標(biāo)題: [求助] 當(dāng)前服務(wù)器上的PHP版本太舊, 新的phpBB將不再支持這個版本的PHP. Details [打印本頁]
作者: voone    時間: 2012-9-12 14:35     標(biāo)題: 當(dāng)前服務(wù)器上的PHP版本太舊, 新的phpBB將不再支持這個版本的PHP. Details
求開袋即食php升級方法
作者: admin    時間: 2012-9-12 15:15
不會吧,支持哪個
5.3/5.4?
作者: voone    時間: 2012-9-12 17:05
wdcp_v2.5.r6(20120907)
PHP Version 5.2.17p1
安裝phpbb 3.0.11(最新版本) 就提示
作者: admin    時間: 2012-9-12 18:57
我知道現(xiàn)在的PHP版本是5.2.17
我是要PHPBB要求的版本是多少
作者: voone    時間: 2012-9-12 19:46
本帖最后由 voone 于 2012-9-12 19:50 編輯
看了一下phpbbchina跟竹貓星球的帖子  最佳版本好像是 php 5.3.2以上
https://www.phpbb.com/community/viewtopic.php?f=14&t=2152375
phpBB 3.1 "Ascraeus" to require PHP 5.3.2
by Oleg » Fri Mar 09, 2012 4:21 pm
The next major release of phpBB, phpBB 3.1 "Ascraeus", will require PHP 5.3.2 or newer.
PHP 5.3 provides important functionality that a number of established projects are using. As it is phpBB's goal to use components from other projects where doing so makes sense, raising minimum PHP version to 5.3 allows phpBB to reuse some components from Symfony instead of reimplementing equivalent functionality. This will speed up the completion of phpBB 3.1 by reducing the amount of work that Development Team has to do.
You can read the discussion leading to the decision.
All major distributions are already shipping PHP 5.3.2 or newer in their current stable versions. You can find a table of several distributions and the versions they ship here.
phpBB 3.0 "Olympus" will continue to require PHP 4.3.3 as the minimum version.
phpBB 3.0.10 supports PHP 5.3. Since PHP 5.2 is no longer maintained by PHP developers, all users not already running PHP 5.3 are strongly encouraged to move to PHP 5.3.
As phpBB 3.1 "Ascraeus" is still under active development, there is still plenty of time to upgrade your PHP installation.
Additionally, one should note that this announcement does not imply that phpBB 3.1 will see large portions of code rewritten in order to take advantage of new features in PHP 5.3. Instead, sections of code will be updated as needed in the 3.x release cycle.
Please discuss this announcement here.
Participate in phpBB development: Get involved | Issue tracker | Report a bug | Development board| [url=irc://chat.freenode.net/phpbb-dev]Development IRC chat[/url]
Formerly known as nn-
Oleg3.1 Release Manager
Posts: 1122Joined: Sat Jan 30, 2010 4:42 pmLocation: NYC
作者: admin    時間: 2012-9-12 22:29
那升級PHP版本就可以了
