標(biāo)題: [求助] 無法啟動(dòng)named [打印本頁]
作者: netahui    時(shí)間: 2016-1-22 18:39     標(biāo)題: 無法啟動(dòng)named
啟動(dòng)顯示如下:
Starting named:                                            [FAILED]
相關(guān)日志如下:
Jan 22 18:31:09 ddfeec named[1956]: starting BIND 9.8.0-P4 -u named -c /www/wdlinux/bind/etc/named.conf
Jan 22 18:31:09 ddfeec named[1956]: built with '--prefix=/www/wdlinux/bind-9.8.0-P4' '--with-dlz-mysql=/www/wdlinux/mysql' '--enable-largefile' '--with-openssl=yes'
Jan 22 18:31:09 ddfeec named[1956]: using up to 4096 sockets
Jan 22 18:31:09 ddfeec named[1956]: loading configuration from '/www/wdlinux/bind/etc/named.conf'
Jan 22 18:31:09 ddfeec named[1956]: /www/wdlinux/bind/etc/wddns_view.conf:109: unknown option 's='0''
Jan 22 18:31:09 ddfeec named[1956]: /www/wdlinux/bind/etc/wddns_view.conf:109: unexpected token near '}'
Jan 22 18:31:09 ddfeec named[1956]: loading configuration: unexpected token
Jan 22 18:31:09 ddfeec named[1956]: exiting (due to fatal error)
作者: xmmaster7    時(shí)間: 2016-6-20 17:11
我也遇到這個(gè)問題了
