[分享]
memched正確食用指南
[打印本頁(yè)]
luqiqi
memched正確食用指南
#!/bin/bash
# Memcache install scripts
# Author:wdlinux
# Url http://www.szkyjg.com
echo "Select php version:
1 php-5.2.17 (default)
2 php-5.3.27
sleep 0.1
read -p "Please Input 1,2: " PHP_VER_ID
if [[ $PHP_VER_ID == 2 ]]; then
PHP_VER="5.3.27"
ext_dir="no-debug-non-zts-20090626"
else
PHP_VER="5.2.17"
ext_dir="no-debug-zts-20060613"
fi
TOP=$(cd $(dirname $0)/.. && pwd)
if [ ! -f /usr/bin/gcc ]; then
yum install -y gcc gcc-c++ make autoconf libtool-ltdl-devel \
gd-devel freetype-devel libxml2-devel libjpeg-devel \
libpng-devel openssl-devel curl-devel patch libmcrypt-devel \
libmhash-devel ncurses-devel sudo bzip2
fi
yum install -y zlib-devel
cd /tmp
wget -c http://dl.wdlinux.cn:5180/soft/libevent-1.4.14b-stable.tar.gz
wget -c http://www.memcached.org/files/memcached-1.4.24.tar.gz
wget -c http://pecl.php.net/get/memcache-2.2.7.tgz
tar xf libevent-1.4.14b-stable.tar.gz
cd libevent-1.4.14b-stable
./configure --prefix=/usr
make
[ $? != 0 ] && exit
make install
cd ..
tar xf memcached-1.4.24.tar.gz
cd memcached-1.4.24
./configure --prefix=/www/wdlinux/memcached --with-libevent=/usr
make
[ $? != 0 ] && exit
make install
cd ..
if grep -qi 'debian\|ubuntu' /etc/issue; then
wget http://www.szkyjg.com/conf/init.d/init.memcached-ubuntu -O /www/wdlinux/init.d/memcached
chmod 755 /www/wdlinux/init.d/memcached
ln -s /www/wdlinux/init.d/memcached /etc/init.d/memcached
update-rc.d -f memcached defaults
update-rc.d -f memcached enable 235
else
wget http://www.szkyjg.com/conf/init.d/init.memcached -O /www/wdlinux/init.d/memcached
chkconfig --level 35 memcached on
fi
touch /www/wdlinux/etc/memcached.conf
service memcached start
tar zxvf memcache-2.2.7.tgz
cd memcache-2.2.7
/www/wdlinux/php/bin/phpize
./configure --enable-memcache --with-php-config=/www/wdlinux/php/bin/php-config --with-zlib-dir
make
[ $? != 0 ] && exit
make install
grep -q 'memcache.so' /www/wdlinux/etc/php.ini
if [ $? != 0 ]; then
echo "
[memcache]
extension_dir ="/www/wdlinux/php/lib/php/extensions/$ext_dir"
extension=memcache.so" >> /www/wdlinux/etc/php.ini
fi
if [ -d /www/wdlinux/apache ]; then
service httpd restart
else
service nginxd restart
fi
echo
echo "memcache install is OK"
echo
修改了第二個(gè)包的地址,保存為memcached.sh,一定行
很好
