標(biāo)題: [BUG反饋] 502 報(bào)錯(cuò) 日志 請(qǐng)大師 幫分析啥原因 [打印本頁]
作者: ailonjien    時(shí)間: 2017-5-18 11:17     標(biāo)題: 502 報(bào)錯(cuò) 日志 請(qǐng)大師 幫分析啥原因
2017/05/18 11:04:11 [notice] 6387#0: signal process started
2017/05/18 11:04:11 [notice] 6398#0: using the "epoll" event method
2017/05/18 11:04:11 [notice] 6398#0: nginx/1.12.0
2017/05/18 11:04:11 [notice] 6398#0: built by gcc 4.8.5 20150623 (Red Hat 4.8.5-11) (GCC)
2017/05/18 11:04:11 [notice] 6398#0: OS: Linux 3.10.0-514.el7.x86_64
2017/05/18 11:04:11 [notice] 6398#0: getrlimit(RLIMIT_NOFILE): 1024:4096
2017/05/18 11:04:11 [notice] 6399#0: start worker processes
2017/05/18 11:04:11 [notice] 6399#0: start worker process 6400
2017/05/18 11:04:11 [notice] 6399#0: start worker process 6401
2017/05/18 11:04:11 [notice] 6399#0: start worker process 6402
2017/05/18 11:04:13 [error] 6400#0: *4 connect() to unix:/tmp/php-56-cgi.sock failed (111: Connection refused) while connecting to upstream, client: 1.1.1.1, server: XXXX.COM, request: "GET /ad4/ HTTP/1.1", upstream: "fastcgi://unix:/tmp/php-56-cgi.sock:",
啟用的是PHP多版本
