標(biāo)題: [求助] WDCP 安裝失敗 求分析 [打印本頁(yè)]
作者: zaituzhe    時(shí)間: 2013-5-21 09:35     標(biāo)題: WDCP 安裝失敗 求分析
本帖最后由 zaituzhe 于 2013-5-21 10:27 編輯
sed:無法讀取 /etc/selinux/config:沒有那個(gè)文件或目錄
安裝時(shí)候提示這個(gè)  然后安裝就失敗了!
作者: zaituzhe    時(shí)間: 2013-5-21 09:42
lanmp_wdcp_ins.sh: line 32: yum: command not found
還有這個(gè)提示
作者: zaituzhe    時(shí)間: 2013-5-21 09:43
[root@ve1409106 /]# sh lanmp_wdcp_ins.sh
Turn off selinux...
setenforce: SELinux is disabled
PING dl.wdlinux.cn (61.146.178.5) 56(84) bytes of data.
64 bytes from 61.146.178.5: icmp_seq=1 ttl=54 time=13.3 ms
64 bytes from 61.146.178.5: icmp_seq=2 ttl=54 time=13.4 ms
64 bytes from 61.146.178.5: icmp_seq=3 ttl=54 time=13.5 ms
--- dl.wdlinux.cn ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 13.384/13.490/13.595/0.086 ms
rpm remove...
error: package php is not installed
error: package httpd is not installed
error: package mysql-server is not installed
error: package mysql is not installed
yum update...
lanmp_wdcp_ins.sh: line 58: yum: command not found
--2013-05-21 09:25:51--  http://dl.wdlinux.cn:5180/rpms/lanmp_wdcp-2-5.x86_64.rpm
正在解析主機(jī) dl.wdlinux.cn... 61.146.178.5
Connecting to dl.wdlinux.cn|61.146.178.5|:5180... 已連接。
已發(fā)出 HTTP 請(qǐng)求,正在等待回應(yīng)... 416 Requested Range Not Satisfiable
    文件已下載完成;不會(huì)進(jìn)行任何操作。
Preparing...                ########################################### [100%]
   1:lanmp_wdcp             ^C########################################### [100%]
============  lanmp_wdcp install error  =============
作者: zaituzhe    時(shí)間: 2013-5-21 10:27
卸載的時(shí)候提示
[root@ve1409106 etc]# sudo sh lanmp_wdcp_ins.sh uninstall
sh: lanmp_wdcp_ins.sh: 沒有那個(gè)文件或目錄
[root@ve1409106 etc]# sh lanmp_wdcp_ins.sh uninstall
[root@ve1409106 etc]# sh lanmp_wdcp_24_ins.sh uninstall
sh: lanmp_wdcp_24_ins.sh: 沒有那個(gè)文件或目錄
[root@ve1409106 etc]# cd ..
[root@ve1409106 /]# sh lanmp_wdcp_ins.sh uninstall
starting backup data...
ERROR! MySQL manager or server PID file could not be found!
停止 httpd:                                               [失敗]
停止 httpd:                                               [失敗]
停止 pure-config.pl:cat: /var/run/pure-ftpd.pid: 沒有那個(gè)文件或目錄
kill: usage: kill [-s sigspec | -n signum | -sigspec] pid | jobspec ... or kill -l [sigspec]
作者: admin    時(shí)間: 2013-5-21 12:06
什么系統(tǒng)?yum都沒有
作者: marquis    時(shí)間: 2013-5-21 14:47
裝個(gè)yum包 試試
