標(biāo)題: [求助] 一件安裝包安裝出錯了,請管理員處理下 [打印本頁]
作者: a529400    時間: 2013-9-4 18:22     標(biāo)題: 一件安裝包安裝出錯了,請管理員處理下
安裝系統(tǒng):CentOS6.2 64位安全版
  1. General settings
  2. checking whether to include gcov symbols... no
  3. checking whether to include debugging symbols... no
  4. checking layout of installed files... PHP
  5. checking path to configuration file... DEFAULT
  6. checking where to scan for configuration files...
  7. checking whether to enable safe mode by default... no
  8. checking for safe mode exec dir... /usr/local/php/bin
  9. checking whether to enable PHP's own SIGCHLD handler... no
  10. checking whether to enable magic quotes by default... no
  11. checking whether to explicitly link against libgcc... no
  12. checking whether to enable short tags by default... yes
  13. checking whether to enable dmalloc... no
  14. checking whether to enable IPv6 support... yes
  15. checking how big to make fd sets... using system default
  16. Configuring extensions
  17. checking size of long... (cached) 8
  18. checking size of int... (cached) 4
  19. checking for int32_t... yes
  20. checking for uint32_t... yes
  21. checking for sys/types.h... (cached) yes
  22. checking for inttypes.h... (cached) yes
  23. checking for stdint.h... (cached) yes
  24. checking for string.h... (cached) yes
  25. checking for stdlib.h... (cached) yes
  26. checking for strtoll... yes
  27. checking for atoll... yes
  28. checking for strftime... (cached) yes
  29. checking whether to enable LIBXML support... yes
  30. checking libxml2 install dir... no
  31. checking for xml2-config path... configure: error: xml2-config not found. Please check your libxml2 installation.
  32. ----Install Error: wdphp configure err -----------
作者: admin    時間: 2013-9-5 09:14
像是yum的庫沒更新到
作者: a529400    時間: 2013-9-5 17:00
   需要更新那些東西?
作者: a529400    時間: 2013-9-5 17:42
checking for xml2-config path... /usr/bin/xml2-config
checking whether libxml build works... yes
checking for OpenSSL support... no
checking for Kerberos support... no
checking for PCRE support... yes
checking for ZLIB support... yes
checking if the location of ZLIB install directory is defined... no
checking for gzgets in -lz... yes
checking whether to enable bc style precision math functions... no
checking for BZip2 support... no
checking whether to enable calendar conversion support... no
checking whether to enable ctype functions... yes
checking for cURL support... yes
checking if we should use cURL for url streams... no
checking for cURL in default path... not found
configure: error: Please reinstall the libcurl distribution -
    easy.h should be in <curl-dir>/include/curl/
  現(xiàn)在重新安裝又出現(xiàn)這個問題了
作者: admin    時間: 2013-9-6 10:50
yum install -y gcc gcc-c++ make autoconf libtool-ltdl-devel gd-devel freetype-devel libxml2-devel libjpeg-devel libpng-devel openssl-devel curl-devel patch libmcrypt-devel libmhash-devel ncurses-devel sudo bzip2
