標題: [教程] WDCP自動將主機上的文件上傳到百度網(wǎng)盤中 [打印本頁]
作者: b15365637 時間: 2018-8-5 18:38 標題: WDCP自動將主機上的文件上傳到百度網(wǎng)盤中
本帖最后由 Miker 于 2018-8-7 13:10 編輯
bpcs_uploader,利用bpcs_uploader你可以自動將VPS主機上的文件上傳到百度網(wǎng)盤中,同時也可以從百度網(wǎng)盤中下載文件到VPS主機上,讓你的文件安全地“住”在百度云中。
百度云空間容量大,且有了百度這個靠山,日后也不必擔心網(wǎng)盤關門走人,隨著眾多國內(nèi)網(wǎng)盤開始投放大量的廣告到網(wǎng)盤下載頁面(典型的有華為網(wǎng)盤、下載賺錢網(wǎng)盤),百度網(wǎng)盤清爽的風格就顯得難能可貴了。將文件上傳到百度云中就可以方便其它用戶下載
1.安裝wdcp
sh lanmp_wdcp_ins.sh
2.下載bpcs_uploader上傳腳本
https://github.com/oott123/bpcs_uploader/tarball/master
給chmod +x bpcs_uploader.php執(zhí)行權限
3.查看php路徑
/www/wdlinux/nginx_php-5.2.17/bin/php –v
將bpcs_uploader.php第一行修改成
#!/www/wdlinux/nginx_php-5.2.17/bin/php -ddisable_functions -d safe_mode=Off
----------------------------------------------------------------------------------------------------------------------------------------------------- [root@VM_166_159_centos oott123-bpcs_uploader-3a75324]# ./bpcs_uploader.php quickinit
- ===========================Baidu PCS Uploader===========================
- Usage: ./bpcs_uploader.php init|quickinit|quota
- Usage: ./bpcs_uploader.php upload|download path_local path_remote
- Usage: ./bpcs_uploader.php delete path_remote
- Usage: ./bpcs_uploader.php uploadbig path_local path_remote [slice_size(default:1073741824)] [temp_dir(def:/tmp/)]
- Usage: ./bpcs_uploader.php fetch path_remote path_to_fetch
- Uploader initialization will be begin. If you have already configured the uploader before, y our old settings will be overwritten.
- Continue? [y/N] y
- % Total % Received % Xferd Average Speed Time Time Time Current
- Dload Upload Total Spent Left Speed
- 171 263 0 263 0 80 671 204 --:--:-- --:--:-- --:--:-- 3210
- Launch your favorite web browser and visit https://openapi.baidu.com/device
- Input 2a24n8dv as the user code if asked.
- After granting access to the application, come back here and press Enter to continue.
- 244 101 0 101 0 143 531 753 --:--:-- --:--:-- --:--:-- 0
- OAuth error authorization_pending : User has not yet completed the authorization
- Authentication failed. Please check the error message and try again.
- Continue? [y/N] y
- 244 101 0 101 0 143 546 773 --:--:-- --:--:-- --:--:-- 0
- Continue? [y/N] y
- 180 397 0 397 0 143 2162 778 --:--:-- --:--:-- --:--:-- 5772
- 0 66 0 66 0 0 220 0 --:--:-- --:--:-- --:--:-- 366
- Access Granted. Your Storage Status: 105.95G/2063.00G (5.14%)
- Enjoy!
復制代碼
以上為快速初始化代碼,輸入授權碼網(wǎng)址:https://openapi.baidu.com/device
- 然后打開瀏覽器訪問 https://openapi.baidu.com/device ,在“請輸入設備上顯示的用戶授權碼:”文本框中輸入上面顯示的授權碼,并點擊繼續(xù)。 看到網(wǎng)頁上顯示“請返回設備繼續(xù)操作!”后,返回ssh上按下回車后,即完成了初始化配置。
- 重新分配
- [root@VM_166_159_centos oott123-bpcs_uploader-3a75324]# ./bpcs_uploader.php init
- Uploader initialization will be begin. If you have already configured the uploader before, your old settings will b e overwritten.
- Continue? [y/N] y
- Please enter your PSC App API Key. You can get this key by visiting http://developer.baidu.com/dev#/create
- If you have already created an app, you can visit http://developer.baidu.com/console#/app and get it in your app's info.
- If you don't want to bother creating an app, you can press Enter to use the demo API Key.
- Doing so (without your own API Key/Secret) will cause the access-token to expire every 30 days, and you'll have to
- re-initialize when it expires.
- App API KEY [uFBSHEwWE6DD94SQx9z77vgG] :uFBSHEwWE6DD94SQx9z77vgG
- App API Key has been set to uFBSHEwWE6DD94SQx9z77vgG .
- Demo key detected. Using default API Secret.
- Demo key detected. Using default app name.
- 171 263 0 263 0 80 1355 412 --:--:-- --:--:-- --:--:-- 3452
- Input axmhkper as the user code if asked.
- 179 395 0 395 0 143 2010 727 --:--:-- --:--:-- --:--:-- 5250
- 0 67 0 67 0 0 294 0 --:--:-- --:--:-- --:--:-- 690
復制代碼
4.我們測試上傳文件
Powered by Discuz! 7.2 |
