標(biāo)題: [提問(wèn)] 自動(dòng)配置文件這樣寫 [打印本頁(yè)]
作者: feiyaogzs    時(shí)間: 2017-7-23 22:28     標(biāo)題: 自動(dòng)配置文件這樣寫
配置文件有錯(cuò)
AH00526: Syntax error on line 5 of /www/wdlinux/httpd-2.4.25/conf/vhost/port.conf:
SSLSessionCache: 'shmcb' session cache not supported (known names: ). Maybe you need to load the appropriate socache module (mod_socache_shmcb?).
port.conf文件的內(nèi)容如下
Listen 443
AddType application/x-x509-ca-cert .crt
AddType application/x-pkcs7-crl    .crl
SSLHonorCipherOrder on
SSLSessionCache        "shmcb:logs/ssl_scache(512000)"
SSLSessionCacheTimeout  300
SSLMutex  "file:logs/ssl_mutex"
