標題: [求助] 服務器重啟后,網(wǎng)站可以打開,wdcp打不開 [打印本頁]
作者: xiaoxiao0    時間: 2012-6-3 02:16     標題: 服務器重啟后,網(wǎng)站可以打開,wdcp打不開
ssh遠程連接,輸入root 后,輸入密碼那里沒有反應咋回事??
下面四個選項應該選擇哪個呢?
And just to make sure, type the action you wish to perform in the box below.
  - To power cycle reboot (or turn ON if previously turned OFF) the server, type 'REBOOT'
  - To turn the power to the server OFF, type 'OFF' (use REBOOT to turn back ON)
  - To boot the server into RESCUE Mode, type 'RESCUE'
  - To reinstall the entire OS (removing ALL DATA), type 'INSTALL'
作者: admin    時間: 2012-6-3 11:18
這個是什么服務器,會有這樣的提示?
作者: xiaoxiao0    時間: 2012-6-3 15:23
回復 2# admin
    https://www.take2hosting.com/它的主機
