EXIF安裝請教
bamuyi
2013-7-26 11:55
EXIF安裝請教
[root@AY130701215223445424Z ~]# cd /usr/local/src/php-5.2.17/ext
[root@AY130701215223445424Z ext]# cd exif/
[root@AY130701215223445424Z exif]# /www/wdlinux/apache_php-5.3.26/bin/phpize
Configuring for:
PHP Api Version: 20090626
Zend Module Api No: 20090626
Zend Extension Api No: 220090626
[root@AY130701215223445424Z exif]# ./configure --with-php-config=/www/wdlinux/apache_php-5.3.26/bin/php-config
checking for cc... cc
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking how to run the C preprocessor... cc -E
checking for icc... no
checking for suncc... no
checking whether cc understands -c and -o together... yes
checking for system library directory... lib
checking if compiler supports -R... no
checking if compiler supports -Wl,-rpath,... yes
checking for PHP prefix... /www/wdlinux/apache_php-5.3.26
checking for PHP includes... -I/www/wdlinux/apache_php-5.3.26/include/php -I/www/wdlinux/apache_php-5.3.26/include/php/main -I/www/wdlinux/apache_php-5.3.26/include/php/TSRM -I/www/wdlinux/apache_php-5.3.26/include/php/Zend -I/www/wdlinux/apache_php-5.3.26/include/php/ext -I/www/wdlinux/apache_php-5.3.26/include/php/ext/date/lib
checking for PHP extension directory... /www/wdlinux/apache_php-5.3.26/lib/php/extensions/no-debug-non-zts-20090626
checking for PHP installed headers prefix... /www/wdlinux/apache_php-5.3.26/include/php
checking if debug is enabled... no
checking if zts is enabled... no
checking for re2c... no
configure: WARNING: You will need re2c 0.13.4 or later if you want to regenerate PHP parsers.
checking for gawk... gawk
checking whether to enable EXIF (metadata from images) support... yes, shared
checking for ld used by cc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognize dependent libraries... pass_all
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking the maximum length of command line arguments... 1966080
checking command to parse /usr/bin/nm -B output from cc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if cc supports -fno-rtti -fno-exceptions... no
checking for cc option to produce PIC... -fPIC
checking if cc PIC flag -fPIC works... yes
checking if cc static flag -static works... no
checking if cc supports -c -o file.o... yes
checking whether the cc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
creating libtool
appending configuration tag "CXX" to libtool
configure: creating ./config.status
config.status: creating config.h
config.status: config.h is unchanged
[root@AY130701215223445424Z exif]# make && make install
/bin/sh /usr/local/src/php-5.2.17/ext/exif/libtool --mode=install cp ./exif.la /usr/local/src/php-5.2.17/ext/exif/modules
cp ./.libs/exif.so /usr/local/src/php-5.2.17/ext/exif/modules/exif.so
cp ./.libs/exif.lai /usr/local/src/php-5.2.17/ext/exif/modules/exif.la
PATH="$PATH:/sbin" ldconfig -n /usr/local/src/php-5.2.17/ext/exif/modules
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the `LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the `LD_RUN_PATH' environment variable
during linking
- use the `-Wl,--rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
Build complete.
Installing shared extensions: /www/wdlinux/apache_php-5.3.26/lib/php/extensions/no-debug-non-zts-20090626/
Configure Command './configure' '--prefix=/www/wdlinux/apache_php-5.3.26' '--with-config-file-path=/www/wdlinux/apache_php-5.3.26/etc' '--with-mysql=/www/wdlinux/mysql' '--with-iconv=/usr' '--with-freetype-dir' '--with-jpeg-dir' '--with-png-dir' '--with-zlib' '--with-libxml-dir=/usr' '--enable-xml' '--disable-rpath' '--enable-discard-path' '--enable-inline-optimization' '--with-curl' '--enable-mbregex' '--enable-mbstring' '--with-mcrypt=/usr' '--with-gd' '--enable-gd-native-ttf' '--with-openssl' '--with-mhash' '--enable-ftp' '--enable-sockets' '--enable-zip' '--with-apxs2=/www/wdlinux/apache/bin/apxs'
為什么還是安裝不上,是不是哪里出現(xiàn)了問題?
PHP.INI
配置如下
; Directory in which the loadable extensions (modules) reside.
; http://php.net/extension-dir
extension_dir = "/www/wdlinux/apache_php-5.3.26/lib/php/extensions/no-debug-non-zts-20090626/"
; On windows:
extension_dir = "ext"
extension = "exif.so";
請求幫助
2013-7-26 18:11
怎么5.3的環(huán)境,用5.2的源碼來編譯?
