標(biāo)題: [求助] wdcp安裝失敗。給解決下 [打印本頁]
作者: jhonm    時間: 2012-2-10 14:25     標(biāo)題: wdcp安裝失敗。給解決下
Build complete.
Installing PHP SAPI module:       apache2handler
/www/wdlinux/wdapache/build/instdso.sh SH_LIBTOOL='/www/wdlinux/wdapache/build/libtool' libphp5.la /www/wdlinux/wdapache/modules
/www/wdlinux/wdapache/build/libtool --mode=install cp libphp5.la /www/wdlinux/wdapache/modules/
cp .libs/libphp5.so /www/wdlinux/wdapache/modules/libphp5.so
cp .libs/libphp5.lai /www/wdlinux/wdapache/modules/libphp5.la
libtool: install: warning: remember to run `libtool --finish /root/wdcp/lanmp/php-5.2.17/libs'
chmod 755 /www/wdlinux/wdapache/modules/libphp5.so
[activating module `php5' in /www/wdlinux/wdapache/conf/httpd.conf]
Installing PHP CLI binary:        /www/wdlinux/wdphp/bin/
Installing PHP CLI man page:      /www/wdlinux/wdphp/man/man1/
Installing build environment:     /www/wdlinux/wdphp/lib/php/build/
Installing header files:          /www/wdlinux/wdphp/include/php/
Installing helper programs:       /www/wdlinux/wdphp/bin/
  program: phpize
  program: php-config
Installing man pages:             /www/wdlinux/wdphp/man/man1/
  page: phpize.1
  page: php-config.1
Installing PEAR environment:      /www/wdlinux/wdphp/lib/php/
/root/wdcp/lanmp/php-5.2.17/sapi/cli/php: error while loading shared libraries: libssl.so.6: cannot open shared object file: No such file or directory
make[1]: *** [install-pear-installer] Error 127
make: *** [install-pear] Error 2
----Install Error: wdphp make install err -----------
作者: sqrcg    時間: 2012-2-10 14:28
這個嘛,不太清楚呀。
作者: admin    時間: 2012-2-10 14:31
系統(tǒng)什么版本,yum install -y openssl-devel
然后再安裝試試
作者: jhonm    時間: 2012-2-10 14:32
centos 6.2
作者: jhonm    時間: 2012-2-10 14:33
[root@web wdcp]# yum install openssl-devel
Loaded plugins: fastestmirror, refresh-packagekit, security
* base: mirror.bit.edu.cn
* extras: mirror.bit.edu.cn
* rpmforge: ftp-stud.fht-esslingen.de
* updates: mirror.bit.edu.cn
Setting up Install Process
Package openssl-devel-1.0.0-20.el6_2.1.i686 already installed and latest version
作者: jhonm    時間: 2012-2-10 14:47
管理員呢,這個包早就裝過了
作者: weblinux    時間: 2012-2-13 13:56
回復(fù) 5# jhonm
    提示shared libraries: libssl.so.6
