自己編譯rewrite后網(wǎng)站無(wú)法打開(kāi)
[打印本頁(yè)]
sr100fen
當(dāng)初下的wdos 1.0 選的是2,可是安后發(fā)現(xiàn)沒(méi)有web環(huán)境和 wdcp,好像就是個(gè)base,懷疑安裝錯(cuò)了,重新安裝一次問(wèn)題依舊,先不管了,看到有新的rmp包后裝上了,感覺(jué)還不錯(cuò),先建幾個(gè)站點(diǎn),大問(wèn)題沒(méi)有。于是不再去想為什么接著用。
前不久發(fā)現(xiàn)了自己的drupal7打不開(kāi)clean urls,搜索后(
http://drupal.org/node/15365
)得知需要改一些東西,于是動(dòng)手了。具體過(guò)程如下:
先是 /www/wdlinux/apache/bin/httpd -l 看到有了mod_rewrite.c 可是在那里呢?怎么沒(méi)有找到?
網(wǎng)上說(shuō)在apache目錄下修改httpd.conf. 在文件中 確定開(kāi)啟mod_rewrite模塊 ( LoadModule rewrite_module modules/mod_rewrite.so)可是/www/wdlinux/httpd-2.2.22/modules下面并沒(méi)有mod_rewrite.so,就有了自己編譯一個(gè)mod_rewrite.so的想法。
接著便是下載lanmp_v2.4.tar.gz (
http://dl.wdlinux.cn:5180/lanmp_v2.4.tar.gz
)在mappers 里面找到了mod_rewrite.c
執(zhí)行命令 /www/wdlinux/apache/bin/apxs -c mod_rewrite.c
然后 /www/wdlinux/apache/bin/apxs -i -a -n mod_rewrite mod_rewrite.la
得到結(jié)果
/www/wdlinux/httpd-2.2.22/build/instdso.sh SH_LIBTOOL='/www/wdlinux/httpd-2.2.22/build/libtool' mod_rewrite.la /www/wdlinux/httpd-2.2.22/modules
/www/wdlinux/httpd-2.2.22/build/libtool --mode=install cp mod_rewrite.la /www/wdlinux/httpd-2.2.22/modules/
cp .libs/mod_rewrite.so /www/wdlinux/httpd-2.2.22/modules/mod_rewrite.so
cp .libs/mod_rewrite.lai /www/wdlinux/httpd-2.2.22/modules/mod_rewrite.la
cp .libs/mod_rewrite.a /www/wdlinux/httpd-2.2.22/modules/mod_rewrite.a
chmod 644 /www/wdlinux/httpd-2.2.22/modules/mod_rewrite.a
ranlib /www/wdlinux/httpd-2.2.22/modules/mod_rewrite.a
PATH="$PATH:/sbin" ldconfig -n /www/wdlinux/httpd-2.2.22/modules
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the `LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the `LD_RUN_PATH' environment variable
during linking
- use the `-Wl,--rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
chmod 755 /www/wdlinux/httpd-2.2.22/modules/mod_rewrite.so
[activating module `mod_rewrite' in /www/wdlinux/httpd-2.2.22/conf/httpd.conf]
modules目錄下有了mod_rewrite.so文件。
httpd.conf里面有了LoadModule rewrite_module modules/mod_rewrite.so
重新啟動(dòng),悲劇就發(fā)生了,所有站點(diǎn)都是打不開(kāi)的,連錯(cuò)誤信息都沒(méi)有……
我哪步錯(cuò)了?
這么奇怪
默認(rèn)是支持了mod_rewrite的,你說(shuō)看不到
wdos安裝,也沒(méi)有安裝到
再者,編譯這個(gè)后,重起沒(méi)有任何提示???
sr100fen
2#
是的,安裝wdos后當(dāng)時(shí)也很奇怪,但是沒(méi)在意,看到
http://www.szkyjg.com/bbs/viewthread.php?tid=2751
的帖子,才感覺(jué)可能不是個(gè)案,也許是硬件的關(guān)系我想。
按理,是不應(yīng)該跟硬件有關(guān)的
如果硬件原因,可能是全裝不了,一般不會(huì)一部分裝不了
marquis
3#
sr100fen
你下載的wdos是什么版本 給你下載的那個(gè)連接給我 我試試
sr100fen
5#
marquis
http://dl.wdlinux.cn:5180/wdos/iso/wdOS-1.0-i386.iso
老機(jī)器,所以下的32位,光驅(qū)用的usb外接的。自己的電腦,磁盤全部重新分區(qū),分區(qū)是只有/boot和/和swap,(好像系統(tǒng)會(huì)分個(gè)別的什么,如下圖)ip什么的都是自動(dòng)分配
df -lh
Filesystem Size Used Avail Use% Mounted on
/dev/hda2 35G 16G 18G 47% /
/dev/hda1 99M 12M 83M 13% /boot
tmpfs 502M 0 502M 0% /dev/shm
還有
fdisk -l
Disk /dev/hda: 40.0 GB, 40007761920 bytes
255 heads, 63 sectors/track, 4864 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/hda1 * 1 13 104391 83 Linux
/dev/hda2 14 4724 37841107+ 83 Linux
/dev/hda3 4725 4863 1116517+ 82 Linux swap / Solaris
/dev/hda4 4864 4864 8032+ 5 Extended
/dev/hda5 4864 4864 8001 8e Linux LVM
順便問(wèn)下,安裝后主機(jī)名,教程里是wdos ,而我是localhost,有問(wèn)題么 ?還有筆記本可以裝么?
