這個(gè)是這個(gè)文件的日志。/var/log/acpid
[Thu Nov 15 09:46:35 2012] exiting
[Thu Nov 15 09:50:41 2012] starting up
[Thu Nov 15 12:53:02 2012] BEGIN HANDLER MESSAGES
[Thu Nov 15 12:53:02 2012] END HANDLER MESSAGES
[Thu Nov 15 12:53:04 2012] exiting
[Thu Nov 15 12:57:03 2012] starting up
這個(gè)是message的日志。12點(diǎn)53斷的。網(wǎng)頁(yè)打不開。57的時(shí)候又好了。
Nov 15 10:10:28 b2c pure-ftpd: (hb2c@192.168.80.25) [INFO] 登出.
Nov 15 12:53:02 b2c shutdown[8481]: shutting down for system halt
Nov 15 12:53:02 b2c init: Switching to runlevel: 0
Nov 15 12:53:03 b2c smartd[3610]: smartd received signal 15: Terminated
Nov 15 12:53:03 b2c smartd[3610]: smartd is exiting (exit status 0)
Nov 15 12:53:05 b2c kernel: Kernel logging (proc) stopped.
Nov 15 12:53:05 b2c kernel: Kernel log daemon terminating.
Nov 15 12:53:06 b2c exiting on signal 15
Nov 15 12:57:02 b2c syslogd 1.4.1: restart.
Nov 15 12:57:02 b2c kernel: klogd 1.4.1, log source = /proc/kmsg started.
Nov 15 12:57:02 b2c kernel: Linux version 2.6.18-308.el5 (mockbuild@builder10.centos.org) (gcc version 4.1.2 20080704 (Red Hat 4.1.2-52)) #1 SMP Tue Feb 21 20:06:06 EST 2012
Nov 15 12:57:02 b2c kernel: Command line: ro root=/dev/VolGroup00/LogVol00
Nov 15 12:57:02 b2c kernel: BIOS-provided physical RAM map:
Nov 15 12:57:02 b2c kernel: BIOS-e820: 0000000000010000 - 00000000000a0000 (usable)
Nov 15 12:57:02 b2c kernel: BIOS-e820: 0000000000100000 - 00000000cf379000 (usable)
Nov 15 12:57:02 b2c kernel: BIOS-e820: 00000000cf379000 - 00000000cf38f000 (reserved)
Nov 15 12:57:02 b2c kernel: BIOS-e820: 00000000cf38f000 - 00000000cf3ce000 (ACPI data)
Nov 15 12:57:02 b2c kernel: BIOS-e820: 00000000cf3ce000 - 00000000d0000000 (reserved)
Nov 15 12:57:02 b2c kernel: BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
Nov 15 12:57:02 b2c kernel: BIOS-e820: 00000000fe000000 - 0000000100000000 (reserved)
Nov 15 12:57:02 b2c kernel: BIOS-e820: 0000000100000000 - 0000000830000000 (usable)
Nov 15 12:57:02 b2c kernel: DMI 2.6 present.
Nov 15 12:57:02 b2c kernel: SRAT: PXM 1 -> APIC 32 -> Node 0
Nov 15 12:57:02 b2c kernel: SRAT: PXM 2 -> APIC 0 -> Node 1
Nov 15 12:57:02 b2c kernel: SRAT: PXM 1 -> APIC 34 -> Node 0
Nov 15 12:57:02 b2c kernel: SRAT: PXM 2 -> APIC 2 -> Node 1
Nov 15 12:57:02 b2c kernel: SRAT: PXM 1 -> APIC 50 -> Node 0
Nov 15 12:57:02 b2c kernel: SRAT: PXM 2 -> APIC 18 -> Node 1
Nov 15 12:57:02 b2c kernel: SRAT: PXM 1 -> APIC 52 -> Node 0
Nov 15 12:57:02 b2c kernel: SRAT: PXM 2 -> APIC 20 -> Node 1
Nov 15 12:57:02 b2c kernel: SRAT: Node 1 PXM 2 0-d0000000
Nov 15 12:57:02 b2c kernel: SRAT: Node 1 PXM 2 0-430000000
Nov 15 12:57:02 b2c kernel: SRAT: Node 0 PXM 1 430000000-830000000
Nov 15 12:57:02 b2c kernel: Bootmem setup node 0 0000000430000000-0000000830000000
Nov 15 12:57:02 b2c kernel: Bootmem setup node 1 0000000000000000-0000000430000000
Nov 15 12:57:02 b2c kernel: Memory for crash kernel (0x0 to 0x0) notwithin permissible range
Nov 15 12:57:02 b2c kernel: disabling kdump
Nov 15 12:57:02 b2c kernel: ACPI: PM-Timer IO Port: 0x808
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x01] lapic_id[0x20] enabled)
Nov 15 12:57:02 b2c kernel: Processor #32 6:12 APIC version 21
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x02] lapic_id[0x00] enabled)
Nov 15 12:57:02 b2c kernel: Processor #0 6:12 APIC version 21
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x03] lapic_id[0x22] enabled)
Nov 15 12:57:02 b2c kernel: Processor #34 6:12 APIC version 21
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x04] lapic_id[0x02] enabled)
Nov 15 12:57:02 b2c kernel: Processor #2 6:12 APIC version 21
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x05] lapic_id[0x32] enabled)
Nov 15 12:57:02 b2c kernel: Processor #50 6:12 APIC version 21
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x06] lapic_id[0x12] enabled)
Nov 15 12:57:02 b2c kernel: Processor #18 6:12 APIC version 21
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x07] lapic_id[0x34] enabled)
Nov 15 12:57:02 b2c kernel: Processor #52 6:12 APIC version 21
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x08] lapic_id[0x14] enabled)
Nov 15 12:57:02 b2c kernel: Processor #20 6:12 APIC version 21
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x09] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x0a] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x0b] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x0c] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x0d] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x0e] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x0f] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x10] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x11] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x12] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x13] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x14] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x15] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x16] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x17] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x18] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x19] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x1a] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x1b] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x1c] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x1d] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x1e] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x1f] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC (acpi_id[0x20] lapic_id[0xff] disabled)
Nov 15 12:57:02 b2c kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
Nov 15 12:57:02 b2c kernel: ACPI: IOAPIC (id[0x00] address[0xfec00000] gsi_base[0])
Nov 15 12:57:02 b2c kernel: IOAPIC[0]: apic_id 0, version 32, address 0xfec00000, GSI 0-23
Nov 15 12:57:02 b2c kernel: ACPI: IOAPIC (id[0x01] address[0xfec80000] gsi_base[32])
Nov 15 12:57:02 b2c kernel: IOAPIC[1]: apic_id 1, version 32, address 0xfec80000, GSI 32-55
Nov 15 12:57:02 b2c kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Nov 15 12:57:02 b2c kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Nov 15 12:57:02 b2c kernel: Setting APIC routing to physical flat
Nov 15 12:57:02 b2c kernel: ACPI: HPET id: 0x8086a301 base: 0xfed00000
Nov 15 12:57:02 b2c kernel: Using ACPI (MADT) for SMP configuration information
Nov 15 12:57:02 b2c kernel: Nosave address range: 00000000000a0000 - 0000000000100000
Nov 15 12:57:02 b2c kernel: Nosave address range: 00000000cf379000 - 00000000cf38f000
Nov 15 12:57:02 b2c kernel: Nosave address range: 00000000cf38f000 - 00000000cf3ce000
Nov 15 12:57:02 b2c kernel: Nosave address range: 00000000cf3ce000 - 00000000d0000000
Nov 15 12:57:02 b2c kernel: Nosave address range: 00000000d0000000 - 00000000e0000000
Nov 15 12:57:02 b2c kernel: Nosave address range: 00000000e0000000 - 00000000f0000000
Nov 15 12:57:02 b2c kernel: Nosave address range: 00000000f0000000 - 00000000fe000000
Nov 15 12:57:02 b2c kernel: Nosave address range: 00000000fe000000 - 0000000100000000
Nov 15 12:57:02 b2c kernel: Allocating PCI resources starting at d1000000 (gap: d0000000:10000000)
Nov 15 12:57:02 b2c kernel: SMP: Allowing 32 CPUs, 24 hotplug CPUs
Nov 15 12:57:02 b2c kernel: Built 2 zonelists. Total pages: 8266379
Nov 15 12:57:02 b2c kernel: Kernel command line: ro root=/dev/VolGroup00/LogVol00
Nov 15 12:57:02 b2c kernel: Initializing CPU#0
Nov 15 12:57:02 b2c kernel: PID hash table entries: 4096 (order: 12, 32768 bytes)
Nov 15 12:57:02 b2c kernel: Console: colour VGA+ 80x25
Nov 15 12:57:02 b2c kernel: Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes)
Nov 15 12:57:02 b2c kernel: Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
Nov 15 12:57:02 b2c kernel: Checking aperture...
Nov 15 12:57:02 b2c kernel: ACPI: DMAR not present
Nov 15 12:57:02 b2c kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Nov 15 12:57:02 b2c kernel: Placing software IO TLB between 0x40a0000 - 0x80a0000
Nov 15 12:57:02 b2c kernel: Memory: 32945256k/34340864k available (2616k kernel code, 595900k reserved, 1671k data, 224k init)
Nov 15 12:57:02 b2c kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 4256.10 BogoMIPS (lpj=2128054)
Nov 15 12:57:02 b2c kernel: Security Framework v1.0.0 initialized
Nov 15 12:57:02 b2c kernel: SELinux: Initializing.
Nov 15 12:57:02 b2c kernel: selinux_register_security: Registering secondary module capability
Nov 15 12:57:02 b2c kernel: Capability LSM initialized as secondary
Nov 15 12:57:02 b2c kernel: Mount-cache hash table entries: 256作者: ggqb 時(shí)間: 2012-11-15 13:34
Nov 15 12:57:02 b2c kernel: CPU: L1 I cache: 32K, L1 D cache: 32K
Nov 15 12:57:02 b2c kernel: CPU: L2 cache: 256K
Nov 15 12:57:02 b2c kernel: CPU: L3 cache: 8192K
Nov 15 12:57:02 b2c kernel: CPU 0/20 -> Node 0
Nov 15 12:57:02 b2c kernel: using mwait in idle threads.
Nov 15 12:57:02 b2c kernel: CPU: Physical Processor ID: 1
Nov 15 12:57:02 b2c kernel: CPU: Processor Core ID: 0
Nov 15 12:57:02 b2c kernel: MCE: Machine Check Exception Reporting is disabled.
Nov 15 12:57:02 b2c kernel: SMP alternatives: switching to UP code
Nov 15 12:57:02 b2c kernel: ACPI: Core revision 20060707
Nov 15 12:57:02 b2c kernel: Using local APIC timer interrupts.
Nov 15 12:57:02 b2c kernel: Detected 8.312 MHz APIC timer.
Nov 15 12:57:02 b2c kernel: SMP alternatives: switching to SMP code
Nov 15 12:57:02 b2c kernel: Booting processor 1/8 APIC 0x0
Nov 15 12:57:02 b2c kernel: Initializing CPU#1
Nov 15 12:57:02 b2c kernel: Calibrating delay using timer specific routine.. 4256.08 BogoMIPS (lpj=2128040)
Nov 15 12:57:02 b2c kernel: CPU 1/0 -> Node 1
Nov 15 12:57:02 b2c kernel: CPU: Physical Processor ID: 0
Nov 15 12:57:02 b2c kernel: Intel(R) Xeon(R) CPU E5606 @ 2.13GHz stepping 02
Nov 15 12:57:02 b2c kernel: Booting processor 2/8 APIC 0x22
Nov 15 12:57:02 b2c kernel: Initializing CPU#2
Nov 15 12:57:02 b2c kernel: Calibrating delay using timer specific routine.. 4256.06 BogoMIPS (lpj=2128033)
Nov 15 12:57:02 b2c kernel: CPU 2/22 -> Node 0
Nov 15 12:57:02 b2c kernel: CPU: Processor Core ID: 1
Nov 15 12:57:02 b2c kernel: Booting processor 3/8 APIC 0x2
Nov 15 12:57:02 b2c kernel: Initializing CPU#3
Nov 15 12:57:02 b2c kernel: Calibrating delay using timer specific routine.. 4256.07 BogoMIPS (lpj=2128038)
Nov 15 12:57:02 b2c kernel: CPU 3/2 -> Node 1
Nov 15 12:57:02 b2c kernel: Booting processor 4/8 APIC 0x32
Nov 15 12:57:02 b2c kernel: Initializing CPU#4
Nov 15 12:57:02 b2c kernel: Calibrating delay using timer specific routine.. 4256.04 BogoMIPS (lpj=2128023)
Nov 15 12:57:02 b2c kernel: CPU 4/32 -> Node 0
Nov 15 12:57:02 b2c kernel: CPU: Processor Core ID: 9
Nov 15 12:57:02 b2c kernel: Booting processor 5/8 APIC 0x12
Nov 15 12:57:02 b2c kernel: Initializing CPU#5
Nov 15 12:57:02 b2c kernel: Calibrating delay using timer specific routine.. 4255.94 BogoMIPS (lpj=2127971)
Nov 15 12:57:02 b2c kernel: CPU 5/12 -> Node 1
Nov 15 12:57:02 b2c kernel: Booting processor 6/8 APIC 0x34
Nov 15 12:57:02 b2c kernel: Initializing CPU#6
Nov 15 12:57:02 b2c kernel: Calibrating delay using timer specific routine.. 4256.05 BogoMIPS (lpj=2128029)
Nov 15 12:57:02 b2c kernel: CPU 6/34 -> Node 0
Nov 15 12:57:02 b2c kernel: CPU: Processor Core ID: 10
Nov 15 12:57:02 b2c kernel: Booting processor 7/8 APIC 0x14
Nov 15 12:57:02 b2c kernel: Initializing CPU#7
Nov 15 12:57:02 b2c kernel: Calibrating delay using timer specific routine.. 4256.05 BogoMIPS (lpj=2128025)
Nov 15 12:57:02 b2c kernel: CPU 7/14 -> Node 1
Nov 15 12:57:02 b2c kernel: Brought up 8 CPUs作者: ggqb 時(shí)間: 2012-11-15 13:35
Nov 15 12:57:02 b2c kernel: Brought up 8 CPUs作者: ggqb 時(shí)間: 2012-11-15 13:37
Nov 15 12:57:02 b2c kernel: NMI watchdog testing PASSED.
Nov 15 12:57:02 b2c kernel: time.c: Using 14.318180 MHz WALL HPET GTOD HPET/TSC timer.
Nov 15 12:57:02 b2c kernel: time.c: Detected 2128.054 MHz processor.
Nov 15 12:57:02 b2c kernel: migration_cost=9,737
Nov 15 12:57:02 b2c kernel: checking if image is initramfs... it is
Nov 15 12:57:02 b2c kernel: Freeing initrd memory: 3532k freed
Nov 15 12:57:02 b2c kernel: NET: Registered protocol family 16
Nov 15 12:57:02 b2c kernel: ACPI: bus type pci registered
Nov 15 12:57:02 b2c kernel: PCI: Using MMCONFIG at e0000000
Nov 15 12:57:02 b2c kernel: ACPI: Interpreter enabled
Nov 15 12:57:02 b2c kernel: ACPI: Using IOAPIC for interrupt routing
Nov 15 12:57:02 b2c kernel: ACPI: No dock devices found.
Nov 15 12:57:02 b2c kernel: ACPI: PCI Root Bridge [PCI0] (0000:00)
Nov 15 12:57:02 b2c kernel: PCI: Transparent bridge - 0000:00:1e.0
Nov 15 12:57:02 b2c kernel: ACPI: PCI Interrupt Link [LK00] (IRQs 3 4 5 6 7 10 11 14 *15)
Nov 15 12:57:02 b2c kernel: ACPI: PCI Interrupt Link [LK01] (IRQs 3 4 5 6 7 10 11 *14 15)
Nov 15 12:57:02 b2c kernel: ACPI: PCI Interrupt Link [LK02] (IRQs 3 4 5 6 7 10 *11 14 15)
Nov 15 12:57:02 b2c kernel: ACPI: PCI Interrupt Link [LK03] (IRQs 3 4 5 6 7 *10 11 14 15)
Nov 15 12:57:02 b2c kernel: ACPI: PCI Interrupt Link [LK04] (IRQs 3 4 *5 6 7 10 11 14 15)
Nov 15 12:57:02 b2c kernel: ACPI: PCI Interrupt Link [LK05] (IRQs 3 4 5 *6 7 10 11 14 15)
Nov 15 12:57:02 b2c kernel: ACPI: PCI Interrupt Link [LK06] (IRQs 3 4 5 6 7 10 11 14 15) *0, disabled.
Nov 15 12:57:02 b2c kernel: ACPI: PCI Interrupt Link [LK07] (IRQs 3 4 5 6 7 10 11 *14 15)
Nov 15 12:57:02 b2c kernel: Linux Plug and Play Support v0.97 (c) Adam Belay
Nov 15 12:57:02 b2c kernel: pnp: PnP ACPI init
Nov 15 12:57:02 b2c kernel: pnp: PnP ACPI: found 12 devices
Nov 15 12:57:02 b2c kernel: usbcore: registered new driver usbfs
Nov 15 12:57:02 b2c kernel: usbcore: registered new driver hub
Nov 15 12:57:02 b2c kernel: PCI: Using ACPI for IRQ routing
Nov 15 12:57:02 b2c kernel: PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
Nov 15 12:57:02 b2c kernel: NetLabel: Initializing
Nov 15 12:57:02 b2c kernel: NetLabel: domain hash size = 128
Nov 15 12:57:02 b2c kernel: NetLabel: protocols = UNLABELED CIPSOv4
Nov 15 12:57:02 b2c kernel: NetLabel: unlabeled traffic allowed by default
Nov 15 12:57:02 b2c kernel: hpet0: at MMIO 0xfed00000 (virtual 0xffffffffff5fe000), IRQs 2, 8, 0, 0
Nov 15 12:57:02 b2c kernel: hpet0: 4 64-bit timers, 14318180 Hz
Nov 15 12:57:02 b2c kernel: PCI-GART: No AMD northbridge found.
Nov 15 12:57:02 b2c kernel: pnp: 00:07: ioport range 0x800-0x87f could not be reserved
Nov 15 12:57:02 b2c kernel: pnp: 00:07: ioport range 0x880-0x8ff has been reserved
Nov 15 12:57:02 b2c kernel: pnp: 00:07: ioport range 0x900-0x91f has been reserved
Nov 15 12:57:02 b2c kernel: pnp: 00:07: ioport range 0x920-0x923 has been reserved
Nov 15 12:57:02 b2c kernel: pnp: 00:07: ioport range 0x924-0x924 has been reserved
Nov 15 12:57:02 b2c kernel: pnp: 00:07: ioport range 0xc00-0xc7f has been reserved
Nov 15 12:57:02 b2c kernel: pnp: 00:07: ioport range 0xca0-0xca7 has been reserved
Nov 15 12:57:02 b2c kernel: pnp: 00:08: ioport range 0xca8-0xca8 has been reserved
Nov 15 12:57:02 b2c kernel: pnp: 00:08: ioport range 0xcac-0xcac has been reserved
Nov 15 12:57:02 b2c kernel: pnp: 00:09: iomem range 0xe0000000-0xefffffff has been reserved
Nov 15 12:57:02 b2c kernel: pnp: 00:0b: iomem range 0xfed90000-0xfed91fff has been reserved
Nov 15 12:57:02 b2c kernel: PCI: Bridge: 0000:00:01.0
Nov 15 12:57:02 b2c kernel: IO window: disabled.
Nov 15 12:57:02 b2c kernel: MEM window: d6000000-d9ffffff
Nov 15 12:57:02 b2c kernel: PREFETCH window: disabled.
Nov 15 12:57:02 b2c kernel: PCI: Bridge: 0000:00:03.0
Nov 15 12:57:02 b2c kernel: MEM window: da000000-ddffffff
Nov 15 12:57:02 b2c kernel: PCI: Bridge: 0000:00:04.0
Nov 15 12:57:02 b2c kernel: IO window: f000-ffff
Nov 15 12:57:02 b2c kernel: MEM window: df100000-df2fffff
Nov 15 12:57:02 b2c kernel: PCI: Bridge: 0000:00:05.0
Nov 15 12:57:02 b2c kernel: MEM window: disabled.
Nov 15 12:57:02 b2c kernel: PCI: Bridge: 0000:00:06.0
Nov 15 12:57:02 b2c kernel: PCI: Bridge: 0000:00:07.0
Nov 15 12:57:02 b2c kernel: PCI: Bridge: 0000:00:09.0
Nov 15 12:57:02 b2c kernel: PCI: Bridge: 0000:00:1e.0
Nov 15 12:57:02 b2c kernel: MEM window: de000000-deffffff
Nov 15 12:57:02 b2c kernel: PREFETCH window 0x00000000d5800000-0x00000000d5ffffff
Nov 15 12:57:02 b2c kernel: GSI 16 sharing vector 0xA9 and IRQ 16
Nov 15 12:57:02 b2c kernel: ACPI: PCI Interrupt 0000:00:01.0[A] -> GSI 53 (level, low) -> IRQ 169
Nov 15 12:57:02 b2c kernel: ACPI: PCI Interrupt 0000:00:03.0[A] -> GSI 53 (level, low) -> IRQ 169
Nov 15 12:57:02 b2c kernel: ACPI: PCI Interrupt 0000:00:04.0[A] -> GSI 53 (level, low) -> IRQ 169
Nov 15 12:57:02 b2c kernel: ACPI: PCI Interrupt 0000:00:05.0[A] -> GSI 53 (level, low) -> IRQ 169
Nov 15 12:57:02 b2c kernel: ACPI: PCI Interrupt 0000:00:06.0[A] -> GSI 53 (level, low) -> IRQ 169
Nov 15 12:57:02 b2c kernel: ACPI: PCI Interrupt 0000:00:07.0[A] -> GSI 53 (level, low) -> IRQ 169
Nov 15 12:57:02 b2c kernel: ACPI: PCI Interrupt 0000:00:09.0[A] -> GSI 53 (level, low) -> IRQ 169
Nov 15 12:57:02 b2c kernel: NET: Registered protocol family 2
Nov 15 12:57:02 b2c kernel: IP route cache hash table entries: 524288 (order: 10, 4194304 bytes)
Nov 15 12:57:02 b2c kernel: TCP established hash table entries: 262144 (order: 10, 4194304 bytes)
Nov 15 12:57:02 b2c kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
Nov 15 12:57:02 b2c kernel: TCP: Hash tables configured (established 262144 bind 65536)
Nov 15 12:57:02 b2c kernel: TCP reno registered
Nov 15 12:57:02 b2c kernel: audit: initializing netlink socket (disabled)
Nov 15 12:57:02 b2c kernel: type=2000 audit(1352955347.956:1): initialized
Nov 15 12:57:02 b2c kernel: Total HugeTLB memory allocated, 0
Nov 15 12:57:02 b2c kernel: VFS: Disk quotas dquot_6.5.1
Nov 15 12:57:02 b2c kernel: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Nov 15 12:57:02 b2c kernel: Initializing Cryptographic API
Nov 15 12:57:02 b2c kernel: alg: No test for crc32c (crc32c-generic)
Nov 15 12:57:02 b2c kernel: ksign: Installing public key data
Nov 15 12:57:02 b2c kernel: Loading keyring
Nov 15 12:57:02 b2c kernel: - Added public key 48D0A1FBAE482C4C
Nov 15 12:57:02 b2c kernel: - User ID: CentOS (Kernel Module GPG key)
Nov 15 12:57:02 b2c kernel: io scheduler noop registered
Nov 15 12:57:02 b2c kernel: io scheduler anticipatory registered
Nov 15 12:57:02 b2c kernel: io scheduler deadline registered
Nov 15 12:57:02 b2c kernel: io scheduler cfq registered (default)
Nov 15 12:57:02 b2c kernel: pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Nov 15 12:57:02 b2c kernel: ACPI: CPU0 (power states: C1[C1] C2[C3])
Nov 15 12:57:02 b2c kernel: ACPI: CPU1 (power states: C1[C1] C2[C3])
Nov 15 12:57:02 b2c kernel: ACPI: CPU2 (power states: C1[C1] C2[C3])
Nov 15 12:57:02 b2c kernel: ACPI: CPU3 (power states: C1[C1] C2[C3])
Nov 15 12:57:02 b2c kernel: ACPI: CPU4 (power states: C1[C1] C2[C3])
Nov 15 12:57:02 b2c kernel: ACPI: CPU5 (power states: C1[C1] C2[C3])
Nov 15 12:57:02 b2c kernel: ACPI: CPU6 (power states: C1[C1] C2[C3])
Nov 15 12:57:02 b2c kernel: ACPI: CPU7 (power states: C1[C1] C2[C3])
Nov 15 12:57:02 b2c kernel: Real Time Clock Driver v1.12ac
Nov 15 12:57:02 b2c kernel: Non-volatile memory driver v1.2
Nov 15 12:57:02 b2c kernel: Linux agpgart interface v0.101 (c) Dave Jones
Nov 15 12:57:02 b2c kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
Nov 15 12:57:02 b2c kernel: serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Nov 15 12:57:02 b2c kernel: serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Nov 15 12:57:02 b2c kernel: 00:05: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Nov 15 12:57:02 b2c kernel: 00:06: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Nov 15 12:57:02 b2c kernel: brd: module loaded
Nov 15 12:57:02 b2c kernel: Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
Nov 15 12:57:02 b2c kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Nov 15 12:57:02 b2c kernel: ide-floppy driver 0.99.newide
Nov 15 12:57:02 b2c kernel: usbcore: registered new driver hiddev作者: admin 時(shí)間: 2012-11-15 16:52
