標(biāo)題: [求助] 403 錯(cuò)誤緊急求助 [打印本頁(yè)]
作者: wpcp0510    時(shí)間: 2015-5-10 16:22     標(biāo)題: 403 錯(cuò)誤緊急求助
網(wǎng)頁(yè)以前挺正常,最近莫名其妙的出現(xiàn)403錯(cuò)誤,提示如下:
Forbidden
You don't have permission to access / on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
遇到這種錯(cuò)誤刷新頁(yè)面偶爾會(huì)恢復(fù),最終需要service httpd restart 重啟下才能正常訪問(wèn)。
但是可能過(guò)10幾個(gè)小時(shí)錯(cuò)誤又會(huì)重新出現(xiàn),重啟httpd服務(wù)就好。
看日志有這種提示:
(24)Too many open files: /www/web/public_html/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable, referer:
根據(jù)百度搜索說(shuō)要修改文件夾權(quán)限為755,但是查詢(xún)文件夾權(quán)限沒(méi)錯(cuò)。
請(qǐng)教是什么原因?qū)е碌?如何辦?
作者: wpcp0510    時(shí)間: 2015-5-10 17:10
Google搜到一個(gè):
http://greproot.com/htaccess-pcfg_openfile-unable-to-check-htaccess-file/
1) A simple restart of apache fixed it all of a sudden.
2) Try ulimit -a as root and  check for “open files”. The default value will be 1024. Try raising it to 4096 as follows.
ulimit -n 4096
3) Also, you can raise this limit for apache by giving it in apache startup script at the beginning.
vi /etc/rc.d/init.d/httpd
Enter the following line at the beginning of the script.
ulimit -n 65536
Save the file and restart apache
/etc/rc.d/init.d/httpd restart
作者: 螞蚱    時(shí)間: 2015-5-11 17:33
回復(fù) 2# wpcp0510
解決了嗎
作者: junwen7788    時(shí)間: 2015-5-12 10:19
我也出現(xiàn)這個(gè)問(wèn)題了,樓主怎么解決的? 求指教, 現(xiàn)在每隔幾個(gè)小時(shí)就得重啟服務(wù)  不然就403,刷新幾次就可以訪問(wèn),然后訪問(wèn)下一個(gè)頁(yè)面又403
作者: hackyhuang    時(shí)間: 2015-5-12 15:22
同求。時(shí)而正常時(shí)而出現(xiàn)錯(cuò)誤。再過(guò)一段時(shí)間就必須重啟服務(wù)器了,否則完全無(wú)法執(zhí)行PHP、運(yùn)行了幾個(gè)月都正常,就是上周五開(kāi)始不正常了,兩臺(tái)VPS都這樣。
作者: xuandun    時(shí)間: 2015-5-12 21:01
應(yīng)該是權(quán)限問(wèn)題 給這個(gè)站點(diǎn)(包括子目錄文件)權(quán)限775
作者: junwen7788    時(shí)間: 2015-5-13 18:09
如果是權(quán)限問(wèn)題,為什么重啟下服務(wù)就正常了呢, 過(guò)幾個(gè)小時(shí)又出現(xiàn)403, 非常不解~
作者: 黑鍋    時(shí)間: 2015-5-16 08:22
我的站最近偶爾也出現(xiàn)這個(gè)問(wèn)題了,我懷疑是不是裝了云鎖的原因?
作者: 天堂傻子    時(shí)間: 2015-6-7 08:14
一樣的問(wèn)題
作者: bird    時(shí)間: 2015-6-7 10:47
都是403
管理員  沒(méi)人解釋下么????
作者: 天堂傻子    時(shí)間: 2015-6-7 16:54
這個(gè)問(wèn)題我已經(jīng)解決的,早上到現(xiàn)在我都像植物人一樣,網(wǎng)上的方法全都試了就是不行。
剛我在回憶前一段進(jìn)行過(guò)什么操作,終于發(fā)現(xiàn)了
我刪了一個(gè)FTP
剛才把那個(gè)刪除的FTP添加進(jìn)來(lái),問(wèn)題解決了!
作者: canimade    時(shí)間: 2015-6-7 17:33
我的也是這樣,這五六天 總是出現(xiàn)Forbidden 404,不知道是不是升級(jí)wdcp導(dǎo)致的,之前不會(huì)這樣的,不知如何解決,坐等解決方案,555555~~~
作者: chenqianwz    時(shí)間: 2015-6-7 20:28
同問(wèn)  也是最近出現(xiàn)的
作者: chenqianwz    時(shí)間: 2015-6-7 20:29
@admin  403錯(cuò)誤
作者: sudu8    時(shí)間: 2015-6-8 14:30
同樣出現(xiàn)403錯(cuò)誤,莫名其妙出現(xiàn)的。
更新了下配置文件就好了。
作者: xuweidiy    時(shí)間: 2015-6-8 14:46
這個(gè)是安裝了云鎖導(dǎo)致,卸載云鎖apache組件,或者直接干掉云鎖即解決!
作者: 注冊(cè)啊    時(shí)間: 2015-6-8 15:44
回復(fù) 16# xuweidiy
   是的,我昨天看了下進(jìn)程,跟其他服務(wù)器對(duì)比,的確是因?yàn)樵奇i。
作者: fanshichenlun    時(shí)間: 2015-6-8 16:42
這個(gè)是云鎖55版本改一個(gè)問(wèn)題導(dǎo)致的,對(duì)于這個(gè)問(wèn)題給大家?guī)?lái)的問(wèn)題表示抱歉;現(xiàn)在云鎖已經(jīng)更新,56版本特意解決了這個(gè)問(wèn)題,請(qǐng)大家更新到56版本即可,不好意思了。
