Preparing... ########################################### [100%]
1:lanmp_wdcp ########################################### [100%]
Installing MySQL system tables...
OK
Filling help tables...
OK
To start mysqld at boot time you have to copy
support-files/mysql.server to the right place for your system
PLEASE REMEMBER TO SET A PASSWORD FOR THE MySQL root USER !
To do so, start the server, then issue the following commands:
Alternatively you can run:
/www/wdlinux/mysql-5.1.63/bin/mysql_secure_installation
which will also give you the option of removing the test
databases and anonymous user created by default. This is
strongly recommended for production servers.
See the manual for more instructions.
You can start the MySQL daemon with:
cd /www/wdlinux/mysql-5.1.63 ; /www/wdlinux/mysql-5.1.63/bin/mysqld_safe &
You can test the MySQL daemon with mysql-test-run.pl
cd /www/wdlinux/mysql-5.1.63/mysql-test ; perl mysql-test-run.pl
Please report any problems with the /www/wdlinux/mysql-5.1.63/bin/mysqlbug script!
Starting MySQL.Manager of pid-file quit without updating file.[失敗]
/www/wdlinux/mysql/bin/mysqladmin: connect to server at 'localhost' failed
error: 'Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)'
Check that mysqld is running and that the socket: '/tmp/mysql.sock' exists!
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
ln: “/usr/lib/plugin”:無法覆蓋目錄
啟動 httpd:[確定]
啟動 nginx:nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Address already in use)
nginx: [emerg] still could not bind()
[失敗]
啟動 httpd:
啟動 pure-config.pl:Running: /usr/sbin/pure-ftpd --daemonize -S21 -A -c50 -B -C8 -D -E -fftp -H -I15 -L10000:8 -m4 -s -U133:022 -u100 -k99 -Z -lunix -p20000:20500 -lmysql:/www/wdlinux/etc/pureftpd-mysql.conf
============ lanmp_wdcp install OK ==============
configuration ,lamp or lnmp,wdcp install is finshed
visit http://ip
wdcp visit http://ip:8080
more infomation please visit http://www.szkyjg.com作者: caiwaji 時間: 2015-1-28 09:59
