標(biāo)題: [求助] 這些日志都是什么意思? [打印本頁]
作者: xiaoxiao0    時(shí)間: 2012-7-26 16:14     標(biāo)題: 這些日志都是什么意思?
Jul 22 19:35:31 www sshd[7573]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=123.138.37.68  user=root
Jul 22 19:35:33 www sshd[7573]: Failed password for root from 123.138.37.68 port 50792 ssh2
Jul 22 11:35:38 www sshd[7574]: Received disconnect from 123.138.37.68: 11: Bye Bye
Jul 22 19:35:44 www sshd[7576]: Did not receive identification string from 123.138.37.68
Jul 22 11:36:37 www sshd[7579]: Connection closed by 123.138.37.68
Jul 22 20:17:20 www sudo:    wdcpu : TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; USER=root ; COMMAND=/www/wdlinux/wdphp/bin/php /www/wdlinux/wdcp/task/wdcp_sv.php
Jul 22 20:17:27 www sudo:    wdcpu : TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; USER=root ; COMMAND=/www/wdlinux/wdphp/bin/php /www/wdlinux/wdcp/task/wdcp_sv.php
Jul 22 20:18:11 www sudo:    wdcpu : TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; USER=root ; COMMAND=/www/wdlinux/wdphp/bin/php /www/wdlinux/wdcp/task/wdcp_sr.php
文件太多,超過限制,所以作為附件上傳,老大幫忙看下,是不是被攻擊或者有人登錄服務(wù)器
附件: 日志.zip (2012-7-26 16:14, 21.63 KB) / 下載次數(shù) 0
http://www.szkyjg.com/bbs/attachment.php?aid=1318&k=ac76903917e6585932b0d352565c7cf4&t=1746474447&sid=os92t5
作者: admin    時(shí)間: 2012-7-26 17:48
ssh那些應(yīng)該是一些猜解機(jī)了
wdcpu這些是后臺(tái)調(diào)用的
