標(biāo)題: [BUG反饋] 升級nginx,官方腳本報錯 [打印本頁]
作者: 純潔滴色魔    時間: 2013-3-31 18:15     標(biāo)題: 升級nginx,官方腳本報錯
./configure: error: the HTTP rewrite module requires the PCRE library.
You can either disable the module by using --without-http_rewrite_module
option, or install the PCRE library into the system, or build the PCRE library
statically from the source with nginx by using --with-pcre=<path> option.
作者: 純潔滴色魔    時間: 2013-3-31 18:21
已經(jīng)搞定了。。木有GCC編譯器。。。
wget http://down.wdlinux.cn/in/pcre_ins.sh
sh pcre_ins.sh
執(zhí)行完后,再升級nginx
就好用了
