標(biāo)題: [求助] wdOS斷電過一次,日志一直出現(xiàn)這個(gè),不知道怎么解決啊 [打印本頁]
作者: uyuwei    時(shí)間: 2013-1-22 13:01     標(biāo)題: wdOS斷電過一次,日志一直出現(xiàn)這個(gè),不知道怎么解決啊
本帖最后由 uyuwei 于 2013-1-22 16:43 編輯
  1. Jan 22 08:36:18 wdOS smartd[2721]: Device: /dev/sda, 8 Currently unreadable (pending) sectors
  2. Jan 22 08:36:18 wdOS smartd[2721]: Device: /dev/sda, 8 Offline uncorrectable sectors
  3. Jan 22 09:06:18 wdOS smartd[2721]: Device: /dev/sda, 8 Currently unreadable (pending) sectors
  4. Jan 22 09:06:18 wdOS smartd[2721]: Device: /dev/sda, 8 Offline uncorrectable sectors
  5. Jan 22 09:36:18 wdOS smartd[2721]: Device: /dev/sda, 8 Currently unreadable (pending) sectors
  6. Jan 22 09:36:18 wdOS smartd[2721]: Device: /dev/sda, 8 Offline uncorrectable sectors
  7. Jan 22 10:06:18 wdOS smartd[2721]: Device: /dev/sda, 8 Currently unreadable (pending) sectors
  8. Jan 22 10:06:18 wdOS smartd[2721]: Device: /dev/sda, 8 Offline uncorrectable sectors
  9. Jan 22 10:36:18 wdOS smartd[2721]: Device: /dev/sda, 8 Currently unreadable (pending) sectors
  10. Jan 22 10:36:18 wdOS smartd[2721]: Device: /dev/sda, 8 Offline uncorrectable sectors
  11. Jan 22 11:06:18 wdOS smartd[2721]: Device: /dev/sda, 8 Currently unreadable (pending) sectors
  12. Jan 22 11:06:18 wdOS smartd[2721]: Device: /dev/sda, 8 Offline uncorrectable sectors
  13. Jan 22 11:36:18 wdOS smartd[2721]: Device: /dev/sda, 8 Currently unreadable (pending) sectors
  14. Jan 22 11:36:18 wdOS smartd[2721]: Device: /dev/sda, 8 Offline uncorrectable sectors
  15. Jan 22 12:06:18 wdOS smartd[2721]: Device: /dev/sda, 8 Currently unreadable (pending) sectors
  16. Jan 22 12:06:18 wdOS smartd[2721]: Device: /dev/sda, 8 Offline uncorrectable sectors
  17. Jan 22 12:36:18 wdOS smartd[2721]: Device: /dev/sda, 8 Currently unreadable (pending) sectors
  18. Jan 22 12:36:18 wdOS smartd[2721]: Device: /dev/sda, 8 Offline uncorrectable sectors
連續(xù)幾天了,有時(shí)突然出現(xiàn)斷線,網(wǎng)站進(jìn)不去,wdcp面板403錯(cuò)誤,SSH連接提示Server unexpectedly closed network connection,重啟服務(wù)器之后正常,一段時(shí)間后再次斷線?是硬盤扇區(qū)的問題么?應(yīng)該怎么修復(fù)?
順便問下如何防止SSH暴力破解,或者說如何限制某IP多次嘗試SSH登陸
作者: admin    時(shí)間: 2013-1-22 18:45
硬盤問題不好修復(fù).可以找些硬盤修復(fù)工具試試看
作者: uyuwei    時(shí)間: 2013-1-22 19:37
我是新手啊,老大介紹下適合新手的工具
作者: itxx    時(shí)間: 2013-1-30 21:23
似乎這塊磁盤已經(jīng)有壞道了,換新的吧。
