˜Ëî}: [ÇóÖú] Íû¸÷λ´ó´óÖ¸½ÌÏÂß@‚€ÅäÖà [´òÓ¡±¾í“]
×÷Õß: ˆÌ(zh¨ª)‘Ù    •rég: 2013-8-30 19:28     ˜Ëî}: Íû¸÷λ´ó´óÖ¸½ÌÏÂß@‚€ÅäÖÃ
¸÷λlinuxß_ÈË£¬ÎÒ„‚Ūlinux·þ„Õ(w¨´)Æ÷£¬²ËÏxÒ»‚€£¬ŽÍæ¿´ÏÂÏÂÃæµÄÅäÖÃÄÄЩ²»ºÏÀí£¬ÓÐÄÄÐ©ÖØÒªµÄÅäÖÛ]Ū£¬
·þ„Õ(w¨´)Æ÷Ö÷ÒªÓÃÓÚappµÄÔL†–£¬›]ÓÐí“Ãæ¡£”µ(sh¨´)“þ(j¨´)ŽìÒ²²»´ó¡£¿ÉÊÇÓЕr•þºÜÂý¡£ßh³ÌxshellßB½ÓÝ”Èë‚€×Ö·û¶¼Òª½üÒ»·ÖçŠ×óÓҲſ´µ½£¬Ž§Œ’ÊÇ2MµÄ
£¬²»ÖªµÀÆ¿îiÔÚÄÄÀtop¿´ÙYԴʹÓõĕrºòcpuʹÓÃÂʺܵÍ¡£ƒÈ(n¨¨i)´æÒ²›]ÓÃÍ꣬¿É¾ÍÊǺÜÂý¡££¬ÍûÖ¸üc
1.Ó²¼þ£º(°¢ÀïÔÆµÄ)CPU£ºIntel(R) Xeon(R) CPU E5-2430 0 @ 2.20GHz 4ºË
ƒÈ(n¨¨i)´æ£º4G
2.ϵ½y(t¨¯ng)£º
Ubuntu 12.04 64λ °²È«¼Ó¹Ì°æ£¬ÑbÁËtomcat6£¬mysql5.1 wdcp 2.5
3.tomcat ÅäÖãº
  <GlobalNamingResources>
    <!-- Editable user database that can also be used by
         UserDatabaseRealm to authenticate users
    <Resource name="UserDatabase" auth="Container"
              type="org.apache.catalina.UserDatabase"
              description="User database that can be updated and saved"
              factory="org.apache.catalina.users.MemoryUserDatabaseFactory"
              pathname="conf/tomcat-users.xml"
maxActive="400"
maxIdle="10"
maxWait="18000000"/>
  </GlobalNamingResources>
<Connector port="8080" protocol="HTTP/1.1"
               connectionTimeout="20000"
               URIEncoding="UTF-8"
               redirectPort="8443"
       maxThreads="500"
minSpareThreads="10"
maxSpareThreads="100"
acceptCount="100"
enableLookups="false"
4.MysqlÅäÖãº
[mysqld]
port
= 3306
socket
= /tmp/mysql.sock
init_connect = 'SET autocommit=0'
skip-locking
key_buffer_size = 256M
max_allowed_packet = 16M
table_open_cache = 512
sort_buffer_size = 32M
net_buffer_length = 512K
read_buffer_size = 10M
read_rnd_buffer_size = 4M
myisam_sort_buffer_size = 64M
wait_timeout = 2880000
interactive_timeout = 2880000
net_read_timeout = 10
max_connections = 500
net_retry_count = 2
tmp_table_size = 50M
table_cache=512
query_cache_size = 64M
thread_cache_size = 16
# log slow query
log-slow-queries = /var/lib/mysql/my.slow.log
long_query_time = 1
# log-queries-not-using-indexes = 1
# log-slow-admin-statements = 1
server-id
= 1
# Uncomment the following if you are using InnoDB tables
innodb_data_home_dir = /www/wdlinux/mysql-5.1.61/var
innodb_data_file_path = ibdata1:10M:autoextend
innodb_log_group_home_dir = /www/wdlinux/mysql-5.1.61/var
# You can set .._buffer_pool_size up to 50 - 80 %
# of RAM but beware of setting memory usage too high
innodb_buffer_pool_size = 1G
innodb_additional_mem_pool_size = 16M
# Set .._log_file_size to 25 % of buffer pool size
innodb_log_file_size = 256M
innodb_log_files_in_group=3
innodb_log_buffer_size = 8M
innodb_flush_log_at_trx_commit = 2
innodb_lock_wait_timeout = 50
innodb_file_per_table=1
innodb_file_io_threads=4
innodb_open_files=500
innodb_flush_method=O_DIRECT
[mysqldump]
quick
[mysql]
no-auto-rehash
# Remove the next comment character if you are not familiar with SQL
#safe-updates
[myisamchk]
key_buffer_size = 20M
sort_buffer_size = 20M
read_buffer = 2M
write_buffer = 2M
5.JAVAÅäÖãº
export JAVA_OPTS="-server -Xms512m -Xmx1024m -XXermSize=128m -XX:MaxNewSize=512m -XX:MaxPermSize=512m -Djava.awt.headless=true"
