標(biāo)題: [求助] 求阿里云ubuntu 12.04 如何升級(jí)php5.4或5.6方法 [打印本頁(yè)]
作者: 317607087    時(shí)間: 2017-1-22 16:21     標(biāo)題: 求阿里云ubuntu 12.04 如何升級(jí)php5.4或5.6方法
找了很多遍,就是解決不掉,本地測(cè)試可以升級(jí),但是到阿里云ubuntu 12.04就是無(wú)法升級(jí) 采用老左或老蔣的方法都不可以
Configuring extensions
checking size of long... (cached) 8
checking size of int... (cached) 4
checking for int32_t... yes
checking for uint32_t... yes
checking for sys/types.h... (cached) yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking for string.h... (cached) yes
checking for stdlib.h... (cached) yes
checking for strtoll... yes
checking for atoll... yes
checking for strftime... (cached) yes
checking which regex library to use... php
checking whether to enable LIBXML support... yes
checking libxml2 install dir... /usr
checking for xml2-config path... /usr/bin/xml2-config
checking whether libxml build works... yes
checking for OpenSSL support... yes
checking for Kerberos support... no
checking whether to use system default cipher list instead of hardcoded value... no
checking for DSA_get_default_method in -lssl... no
checking for X509_free in -lcrypto... yes
checking for RAND_egd... no
checking for pkg-config... /usr/bin/pkg-config
checking for PCRE library to use... bundled
checking whether to enable the SQLite3 extension... yes
checking bundled sqlite3 library... yes
checking for ZLIB support... yes
checking if the location of ZLIB install directory is defined... no
checking for zlib version >= 1.2.0.4... 1.2.3.4
checking for gzgets in -lz... yes
checking whether to enable bc style precision math functions... yes
checking for BZip2 support... no
checking whether to enable calendar conversion support... no
checking whether to enable ctype functions... yes
checking for cURL support... yes
checking for cURL in default path... found in /usr
checking for cURL 7.10.5 or greater... libcurl 7.22.0
checking for SSL support in libcurl... yes
checking how to run the C preprocessor... cc -E
checking for openssl support in libcurl... no
checking for gnutls support in libcurl... no
checking for curl_easy_perform in -lcurl... no
configure: error: There is something wrong. Please check config.log for more information.
NO! CONFIGURE ERROR! TRY AGAIN OR ASK IN THE BBS! :(
到這步就不行
求大神解決
