標(biāo)題: [求助] nginx升級(jí)失敗,求助,求助,求助 [打印本頁(yè)]
作者: cyanwu    時(shí)間: 2019-6-23 15:40     標(biāo)題: nginx升級(jí)失敗,求助,求助,求助
照著這個(gè)進(jìn)行升級(jí)。。。http://www.szkyjg.com/bbs/redirect.php?tid=63480&goto=lastpost
make[1]: Leaving directory `/tmp/nginx-1.15.7'
cp: `/www/wdlinux/nginx/conf/cert' and `/www/wdlinux/nginx-1.15.7/conf/cert' are the same file
cp: `/www/wdlinux/nginx/conf/fastcgi.conf' and `/www/wdlinux/nginx-1.15.7/conf/fastcgi.conf' are the same file
cp: `/www/wdlinux/nginx/conf/fastcgi.conf.default' and `/www/wdlinux/nginx-1.15.7/conf/fastcgi.conf.default' are the same file
cp: `/www/wdlinux/nginx/conf/fastcgi_params' and `/www/wdlinux/nginx-1.15.7/conf/fastcgi_params' are the same file
cp: `/www/wdlinux/nginx/conf/fastcgi_params.default' and `/www/wdlinux/nginx-1.15.7/conf/fastcgi_params.default' are the same file
cp: `/www/wdlinux/nginx/conf/fcgi.conf' and `/www/wdlinux/nginx-1.15.7/conf/fcgi.conf' are the same file
cp: `/www/wdlinux/nginx/conf/koi-utf' and `/www/wdlinux/nginx-1.15.7/conf/koi-utf' are the same file
cp: `/www/wdlinux/nginx/conf/koi-win' and `/www/wdlinux/nginx-1.15.7/conf/koi-win' are the same file
cp: `/www/wdlinux/nginx/conf/mime.types' and `/www/wdlinux/nginx-1.15.7/conf/mime.types' are the same file
cp: `/www/wdlinux/nginx/conf/mime.types.default' and `/www/wdlinux/nginx-1.15.7/conf/mime.types.default' are the same file
cp: `/www/wdlinux/nginx/conf/naproxy.conf' and `/www/wdlinux/nginx-1.15.7/conf/naproxy.conf' are the same file
cp: `/www/wdlinux/nginx/conf/nginx.conf2015122611' and `/www/wdlinux/nginx-1.15.7/conf/nginx.conf2015122611' are the same file
cp: `/www/wdlinux/nginx/conf/nginx.conf.default' and `/www/wdlinux/nginx-1.15.7/conf/nginx.conf.default' are the same file
cp: `/www/wdlinux/nginx/conf/rewrite' and `/www/wdlinux/nginx-1.15.7/conf/rewrite' are the same file
cp: `/www/wdlinux/nginx/conf/scgi_params' and `/www/wdlinux/nginx-1.15.7/conf/scgi_params' are the same file
cp: `/www/wdlinux/nginx/conf/scgi_params.default' and `/www/wdlinux/nginx-1.15.7/conf/scgi_params.default' are the same file
cp: `/www/wdlinux/nginx/conf/uwsgi_params' and `/www/wdlinux/nginx-1.15.7/conf/uwsgi_params' are the same file
cp: `/www/wdlinux/nginx/conf/uwsgi_params.default' and `/www/wdlinux/nginx-1.15.7/conf/uwsgi_params.default' are the same file
cp: `/www/wdlinux/nginx/conf/vhost' and `/www/wdlinux/nginx-1.15.7/conf/vhost' are the same file
cp: `/www/wdlinux/nginx/conf/win-utf' and `/www/wdlinux/nginx-1.15.7/conf/win-utf' are the same file
Stopping nginx: nginx: [emerg] open() "/www/wdlinux/nginx-1.15.7/conf/nginx.conf" failed (2: No such file or directory)
