
[memcache]
extension_dir ="/www/wdlinux/php/lib/php/extensions/$ext_dir"
extension=memcache.so" >> /www/wdlinux/etc/php.ini
fi
if [ -d /www/wdlinux/apache ]; then
    service httpd restart
else
    service nginxd restart
fi
echo
echo "memcache install is OK"
echo
TAT 求助。。。。。。。。完全不知道該怎么辦了..........我是不是要寫死5.3.17這個(gè)安裝目錄?
本帖最后由 cfooxl 于 2013-12-4 18:04 編輯
=.= 老大的服務(wù)器里什么版本都有,直接修改置頂PHP升級(jí)文件里的ver為5.3.27 這是memcached安裝文件里的另外一個(gè)版本選擇
5.2.17和5.3.27我直接升級(jí)5.3.27 然后再安裝一次memcached。。。。。。。。。。。笨人有笨辦法。。。。。。。。。
升級(jí)成功!
phpinfo可查
探針在一樓
解決了就好
