eaccelerator編譯不成功,求助
longyushen
2013-4-23 01:03
本帖最后由 longyushen 于 2013-4-23 01:05 編輯
eaccelerator編譯不成功,求助日志在附件
eaccelerator.zip
(3.04 KB)
下載次數(shù): 2
2013-4-23 01:02
下載消耗 金幣 1
或者繼續(xù)看2F和3F,由于限制長度,所以分開兩回帖發(fā),謝謝諒解
附件:
eaccelerator.zip
(2013-4-23 01:02, 3.04 KB) / 下載次數(shù) 2
http://www.szkyjg.com/bbs/attachment.php?aid=2850&k=3889549d1264cc808326012144217484&t=1746336007&sid=256lF7
longyushen
2013-4-23 01:04
--2013-04-23 00:54:57-- http://soft.vpser.net/web/eaccelerator/eaccelerator-0.9.5.3.tar.bz2
Resolving soft.vpser.net... 96.44.153.111
Connecting to soft.vpser.net|96.44.153.111|:80... connected.
HTTP request sent, awaiting response... 416 Requested Range Not Satisfiable
The file is already fully retrieved; nothing to do.
eaccelerator-0.9.5.3/
eaccelerator-0.9.5.3/run-tests.php
eaccelerator-0.9.5.3/shm.c
eaccelerator-0.9.5.3/modules/
eaccelerator-0.9.5.3/x86_spinlocks.h
eaccelerator-0.9.5.3/COPYING
eaccelerator-0.9.5.3/ea_info.c
eaccelerator-0.9.5.3/install-sh
eaccelerator-0.9.5.3/ea_restore.h
eaccelerator-0.9.5.3/Makefile.global
eaccelerator-0.9.5.3/config.h.in
eaccelerator-0.9.5.3/configure.in
eaccelerator-0.9.5.3/config.m4
eaccelerator-0.9.5.3/build/
eaccelerator-0.9.5.3/build/libtool.m4
eaccelerator-0.9.5.3/build/scan_makefile_in.awk
eaccelerator-0.9.5.3/build/mkdep.awk
eaccelerator-0.9.5.3/build/shtool
eaccelerator-0.9.5.3/debug.c
eaccelerator-0.9.5.3/Makefile.fragments
eaccelerator-0.9.5.3/config.w32
eaccelerator-0.9.5.3/mm.h
eaccelerator-0.9.5.3/opcodes.c
eaccelerator-0.9.5.3/session.h
eaccelerator-0.9.5.3/win32/
eaccelerator-0.9.5.3/win32/eLoader.vcproj
eaccelerator-0.9.5.3/win32/eAccelerator.dsw
eaccelerator-0.9.5.3/win32/eAccelerator.sln
eaccelerator-0.9.5.3/win32/eAccelerator.dsp
eaccelerator-0.9.5.3/win32/eAccelerator.vcproj
eaccelerator-0.9.5.3/win32/eLoader.dsp
eaccelerator-0.9.5.3/ea_info.h
eaccelerator-0.9.5.3/config.guess
eaccelerator-0.9.5.3/Makefile.in
eaccelerator-0.9.5.3/ea_restore.c
eaccelerator-0.9.5.3/eLoader/
eaccelerator-0.9.5.3/eLoader/config.m4
eaccelerator-0.9.5.3/eLoader/Makefile.in
eaccelerator-0.9.5.3/eLoader/autogen.sh
eaccelerator-0.9.5.3/autom4te.cache/
eaccelerator-0.9.5.3/autom4te.cache/output.0
eaccelerator-0.9.5.3/autom4te.cache/requests
eaccelerator-0.9.5.3/autom4te.cache/traces.0
eaccelerator-0.9.5.3/content.c
eaccelerator-0.9.5.3/ea_dasm.h
eaccelerator-0.9.5.3/include/
eaccelerator-0.9.5.3/doc/
eaccelerator-0.9.5.3/doc/phpdoc.ini
eaccelerator-0.9.5.3/doc/php/
eaccelerator-0.9.5.3/doc/php/info.php
eaccelerator-0.9.5.3/doc/php/shared_memory.php
eaccelerator-0.9.5.3/doc/php/examples/
eaccelerator-0.9.5.3/doc/php/examples/eaccelerator_cache_output.php
eaccelerator-0.9.5.3/doc/php/examples/eaccelerator_cache_result.php
eaccelerator-0.9.5.3/doc/php/examples/eaccelerator_cache_page.php
eaccelerator-0.9.5.3/doc/php/examples/eaccelerator_lock.php
eaccelerator-0.9.5.3/doc/php/session.php
eaccelerator-0.9.5.3/doc/php/dasm.php
eaccelerator-0.9.5.3/doc/php/encoder.php
eaccelerator-0.9.5.3/doc/php/loader.php
eaccelerator-0.9.5.3/doc/php/cache.php
eaccelerator-0.9.5.3/config.log
eaccelerator-0.9.5.3/eaccelerator_version.h
eaccelerator-0.9.5.3/optimize.c
eaccelerator-0.9.5.3/missing
eaccelerator-0.9.5.3/README.win32
eaccelerator-0.9.5.3/config.status
eaccelerator-0.9.5.3/ltmain.sh
eaccelerator-0.9.5.3/loader.c
eaccelerator-0.9.5.3/ea_store.h
eaccelerator-0.9.5.3/bugreport.php
eaccelerator-0.9.5.3/cache.c
eaccelerator-0.9.5.3/mm.c
eaccelerator-0.9.5.3/PHP_Highlight.php
eaccelerator-0.9.5.3/mkinstalldirs
eaccelerator-0.9.5.3/cache.h
eaccelerator-0.9.5.3/control.php
eaccelerator-0.9.5.3/aclocal.m4
eaccelerator-0.9.5.3/session.c
eaccelerator-0.9.5.3/opcodes.h
eaccelerator-0.9.5.3/NEWS
eaccelerator-0.9.5.3/debug.h
eaccelerator-0.9.5.3/.deps
eaccelerator-0.9.5.3/content.h
eaccelerator-0.9.5.3/Makefile.objects
eaccelerator-0.9.5.3/dasm.php
eaccelerator-0.9.5.3/encoder.php
eaccelerator-0.9.5.3/config.nice
eaccelerator-0.9.5.3/eaccelerator.h
eaccelerator-0.9.5.3/shm.h
eaccelerator-0.9.5.3/acinclude.m4
eaccelerator-0.9.5.3/eaccelerator.c
eaccelerator-0.9.5.3/config.sub
eaccelerator-0.9.5.3/libtool
eaccelerator-0.9.5.3/AUTHORS
eaccelerator-0.9.5.3/README.eLoader
eaccelerator-0.9.5.3/ea_store.c
eaccelerator-0.9.5.3/encoder.c
eaccelerator-0.9.5.3/ea_dasm.c
eaccelerator-0.9.5.3/ChangeLog
eaccelerator-0.9.5.3/eaccelerator.ini
checking for gcc... gcc
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc and cc understand -c and -o together... yes
checking if compiler supports -R... no
checking if compiler supports -Wl,-rpath,... yes
checking for PHP prefix... /www/wdlinux/nginx_php-5.2.17
checking for PHP includes... -I/www/wdlinux/nginx_php-5.2.17/include/php -I/www/wdlinux/nginx_php-5.2.17/include/php/main -I/www/wdlinux/nginx_php-5.2.17/include/php/TSRM -I/www/wdlinux/nginx_php-5.2.17/include/php/Zend -I/www/wdlinux/nginx_php-5.2.17/include/php/ext -I/www/wdlinux/nginx_php-5.2.17/include/php/ext/date/lib
checking for PHP extension directory... /www/wdlinux/nginx_php-5.2.17/lib/php/extensions/no-debug-non-zts-20060613
checking for PHP installed headers prefix... /www/wdlinux/nginx_php-5.2.17/include/php
checking for re2c... no
configure: WARNING: You will need re2c 0.9.11 or later if you want to regenerate PHP parsers.
checking for gawk... gawk
checking whether to enable eaccelerator support... yes, shared
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for unistd.h... (cached) yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking sched.h usability... yes
checking sched.h presence... yes
checking for sched.h... yes
checking mandatory system headers... yes
checking whether union semun is defined in sys/sem.h... no
checking for sysvipc shared memory support... yes
checking for mmap shared memory support... yes
checking for mmap on /dev/zero shared memory support... yes
checking for anonymous mmap shared memory support... yes
checking for posix mmap shared memory support... no
checking for best shared memory type... anonymous mmap
checking for spinlock semaphores support... yes
checking for pthread semaphores support... no
checking for posix semaphores support... no
checking for sysvipc semaphores support... yes
checking for fcntl semaphores support... yes
checking for flock semaphores support... yes
checking for best semaphores type... spinlock
checking for sched_yield... yes
checking for mprotect... yes
checking for ext/session/php_session.h... yes
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... no
checking for g95... no
checking for xlf95... no
checking for f95... no
checking for fort... no
checking for ifort... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for ftn... no
longyushen
2013-4-23 01:04
checking whether we are using the GNU Fortran 77 compiler... no
checking whether accepts -g... no
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc static flag -static works... no
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ static flag -static works... no
checking if g++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
configure: creating ./config.status
config.status: creating config.h
/bin/sh /tmp/eaccelerator-0.9.5.3/libtool --mode=install cp ./eaccelerator.la /tmp/eaccelerator-0.9.5.3/modules
cp ./.libs/eaccelerator.so /tmp/eaccelerator-0.9.5.3/modules/eaccelerator.so
cp ./.libs/eaccelerator.lai /tmp/eaccelerator-0.9.5.3/modules/eaccelerator.la
PATH="$PATH:/sbin" ldconfig -n /tmp/eaccelerator-0.9.5.3/modules
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the `LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the `LD_RUN_PATH' environment variable
during linking
- use the `-Wl,--rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
Build complete.
Installing shared extensions: /www/wdlinux/nginx_php-5.2.17/lib/php/extensions/no-debug-non-zts-20060613/
Stopping nginx: [60G[[0;32m OK [0;39m]
Shutting down php_fpm . done
Starting nginx: [60G[[0;32m OK [0;39m]
Starting php_fpm done
2013-4-23 09:23
用哪個安裝的?
longyushen
2013-4-23 13:11
用哪個安裝的?
admin 發(fā)表于 2013-4-23 09:23
http://www.szkyjg.com/bbs/viewthread.php?tid=18
是安裝這個帖子搞的
2013-4-24 09:21
我看不像
