標題: [求助] 老大,我wdcp_v2.5.9 用的是apache [打印本頁]
作者: cfooxl    時間: 2013-11-30 23:02     標題: 老大,我wdcp_v2.5.9 用的是apache
我只裝了apache,如果想切換nginx的話,該如何操作?因為如果要重裝的話,就要備份什么的 太麻煩了
而現(xiàn)在apache越來越不行了...
作者: admin    時間: 2013-12-1 22:37
可以再運行下安裝腳本,然后選擇相應(yīng)的選項即可
安裝前,可以打包下數(shù)據(jù)庫目錄,以防萬一
作者: cfooxl    時間: 2013-12-2 13:49
[root@rxero ~]# sh lanmp.sh
Select Install
    1 apache + php + mysql + zend + eAccelerator + pureftpd + phpmyadmin
    2 nginx + php + mysql + zend + eAccelerator + pureftpd + phpmyadmin
    3 nginx + apache + php + mysql + zend + eAccelerator + pureftpd + phpmyadmin
    4 install all service
    5 don't install is now
Please Input 1,2,3,4,5: 3
Select php version:
    1 php-5.2.17 (default)
    2 php-5.3.27
Please Input 1,2: 1
Retrieving http://pkgs.repoforge.org/rpmforge-release/rpmforge-release-0.5.3-1.el6.rf.x86_64.rpm
Preparing...                ########################################### [100%]
        package rpmforge-release-0.5.3-1.el6.rf.x86_64 is already installed
Loaded plugins: fastestmirror
* base: mirrors.kernel.org
* extras: centosc5.centos.org
* rpmforge: repoforge.mirror.constant.com
* updates: centosb6.centos.org
base                                                     | 3.7 kB     00:00
extras                                                   | 3.4 kB     00:00
rpmforge                                                 | 1.9 kB     00:00
updates                                                  | 3.4 kB     00:00
vz-base                                                  |  951 B     00:00
vz-updates                                               |  951 B     00:00
Setting up Install Process
Package gcc-4.4.7-4.el6.x86_64 already installed and latest version
Package gcc-c++-4.4.7-4.el6.x86_64 already installed and latest version
Package 1:make-3.81-20.el6.x86_64 already installed and latest version
Package sudo-1.8.6p3-12.el6.x86_64 already installed and latest version
Package autoconf-2.63-5.1.el6.noarch already installed and latest version
Package libtool-ltdl-devel-2.2.6-15.5.el6.x86_64 already installed and latest version
Package gd-devel-2.0.35-11.el6.x86_64 already installed and latest version
Package freetype-devel-2.3.11-14.el6_3.1.x86_64 already installed and latest version
Package libxml2-devel-2.7.6-14.el6.x86_64 already installed and latest version
Package libjpeg-turbo-devel-1.2.1-1.el6.x86_64 already installed and latest version
Package 2:libpng-devel-1.2.49-1.el6_2.x86_64 already installed and latest version
Package openssl-devel-1.0.1e-15.el6.x86_64 already installed and latest version
Package libcurl-devel-7.19.7-37.el6_4.x86_64 already installed and latest version
Package patch-2.6-6.el6.x86_64 already installed and latest version
Package libmcrypt-devel-2.5.7-1.2.el6.rf.x86_64 already installed and latest version
Package mhash-devel-0.9.9-1.el6.rf.x86_64 already installed and latest version
Package ncurses-devel-5.7-3.20090208.el6.x86_64 already installed and latest version
Package bzip2-1.0.5-7.el6_0.x86_64 already installed and latest version
Package libcap-devel-2.16-5.5.el6.x86_64 already installed and latest version
Package ntp-4.2.6p5-1.el6.centos.x86_64 already installed and latest version
No package sysklogd available.
Package diffutils-2.8.1-28.el6.x86_64 already installed and latest version
Package sendmail-8.14.4-8.el6.x86_64 already installed and latest version
Package iptables-1.4.7-11.el6.x86_64 already installed and latest version
Package unzip-6.0-1.el6.x86_64 already installed and latest version
Nothing to do
2 Dec 13:38:25 ntpdate[951]: Can't adjust the time of day: Operation not permitted
Cannot access the Hardware Clock via any known method.
Use the --debug option to see the details of our search for an access method.
restart...
Shutting down MySQL. SUCCESS!
Starting MySQL.... SUCCESS!
Starting httpd:
Starting nginx: nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Address already in use)
nginx: [emerg] still could not bind()
[FAILED]
Starting pure-ftpd:
iptables: Saving firewall rules to /etc/sysconfig/iptables: [  OK  ]
      Congratulations ,lanmp install is complete
      visit http://ip
      more infomation please visit http://www.szkyjg.com
老大 求幫助,我是小白。。。
作者: cfooxl    時間: 2013-12-2 14:21
算了,我還是備份所有文件重裝吧...
