----Install Error: mysql configure err -----------
PING www.szkyjg.com (119.146.223.143) 56(84) bytes of data.
From 10.5.1.175 icmp_seq=1 Time to live exceeded
--- www.szkyjg.com ping statistics ---
1 packets transmitted, 0 received, +1 errors, 100% packet loss, time 0ms
diffutils-2.8.1-16.el5.x86_64: failure: CentOS/diffutils-2.8.1-16.el5.x86_64.rpm from base: [Errno 256] No more mirrors to try.
libgcc-4.1.2-54.el5.x86_64: failure: CentOS/libgcc-4.1.2-54.el5.x86_64.rpm from base: [Errno 256] No more mirrors to try.
2:libpng-devel-1.2.10-17.el5_8.x86_64: failure: CentOS/libpng-devel-1.2.10-17.el5_8.x86_64.rpm from base: [Errno 256] No more mirrors to try.
libtool-ltdl-1.5.22-7.el5_4.i386: failure: CentOS/libtool-ltdl-1.5.22-7.el5_4.i386.rpm from base: [Errno 256] No more mirrors to try.
freetype-devel-2.2.1-32.el5_9.1.x86_64: failure: RPMS/freetype-devel-2.2.1-32.el5_9.1.x86_64.rpm from updates: [Errno 256] No more mirrors to try.
nscd-2.5-107.el5_9.4.x86_64: failure: RPMS/nscd-2.5-107.el5_9.4.x86_64.rpm from updates: [Errno 256] No more mirrors to try.
libtool-ltdl-devel-1.5.22-7.el5_4.i386: failure: CentOS/libtool-ltdl-devel-1.5.22-7.el5_4.i386.rpm from base: [Errno 256] No more mirrors to try.
curl-devel-7.15.5-16.el5_9.i386: failure: RPMS/curl-devel-7.15.5-16.el5_9.i386.rpm from updates: [Errno 256] No more mirrors to try.
libmcrypt-devel-2.5.8-4.el5.centos.x86_64: failure: RPMS/libmcrypt-devel-2.5.8-4.el5.centos.x86_64.rpm from extras: [Errno 256] No more mirrors to try.
libmcrypt-2.5.8-4.el5.centos.x86_64: failure: RPMS/libmcrypt-2.5.8-4.el5.centos.x86_64.rpm from extras: [Errno 256] No more mirrors to try.
libjpeg-devel-6b-37.i386: failure: CentOS/libjpeg-devel-6b-37.i386.rpm from base: [Errno 256] No more mirrors to try.
curl-7.15.5-16.el5_9.i386: failure: RPMS/curl-7.15.5-16.el5_9.i386.rpm from updates: [Errno 256] No more mirrors to try.
gd-devel-2.0.33-9.4.el5_4.2.i386: failure: CentOS/gd-devel-2.0.33-9.4.el5_4.2.i386.rpm from base: [Errno 256] No more mirrors to try.
2:libpng-1.2.10-17.el5_8.i386: failure: CentOS/libpng-1.2.10-17.el5_8.i386.rpm from base: [Errno 256] No more mirrors to try.
freetype-2.2.1-32.el5_9.1.x86_64: failure: RPMS/freetype-2.2.1-32.el5_9.1.x86_64.rpm from updates: [Errno 256] No more mirrors to try.
curl-devel-7.15.5-16.el5_9.x86_64: failure: RPMS/curl-devel-7.15.5-16.el5_9.x86_64.rpm from updates: [Errno 256] No more mirrors to try.
freetype-devel-2.2.1-32.el5_9.1.i386: failure: RPMS/freetype-devel-2.2.1-32.el5_9.1.i386.rpm from updates: [Errno 256] No more mirrors to try.
curl-7.15.5-16.el5_9.x86_64: failure: RPMS/curl-7.15.5-16.el5_9.x86_64.rpm from updates: [Errno 256] No more mirrors to try.
gd-2.0.33-9.4.el5_4.2.i386: failure: CentOS/gd-2.0.33-9.4.el5_4.2.i386.rpm from base: [Errno 256] No more mirrors to try.
libXpm-devel-3.5.5-3.x86_64: failure: CentOS/libXpm-devel-3.5.5-3.x86_64.rpm from base: [Errno 256] No more mirrors to try.
gd-2.0.33-9.4.el5_4.2.x86_64: failure: CentOS/gd-2.0.33-9.4.el5_4.2.x86_64.rpm from base: [Errno 256] No more mirrors to try.
freetype-2.2.1-32.el5_9.1.i386: failure: RPMS/freetype-2.2.1-32.el5_9.1.i386.rpm from updates: [Errno 256] No more mirrors to try.
mhash-devel-0.9.9-1.el5.rf.x86_64: failure: RPMS/mhash-devel-0.9.9-1.el5.rf.x86_64.rpm from rpmforge: [Errno 256] No more mirrors to try.
2:libpng-1.2.10-17.el5_8.x86_64: failure: CentOS/libpng-1.2.10-17.el5_8.x86_64.rpm from base: [Errno 256] No more mirrors to try.
libcap-devel-1.10-26.i386: failure: CentOS/libcap-devel-1.10-26.i386.rpm from base: [Errno 256] No more mirrors to try.
libtool-ltdl-devel-1.5.22-7.el5_4.x86_64: failure: CentOS/libtool-ltdl-devel-1.5.22-7.el5_4.x86_64.rpm from base: [Errno 256] No more mirrors to try.
libtool-ltdl-1.5.22-7.el5_4.x86_64: failure: CentOS/libtool-ltdl-1.5.22-7.el5_4.x86_64.rpm from base: [Errno 256] No more mirrors to try.
libidn-devel-0.6.5-1.1.x86_64: failure: CentOS/libidn-devel-0.6.5-1.1.x86_64.rpm from base: [Errno 256] No more mirrors to try.
2:libpng-devel-1.2.10-17.el5_8.i386: failure: CentOS/libpng-devel-1.2.10-17.el5_8.i386.rpm from base: [Errno 256] No more mirrors to try.
libXpm-3.5.5-3.i386: failure: CentOS/libXpm-3.5.5-3.i386.rpm from base: [Errno 256] No more mirrors to try.
libgcc-4.1.2-54.el5.i386: failure: CentOS/libgcc-4.1.2-54.el5.i386.rpm from base: [Errno 256] No more mirrors to try.
gd-devel-2.0.33-9.4.el5_4.2.x86_64: failure: CentOS/gd-devel-2.0.33-9.4.el5_4.2.x86_64.rpm from base: [Errno 256] No more mirrors to try.
8 May 16:07:41 ntpdate[4058]: step time server 218.30.114.84 offset 2.018276 sec
setenforce: SELinux is disabled
httpd: unrecognized service
mysqld: unrecognized service
error reading information on service httpd: No such file or directory
error reading information on service mysqld: No such file or directory
installing mysql...
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking how to create a ustar tar archive... gnutar
checking for style of include used by make... GNU
checking for gcc... no
checking for cc... no
checking for cl.exe... configure: error: in `/home/lanmp/mysql-5.1.63':
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details.
no
Preparing... package rpmforge-release-0.5.2-2.el5.rf.x86_64 is already installed
Loaded plugins: fastestmirror
* base: mirrors.btte.net
* extras: mirrors.btte.net
* rpmforge: mirror.oscc.org.my
* updates: mirrors.btte.net
no
[root@localhost ~]# wget http://dl.wdlinux.cn:5180/lanmp_laster.tar.gz
-bash: wget: command not found
[root@localhost ~]# tar zxvf lanmp_laster.tar.gz
tar (child): lanmp_laster.tar.gz:無法 open: 沒有那個(gè)文件或目錄
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
[root@localhost ~]# sh install.sh
