標(biāo)題: [求助] Install Error: mysql configure err [打印本頁]
作者: yunkaiai    時間: 2017-6-13 22:45     標(biāo)題: Install Error: mysql configure err
mysql-5.5.54/storage/perfschema/table_sync_instances.cc
mysql-5.5.54/storage/perfschema/table_sync_instances.h
mysql-5.5.54/storage/perfschema/table_threads.cc
mysql-5.5.54/storage/perfschema/table_threads.h
mysql-5.5.54/storage/perfschema/unittest/
mysql-5.5.54/storage/perfschema/unittest/CMakeLists.txt
mysql-5.5.54/storage/perfschema/unittest/conf.txt
mysql-5.5.54/storage/perfschema/unittest/pfs-t.cc
mysql-5.5.54/storage/perfschema/unittest/pfs_instr-oom-t.cc
mysql-5.5.54/storage/perfschema/unittest/pfs_instr-t.cc
mysql-5.5.54/storage/perfschema/unittest/pfs_instr_class-oom-t.cc
mysql-5.5.54/storage/perfschema/unittest/pfs_instr_class-t.cc
mysql-5.5.54/storage/perfschema/unittest/pfs_timer-t.cc
mysql-5.5.54/storage/perfschema/unittest/stub_pfs_global.h
mysql-5.5.54/storage/perfschema/unittest/stub_print_error.h
mysql-5.5.54/storage/perfschema/unittest/stub_server_misc.h
mysql-5.5.54/strings/
mysql-5.5.54/strings/CHARSET_INFO.txt
mysql-5.5.54/strings/CMakeLists.txt
mysql-5.5.54/strings/README
mysql-5.5.54/strings/bchange.c
mysql-5.5.54/strings/bmove_upp.c
mysql-5.5.54/strings/conf_to_src.c
mysql-5.5.54/strings/ctype-big5.c
mysql-5.5.54/strings/ctype-bin.c
mysql-5.5.54/strings/ctype-cp932.c
mysql-5.5.54/strings/ctype-czech.c
mysql-5.5.54/strings/ctype-euc_kr.c
mysql-5.5.54/strings/ctype-eucjpms.c
mysql-5.5.54/strings/ctype-extra.c
mysql-5.5.54/strings/ctype-gb2312.c
mysql-5.5.54/strings/ctype-gbk.c
mysql-5.5.54/strings/ctype-latin1.c
mysql-5.5.54/strings/ctype-mb.c
mysql-5.5.54/strings/ctype-simple.c
mysql-5.5.54/strings/ctype-sjis.c
mysql-5.5.54/strings/ctype-tis620.c
mysql-5.5.54/strings/ctype-uca.c
mysql-5.5.54/strings/ctype-ucs2.c
mysql-5.5.54/strings/ctype-ujis.c
mysql-5.5.54/strings/ctype-utf8.c
mysql-5.5.54/strings/ctype-win1250ch.c
mysql-5.5.54/strings/ctype.c
mysql-5.5.54/strings/decimal.c
mysql-5.5.54/strings/do_ctype.c
mysql-5.5.54/strings/dtoa.c
mysql-5.5.54/strings/dump_map.c
mysql-5.5.54/strings/int2str.c
mysql-5.5.54/strings/is_prefix.c
mysql-5.5.54/strings/latin2.def
mysql-5.5.54/strings/llstr.c
mysql-5.5.54/strings/longlong2str.c
mysql-5.5.54/strings/my_strchr.c
mysql-5.5.54/strings/my_strtoll10.c
mysql-5.5.54/strings/my_vsnprintf.c
mysql-5.5.54/strings/str2int.c
mysql-5.5.54/strings/str_alloc.c
mysql-5.5.54/strings/strappend.c
mysql-5.5.54/strings/strcend.c
mysql-5.5.54/strings/strcont.c
mysql-5.5.54/strings/strend.c
mysql-5.5.54/strings/strfill.c
mysql-5.5.54/strings/string.doc
mysql-5.5.54/strings/strmake.c
mysql-5.5.54/strings/strmov.c
mysql-5.5.54/strings/strnlen.c
mysql-5.5.54/strings/strnmov.c
mysql-5.5.54/strings/strxmov.c
mysql-5.5.54/strings/strxnmov.c
mysql-5.5.54/strings/t_ctype.h
mysql-5.5.54/strings/uca-dump.c
mysql-5.5.54/strings/uctypedump.c
mysql-5.5.54/strings/utr11-dump.c
mysql-5.5.54/strings/xml.c
mysql-5.5.54/support-files/
mysql-5.5.54/support-files/CMakeLists.txt
mysql-5.5.54/support-files/MacOSX/
mysql-5.5.54/support-files/MacOSX/Description.plist.sh
mysql-5.5.54/support-files/MacOSX/Info.plist.sh
mysql-5.5.54/support-files/MacOSX/MySQLCOM
mysql-5.5.54/support-files/MacOSX/StartupItem.Description.plist
mysql-5.5.54/support-files/MacOSX/StartupItem.Info.plist
mysql-5.5.54/support-files/MacOSX/StartupItem.postinstall
mysql-5.5.54/support-files/MacOSX/StartupParameters.plist.sh
mysql-5.5.54/support-files/MacOSX/mwar-wrapper
mysql-5.5.54/support-files/MacOSX/mwcc-wrapper
mysql-5.5.54/support-files/MacOSX/postflight.sh
mysql-5.5.54/support-files/MacOSX/preflight.sh
mysql-5.5.54/support-files/MacOSX/ReadMe.txt
mysql-5.5.54/support-files/MySQL-shared-compat.spec.sh
mysql-5.5.54/support-files/RHEL4-SElinux/
mysql-5.5.54/support-files/RHEL4-SElinux/mysql.fc
mysql-5.5.54/support-files/RHEL4-SElinux/mysql.te
mysql-5.5.54/support-files/binary-configure.sh
mysql-5.5.54/support-files/build-tags
mysql-5.5.54/support-files/compiler_warnings.supp
mysql-5.5.54/support-files/config.huge.ini.sh
mysql-5.5.54/support-files/config.medium.ini.sh
mysql-5.5.54/support-files/config.small.ini.sh
mysql-5.5.54/support-files/dtrace/
mysql-5.5.54/support-files/dtrace/locktime.d
mysql-5.5.54/support-files/dtrace/query-execandqc.d
mysql-5.5.54/support-files/dtrace/query-filesort-time.d
mysql-5.5.54/support-files/dtrace/query-network-time.d
mysql-5.5.54/support-files/dtrace/query-parse-time.d
mysql-5.5.54/support-files/dtrace/query-rowops.d
mysql-5.5.54/support-files/dtrace/query-time.d
mysql-5.5.54/support-files/dtrace/statement-time.d
mysql-5.5.54/support-files/dtrace/statement-type-aggregate.d
mysql-5.5.54/support-files/magic
mysql-5.5.54/support-files/my-huge.cnf.sh
mysql-5.5.54/support-files/my-innodb-heavy-4G.cnf.sh
mysql-5.5.54/support-files/my-large.cnf.sh
mysql-5.5.54/support-files/my-medium.cnf.sh
mysql-5.5.54/support-files/my-small.cnf.sh
mysql-5.5.54/support-files/mysql-log-rotate.sh
mysql-5.5.54/support-files/mysql-multi.server.sh
mysql-5.5.54/support-files/mysql.m4
mysql-5.5.54/support-files/mysql.server-sys5.sh
mysql-5.5.54/support-files/mysql.server.sh
mysql-5.5.54/support-files/mysql.spec.sh
mysql-5.5.54/support-files/mysqld_multi.server.sh
mysql-5.5.54/support-files/ndb-config-2-node.ini.sh
mysql-5.5.54/support-files/mysql.5.5.54.spec
mysql-5.5.54/tests/
mysql-5.5.54/tests/CMakeLists.txt
mysql-5.5.54/tests/auto_increment.res
mysql-5.5.54/tests/auto_increment.tst
mysql-5.5.54/tests/big_record.pl
mysql-5.5.54/tests/bug25714.c
mysql-5.5.54/tests/connect_test.c
mysql-5.5.54/tests/deadlock_test.c
mysql-5.5.54/tests/drop_test.pl
mysql-5.5.54/tests/export.pl
mysql-5.5.54/tests/fork2_test.pl
mysql-5.5.54/tests/fork_big.pl
mysql-5.5.54/tests/fork_big2.pl
mysql-5.5.54/tests/function.res
mysql-5.5.54/tests/function.tst
mysql-5.5.54/tests/grant.pl
mysql-5.5.54/tests/grant.res
mysql-5.5.54/tests/index_corrupt.pl
mysql-5.5.54/tests/insert_and_repair.pl
mysql-5.5.54/tests/insert_test.c
mysql-5.5.54/tests/list_test.c
mysql-5.5.54/tests/lock_test.pl
mysql-5.5.54/tests/lock_test.res
mysql-5.5.54/tests/mail_to_db.pl
mysql-5.5.54/tests/myisam-big-rows.tst
mysql-5.5.54/tests/mysql_client_fw.c
mysql-5.5.54/tests/mysql_client_test.c
mysql-5.5.54/tests/pmail.pl
mysql-5.5.54/tests/rename_test.pl
mysql-5.5.54/tests/restore-lock.smack
mysql-5.5.54/tests/select_test.c
mysql-5.5.54/tests/showdb_test.c
mysql-5.5.54/tests/ssl_test.c
mysql-5.5.54/tests/table_types.pl
mysql-5.5.54/tests/test_delayed_insert.pl
mysql-5.5.54/tests/thread_test.c
mysql-5.5.54/tests/truncate.pl
mysql-5.5.54/unittest/
mysql-5.5.54/unittest/README.txt
mysql-5.5.54/unittest/examples/
mysql-5.5.54/unittest/examples/CMakeLists.txt
mysql-5.5.54/unittest/examples/core-t.c
mysql-5.5.54/unittest/examples/no_plan-t.c
mysql-5.5.54/unittest/examples/simple-t.c
mysql-5.5.54/unittest/examples/skip-t.c
mysql-5.5.54/unittest/examples/skip_all-t.c
mysql-5.5.54/unittest/examples/todo-t.c
mysql-5.5.54/unittest/my_decimal/
mysql-5.5.54/unittest/my_decimal/CMakeLists.txt
mysql-5.5.54/unittest/my_decimal/my_decimal-t.cc
mysql-5.5.54/unittest/mysys/
mysql-5.5.54/unittest/mysys/CMakeLists.txt
mysql-5.5.54/unittest/mysys/base64-t.c
mysql-5.5.54/unittest/mysys/bitmap-t.c
mysql-5.5.54/unittest/mysys/explain_filename-t.cc
mysql-5.5.54/unittest/mysys/lf-t.c
mysql-5.5.54/unittest/mysys/my_atomic-t.c
mysql-5.5.54/unittest/mysys/my_malloc-t.c
mysql-5.5.54/unittest/mysys/my_rdtsc-t.c
mysql-5.5.54/unittest/mysys/my_vsnprintf-t.c
mysql-5.5.54/unittest/mysys/thr_template.c
mysql-5.5.54/unittest/mytap/
mysql-5.5.54/unittest/mytap/CMakeLists.txt
mysql-5.5.54/unittest/mytap/Doxyfile
mysql-5.5.54/unittest/mytap/t/
mysql-5.5.54/unittest/mytap/t/basic-t.c
mysql-5.5.54/unittest/mytap/tap.c
mysql-5.5.54/unittest/mytap/tap.h
mysql-5.5.54/unittest/strings/
mysql-5.5.54/unittest/strings/strings-t.c
mysql-5.5.54/unittest/unit.pl
mysql-5.5.54/vio/
mysql-5.5.54/vio/CMakeLists.txt
mysql-5.5.54/vio/docs/
mysql-5.5.54/vio/docs/COPYING.openssl
mysql-5.5.54/vio/docs/INSTALL
mysql-5.5.54/vio/docs/TODO
mysql-5.5.54/vio/test-ssl.c
mysql-5.5.54/vio/test-sslclient.c
mysql-5.5.54/vio/test-sslserver.c
mysql-5.5.54/vio/vio.c
mysql-5.5.54/vio/vio_priv.h
mysql-5.5.54/vio/viosocket.c
mysql-5.5.54/vio/viossl.c
mysql-5.5.54/vio/viosslfactories.c
mysql-5.5.54/vio/viotest-ssl.c
mysql-5.5.54/vio/viotest-sslconnect.cc
mysql-5.5.54/vio/viotest.cc
mysql-5.5.54/win/
mysql-5.5.54/win/create_def_file.js
mysql-5.5.54/zlib/
mysql-5.5.54/zlib/CMakeLists.txt
mysql-5.5.54/zlib/ChangeLog
mysql-5.5.54/zlib/FAQ
mysql-5.5.54/zlib/INDEX
mysql-5.5.54/zlib/README
mysql-5.5.54/zlib/README.MySQL
mysql-5.5.54/zlib/adler32.c
mysql-5.5.54/zlib/algorithm.txt
mysql-5.5.54/zlib/compress.c
mysql-5.5.54/zlib/crc32.c
mysql-5.5.54/zlib/crc32.h
mysql-5.5.54/zlib/deflate.c
mysql-5.5.54/zlib/deflate.h
mysql-5.5.54/zlib/gzio.c
mysql-5.5.54/zlib/infback.c
mysql-5.5.54/zlib/inffast.c
mysql-5.5.54/zlib/inffast.h
mysql-5.5.54/zlib/inffixed.h
mysql-5.5.54/zlib/inflate.c
mysql-5.5.54/zlib/inflate.h
mysql-5.5.54/zlib/inftrees.c
mysql-5.5.54/zlib/inftrees.h
mysql-5.5.54/zlib/trees.c
mysql-5.5.54/zlib/trees.h
mysql-5.5.54/zlib/uncompr.c
mysql-5.5.54/zlib/zconf.h
mysql-5.5.54/zlib/zlib.3
mysql-5.5.54/zlib/zlib.h
mysql-5.5.54/zlib/zutil.c
mysql-5.5.54/zlib/zutil.h
configure in progress ...
lib/mysql.sh: line 13: cmake: command not found
x86_64
----Install Error: mysql configure err -----------
請求各位大俠,這個怎么破
作者: admin    時間: 2017-6-14 08:06
yum源有問題,導(dǎo)致cmake更新不了
作者: xjsxiao2004    時間: 2017-10-23 17:37
那這個錯誤要怎么處理?
