[root@AY130811112859728246Z home]# sh install.sh
Setting up Install Process
No package screen available.
Nothing to do
Cannot find 'screen' command,install without screen(default yes)?
(Yes/No): y
Select Install
1 apache + php + mysql + zend + eAccelerator + pureftpd + phpmyadmin
2 nginx + php + mysql + zend + eAccelerator + pureftpd + phpmyadmin
3 nginx + apache + php + mysql + zend + eAccelerator + pureftpd + phpmyadmin
4 install all service
5 don't install is now
Please Input 1,2,3,4,5: 1
Select php version:
1 php-5.2.17 (default)
2 php-5.3.27
Please Input 1,2: 1
error: skipping http://pkgs.repoforge.org/rpmforge-release/rpmforge-release-0.5.3-1.el5.rf.x86_64.rpm - transfer failed - Unknown or unexpected error
Retrieving http://pkgs.repoforge.org/rpmforge-release/rpmforge-release-0.5.3-1.el5.rf.x86_64.rpm
No package gcc-c++ available.
No package autoconf available.
No package libtool-ltdl-devel available.
No package gd-devel available.
No package freetype-devel available.
No package libxml2-devel available.
No package libjpeg-devel available.
No package libpng-devel available.
No package openssl-devel available.
No package curl-devel available.
No package patch available.
No package libmcrypt-devel available.
No package libmhash-devel available.
No package ncurses-devel available.
No package libcap-devel available.
No package sendmail available.
No package unzip available.
Nothing to do
19 Dec 18:04:35 ntpdate[1878]: the NTP socket is in use, exiting
installing mysql,this may take a few minutes,hold on plz...
configure in progress ...
Preparing... ##################################################
rpmforge-release ##################################################
Resolving Dependencies
--> Running transaction check
---> Package libmcrypt-devel.x86_64 0:2.5.7-1.2.el5.rf set to be updated
--> Processing Dependency: libmcrypt = 2.5.7-1.2.el5.rf for package: libmcrypt-devel
--> Processing Dependency: libmcrypt.so.4()(64bit) for package: libmcrypt-devel
---> Package mhash-devel.x86_64 0:0.9.9-1.el5.rf set to be updated
--> Processing Dependency: mhash = 0.9.9-1.el5.rf for package: mhash-devel
--> Processing Dependency: libmhash.so.2()(64bit) for package: mhash-devel
---> Package libmcrypt.x86_64 0:2.5.7-1.2.el5.rf set to be updated
---> Package mhash.x86_64 0:0.9.9-1.el5.rf set to be updated
--> Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository Size
Installing:
libmcrypt-devel x86_64 2.5.7-1.2.el5.rf rpmforge 112 k
mhash-devel x86_64 0.9.9-1.el5.rf rpmforge 19 k
Installing for dependencies:
libmcrypt x86_64 2.5.7-1.2.el5.rf rpmforge 182 k
mhash x86_64 0.9.9-1.el5.rf rpmforge 161 k
Transaction Summary
Install 4 Package(s)
Update 0 Package(s)
Remove 0 Package(s)
Total download size: 475 k
Downloading Packages:
Total 68 kB/s | 475 kB 00:06
Running rpm_check_debug
Running Transaction Test
Finished Transaction Test
Transaction Test Succeeded
Running Transaction
Installing : mhash 1/4
Installing : libmcrypt 2/4
Installing : mhash-devel 3/4
Installing : libmcrypt-devel 4/4
Installed:
libmcrypt-devel.x86_64 0:2.5.7-1.2.el5.rf mhash-devel.x86_64 0:0.9.9-1.el5.rf
Dependency Installed:
libmcrypt.x86_64 0:2.5.7-1.2.el5.rf mhash.x86_64 0:0.9.9-1.el5.rf
Complete!
19 Dec 18:05:36 ntpdate[8149]: the NTP socket is in use, exiting
用的阿里云服務(wù)器 ,安裝N次了,每次都是這樣。求高手幫忙。 |
