[已解決]
mysql升級(jí)報(bào)錯(cuò),現(xiàn)在啟動(dòng)不了
druse
本帖最后由 druse 于 2014-6-16 14:28 編輯
我是用這個(gè)來升級(jí)的
wget
http://down.wdlinux.cn/in/mysql_up55.sh
sh mysql_up55.sh
現(xiàn)在出錯(cuò)了,Mysql無法啟動(dòng) 請大家?guī)兔σ幌,謝謝
ERROR! MySQL server PID file could not be found!
scripts/mysql_install_db.sh: line 325: @HOSTNAME@: command not found
WARNING: The host '' could not be looked up with resolveip.
This probably means that your libc libraries are not 100 % compatible
with this binary MySQL version. The MySQL daemon, mysqld, should work
normally with the exception that host name resolving will not work.
This means that you should use IP addresses instead of hostnames
when specifying MySQL privileges !
Installing MySQL system tables...
140616 13:43:01 [ERROR] Incorrect definition of table mysql.proc: expected column 'comment' at position 15 to have type text, found type char(64).
ERROR: 1136 Column count doesn't match value count at row 1
140616 13:43:01 [ERROR] Aborting
140616 13:43:01 [Note] /www/wdlinux/mysql/bin/mysqld: Shutdown complete
Installation of system tables failed! Examine the logs in
/www/wdlinux/mysql/var for more information.
You can try to start the mysqld daemon with:
shell> /www/wdlinux/mysql/bin/mysqld --skip-grant &
and use the command line tool /www/wdlinux/mysql/bin/mysql
to connect to the mysql database and look at the grant tables:
shell> /www/wdlinux/mysql/bin/mysql -u root mysql
mysql> show tables
Try 'mysqld --help' if you have problems with paths. Using --log
gives you a log in /www/wdlinux/mysql/var that may be helpful.
Please consult the MySQL manual section
'Problems running mysql_install_db', and the manual section that
describes problems on your OS. Another information source are the
MySQL email archives available at http://lists.mysql.com/.
Please check all of the above before mailing us! And remember, if
you do mail us, you MUST use the /www/wdlinux/mysql/scripts/mysqlbug script!
mv: cannot move `/www/wdlinux/mysql/var/mysql' to `/www/wdlinux/mysql/var/mysqlo/mysql': Directory not empty
Starting MySQL. ERROR! The server quit without updating PID file (/www/wdlinux/mysql-5.5.27/data/AY140228220438096255Z.pid).
Running..., Please Wait...
err
mysql update is OK
druse
http://www.szkyjg.com/bbs/viewthread.php?tid=5461
請參照這個(gè)帖子,解決問題了
ligq198838
這樣也不能完全解決問題,請到
http://www.szkyjg.com/bbs/viewthread.php?tid=10582&extra=
