標(biāo)題: [求助] 求助。安裝APC和eAccelerator死活就不成功 [打印本頁]
作者: limboy    時間: 2015-5-26 14:38     標(biāo)題: 求助。安裝APC和eAccelerator死活就不成功
按照這個帖子來操作的http://www.freehao123.com/wdcp-lnmp-php/
php.ini里也都有相關(guān)配置  但是就是功能啟用不了,搜索本論壇都是看到admin 每次都說修改php.ini 就沒說過其他的問題 求大家的幫助
[eaccelerator]
extension_dir="/www/wdlinux/nginx_php/lib/php/extensions/no-debug-non-zts-20090626/"
extension ="/apc.so"
enabled = 1
apc.cache_by_default = on
apc.shm_segments = 1
apc.shm_size = 32
apc.ttl = 600
apc.user_ttl = 600
apc.num_files_hint = 0
apc.write_lock = On
extension="eaccelerator.so"
eaccelerator.shm_size="8"
eaccelerator.cache_dir="/www/wdlinux/eaccelerator_cache"
eaccelerator.enable="1"
eaccelerator.optimizer="1"
eaccelerator.check_mtime="1"
eaccelerator.debug="0"
eaccelerator.filter=""
eaccelerator.shm_max="0"
eaccelerator.shm_ttl="3600"
eaccelerator.shm_prune_period="3600"
eaccelerator.shm_only="0"
eaccelerator.compress="1"
eaccelerator.compress_level="9"
[xcache-common]
extension = xcache.so
[xcache]
xcache.shm_scheme = "mmap"
xcache.size = 160M
xcache.count = 1
xcache.slots = 8K
xcache.ttl = 0
xcache.gc_interval = 0
xcache.var_size = 4M
xcache.var_count = 1
xcache.var_slots = 8K
xcache.var_ttl = 0
xcache.var_maxttl = 0
xcache.var_gc_interval = 300
xcache.var_namespace_mode = 0
xcache.var_namespace = ""
xcache.readonly_protection = Off
xcache.mmap_path = "/tmp/xcache"
xcache.coredump_directory = ""
xcache.coredump_type = 0
xcache.disable_on_crash = Off
xcache.experimental = Off
xcache.cacher = On
xcache.stat = On
xcache.optimizer = Off
[xcache.coverager]
xcache.coverager = Off
xcache.coverager_autostart = On
xcache.coveragedump_directory = ""
