標題:
請問WDCP3.2.21如何設(shè)置Nginx支持TP5的pathinfo?
Locked
2017-12-2 12:12
標題:
我在網(wǎng)上找了一些方法修改對應域名的.conf但是沒有辦法完成 請問如何可以實現(xiàn)呢?
Locked
2017-12-2 15:02
求大神們幫幫解決。!
hyqlhy
2017-12-12 17:41
同求同求,現(xiàn)在的配置文件是錯的,獲取不到PATHINFO
hyqlhy
2017-12-15 09:47
我找到了一種辦法,配置文件如下:
server {
listen 80;
root /www/web/xxxx/public_html;
include /www/wdlinux/wdcp/rewrite/robelf_nginx.conf;
server_name xxxx.com www.xxxx.com;
index index.html index.php index.htm;
error_page 400 /errpage/400.html;
error_page 403 /errpage/403.html;
error_page 404 /errpage/404.html;
error_page 503 /errpage/503.html;
location ~ \.php {
fastcgi_pass unix:/tmp/php-56-cgi.sock;
fastcgi_index index.php;
include fcgi.conf;
set $real_script_name $fastcgi_script_name;
if ($fastcgi_script_name ~ "^(.+?\.php)(/.+)$") {
set $real_script_name $1;
set $path_info $2;
fastcgi_param SCRIPT_FILENAME $document_root$real_script_name;
fastcgi_param SCRIPT_NAME $real_script_name;
fastcgi_param PATH_INFO $path_info;
location ~ /\.ht {
deny all;
location / {
try_files $uri $uri/ /?$args;
Locked
2017-12-15 10:27
回復
4#
hyqlhy
感謝,我先嘗試一下!
Miker
2017-12-16 16:05
安裝完成需要配置Nginx相關(guān)文件重新啟動服務器即可的
Locked
2017-12-18 10:29
回復
6#
Miker
你這當什么都沒說啊
jiangyouhong
2017-12-19 15:22
回復
1#
Locked
你好,打開wdcp面板,找到-文件管理-點擊nginx,然后修改對應站點的nginx配置為:
location ~ \.php(.*)$ {
fastcgi_param SCRIPT_FILENAME $DOCUMENT_ROOT$fastcgi_script_name;
fastcgi_param PATH_INFO $2;
include fcgi.conf;
set $path_info "";
if ($fastcgi_script_name ~ "^(.+\.php)(/.+)$") {
set $path_info $2;
復制代碼
jiangyouhong
2017-12-19 15:22
回復
8#
jiangyouhong
當然了,要從啟一下web服務
風過意濃
2019-3-22 15:42
/www/wdlinux/wdcp/rewrite/robelf_nginx.conf; 這個文件呢?
