標(biāo)題: [求助] 安裝提示錯(cuò)誤 求大鳥(niǎo)給解答下 [打印本頁(yè)]
作者: zaituzhe    時(shí)間: 2013-5-20 18:19     標(biāo)題: 安裝提示錯(cuò)誤 求大鳥(niǎo)給解答下
Starting MySQL... SUCCESS!
啟動(dòng) httpd:httpd: Syntax error on line 54 of /www/wdlinux/httpd-2.2.22/conf/httpd.conf: Cannot load /www/wdlinux/httpd-2.2.22/modules/libphp5.so into server: libmhash.so.2: cannot open shared object file: No such file or directory
[失敗]
啟動(dòng) nginx:[確定]
啟動(dòng) httpd:Syntax error on line 232 of /www/wdlinux/wdapache/conf/httpd.conf:
Cannot load /www/wdlinux/wdapache/modules/libphp5.so into server: libxml2.so.2: cannot open shared object file: No such file or directory
[失敗]
啟動(dòng) pure-config.pl:Running: /usr/sbin/pure-ftpd --daemonize -S21 -A -c50 -B -C8 -D -E -fftp -H -I15 -L10000:8 -m4 -s -U133:022 -u100 -k99 -Z -lunix -p20000:20500 -lmysql:/www/wdlinux/etc/pureftpd-mysql.conf
error: %post(lanmp_wdcp-2-5.x86_64) scriptlet failed, exit status 1
============  lanmp_wdcp install error  =============
作者: admin    時(shí)間: 2013-5-20 20:36
什么版本系統(tǒng)?
是yum沒(méi)更新成功吧
作者: zaituzhe    時(shí)間: 2013-5-20 21:09
CentOS 6.0 本來(lái)提示 yum.conf   和SELINUX/CONFIG找不到 , 我去我另外個(gè)服務(wù)器拷了過(guò)來(lái)  然后把防火墻關(guān)掉了
作者: admin    時(shí)間: 2013-5-21 08:50
如果不同版本,直接拷,可能會(huì)有問(wèn)題的
