標(biāo)題: [求助] 安裝過程中mysql錯誤 [打印本頁]
作者: 半夜洗衣服    時間: 2012-11-6 20:09     標(biāo)題: 安裝過程中mysql錯誤
/usr/bin/ld: ../cmd-line-utils/libedit/libedit.a(terminal.o): undefined reference to symbol 'tgetnum'
/usr/bin/ld: note: 'tgetnum' is defined in DSO /lib/libtinfo.so.5 so try adding it to the linker command line
/lib/libtinfo.so.5: could not read symbols: Invalid operation
make[2]: *** [mysql] 錯誤 1
make[2]: Leaving directory `/home/ec2-user/lanmp/mysql-5.1.63/client'
make[1]: *** [all] 錯誤 2
make: *** [all-recursive] 錯誤 1
make[1]: Leaving directory `/home/ec2-user/lanmp/mysql-5.1.63/client'
請問這個錯誤該如何解決?
  • yum install -y gcc gcc-c++ make autoconf libtool-ltdl-devel gd-devel freetype-devel libxml2-devel libjpeg-devel libpng-devel openssl-devel curl-devel patch libmcrypt-devel libmhash-devel ncurses-devel sudo bzip2
這個運行過 在安裝 還是有的
作者: 半夜洗衣服    時間: 2012-11-6 20:11
回復(fù)是  nothing to do
