標題: [BUG反饋] centos5.6 32位wdcp_v2.4RPM包LNMP 創(chuàng)建站點成功,上傳程序出現(xiàn)502 Bad Gateway [打印本頁] 作者: zhanjun 時間: 2012-7-15 11:10 標題: centos5.6 32位wdcp_v2.4RPM包LNMP 創(chuàng)建站點成功,上傳程序出現(xiàn)502 Bad Gateway
本帖最后由 zhanjun 于 2012-7-15 20:18 編輯
wdcp_v2.4創(chuàng)建站點成功,域名打開是官方默認的創(chuàng)建站長成功html界面,但是我自己上傳程序上去打開訪問卻是502 Bad Gateway,無法安裝網(wǎng)站程序,求解決測試頁面http://test.znsmw.com/
用的nginx web,沒有選擇偽靜態(tài)
[root@centos ~]# service nginxd restart
Stopping nginx: nginx: [warn] conflicting server name "123.znsmw.com" on 0.0.0.0:80, ignored
nginx: [error] open() "/www/wdlinux/nginx-1.0.15/logs/nginx.pid" failed (2: No such file or directory)
[ OK ]
Shutting down php_fpm warning, no pid file found - php-fpm is not running ?
Starting nginx: nginx: [warn] conflicting server name "123.znsmw.com" on 0.0.0.0:80, ignored
nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Address already in use)
nginx: [emerg] still could not bind()
[FAILED]
Starting php_fpm Error in argument 1, char 1: no argument for option -
Usage: php-cgi [-q] [-h] [-s] [-v] [-i] [-f <file>]
php-cgi <file> [args...]
-a Run interactively
-b <address:port>|<port> Bind Path for external FASTCGI Server mode
-C Do not chdir to the script's directory
-c <path>|<file> Look for php.ini file in this directory
-n No php.ini file will be used
-d foo[=bar] Define INI entry foo with value 'bar'
-e Generate extended information for debugger/profiler
-f <file> Parse <file>. Implies `-q'
-h This help
-i PHP information
-l Syntax check only (lint)
-m Show compiled in modules
-q Quiet-mode. Suppress HTTP Header output.
-s Display colour syntax highlighted source.
-v Version number
-w Display source with stripped comments and whitespace.
-z <file> Load Zend extension <file>.
-T <count> Measure execution time of script repeated <count> times.
................................... failed
重啟nginx失敗,VPS重啟了好幾次還是不行作者: huzs1622 時間: 2012-9-1 16:38
