wdcp centos 7.3 nginx+apache,系統(tǒng)重啟后.頁面打不開
jiangzhaos
服務(wù)器重啟后,發(fā)現(xiàn)nginx啟動(dòng)了.但是httpd沒有啟動(dòng).說80端口占用.由于是接手別人維護(hù),以前的配置就這樣.
圖片上傳不了只能文字了,執(zhí)行命令service httpd status 內(nèi)容如下
Apr 13 14:01:49 VM_132_179_centos httpd[24588]: AH00558: httpd: Could not reliably determine the server's fully qualified domai...essage
Apr 13 14:01:49 VM_132_179_centos httpd[24588]: (98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:80
Apr 13 14:01:49 VM_132_179_centos httpd[24588]: no listening sockets available, shutting down
Apr 13 14:01:49 VM_132_179_centos httpd[24588]: AH00015: Unable to open logs
Apr 13 14:01:49 VM_132_179_centos systemd[1]: httpd.service: main process exited, code=exited, status=1/FAILURE
Apr 13 14:01:49 VM_132_179_centos kill[24589]: kill: cannot find process ""
Apr 13 14:01:49 VM_132_179_centos systemd[1]: httpd.service: control process exited, code=exited status=1
Apr 13 14:01:49 VM_132_179_centos systemd[1]: Failed to start The Apache HTTP Server.
Apr 13 14:01:49 VM_132_179_centos systemd[1]: Unit httpd.service entered failed state.
Apr 13 14:01:49 VM_132_179_centos systemd[1]: httpd.service failed.
Hint: Some lines were ellipsized, use -l to show in full.
