標(biāo)題: [BUG反饋] v3不能增加子域名 [打印本頁(yè)]
作者: evilbat    時(shí)間: 2017-12-25 18:10     標(biāo)題: v3不能增加子域名
添加域名后頁(yè)面變?nèi),但是再點(diǎn)域名列表還可以看到域名已經(jīng)增加了
進(jìn)入剛添加的域名,增加子域名,設(shè)置好內(nèi)容,點(diǎn)完確定后頁(yè)面就變?nèi),再查看子域名列表是空白,然后看log有報(bào)錯(cuò)
2017/12/25 17:30:58 [C] the request url is  /dns/records
2017/12/25 17:30:58 [C] Handler crashed with error runtime error: index out of range
2017/12/25 17:30:58 [C] /root/go/src/runtime/asm_amd64.s:509
2017/12/25 17:30:58 [C] /root/go/src/runtime/panic.go:491
2017/12/25 17:30:58 [C] /root/go/src/runtime/panic.go:28
2017/12/25 17:30:58 [C] /smb/code/src/wddns/src/controllers/dns.go:261
2017/12/25 17:30:58 [C] /root/go/src/reflect/value.go:434
2017/12/25 17:30:58 [C] /root/go/src/reflect/value.go:302
2017/12/25 17:30:58 [C] /smb/code/src/github.com/astaxie/beego/router.go:815
2017/12/25 17:30:58 [C] /root/go/src/net/http/server.go:2619
2017/12/25 17:30:58 [C] /root/go/src/net/http/server.go:1801
2017/12/25 17:30:58 [C] /root/go/src/runtime/asm_amd64.s:2337
